Using a Stripboard as a Final Product
Page 1 of 1 [16 Posts]
ChrisSousa9
PostPosted: Mon Dec 01, 2008 7:40 pm    Post subject: Using a Stripboard as a Final Product Reply with quote  Mark this post and the followings unread
So, I recently got started into making my own schematics and such on breadboards (About a year ago). So I know they're are about three ways you can make a circuit 1) Breadboard 2) Stripboard 3) PCB. I've always used pre-made PCB whenever I build a circuit, quiet cost consuming if I don't say myself (No offense to any Synth PCBer's, Ray Wilson has awesome PCB's). But I thought about just using stripboard for my synth projects and solder my leads on the bottom. The good thing about this is a save about $20 for buying or designing my own PCB. Of course you run definetly have a lot more on the board itself, And that could lead to some design flaws. Im want to know some of your opinions on this. Is it safe with building Power Supplies on?
www.soundabstract.net
"Overprotecting intellectual property is as harmful as underprotecting it. Culture is impossible without a rich public domain. Nothing today, likely nothing since we tamed fire, is genuinely new: Culture, like science and technology, grows by accretion, each new creator building on the works of those who came before. Overprotection stifles the very creative forces it's supposed to nurture." - Alex Kozinski, Ninth Circuit Federal Court of Appeals Judge
DrJustice
PostPosted: Tue Dec 02, 2008 7:34 am    Post subject: Reply with quote  Mark this post and the followings unread
The thing with stripboards is that big projects can become a bit messy and not so fun to maintain or repair. Other than that I see no reason not to use them if it suits you. High speed digital circuits may emit more noise, and some critical analogue circuits may not perform as well, as on a purpose designed PCB with optimal ruoting, ground and power planes etc.. Most synth related circuits should be fine, though. You can safely use stripboards for power supplies too, as long as you are careful with the construction and not too much heat is generated.
DJ
kxspxr
PostPosted: Fri Dec 05, 2008 3:24 am    Post subject: Reply with quote  Mark this post and the followings unread
I have succesfully used veroboard/stripboard on all my DIY projects. Ring modulators, LFO, VCO, VCF and ELF radios. Everything still works to perfection. The drawback is that it can be quite messy and difficult to repair, as DrJustice noted. On the other hand, it's quick and dirty compared to PCB-making, hole drilling etc. I have considered on several occasions to start making PCB using the phototransfer method. It looks easy and I might just look into that between xmas and new year since I have a friend who offered to help me get startet. If I were you I would look into the phototransfer method too... and use stripboard for smaller projects.
I found a straight forward tutorial for phototransfer here:
http://www.youtube.com/watch?v=QQupRXEqOz4
EDIT: You can also consider getting Futurlec to make the PCB's for you. It's actually quite cheap: http://www.futurlec.com/PCBService.shtml
-kasper
"Posthumanity is a discrete set of processes with arbitrary return codes."
PostPosted: Fri Dec 05, 2008 3:53 am    Post subject: Reply with quote  Mark this post and the followings unread
I've used stripboard for many projects and they all work just fine. The messiness aspect can be fixed by laying out designs using a layout application like Lochmaster. It makes it easy to design layouts which are compact, noise free, easy to work on, etc. I've used stripboard to build PSUs (like my latest one) and plan on doing a beefed up version which deliver 3Amps per rail. It mostly comes down to using the same kind of design principles which you use in PCB layouts. Plenty of space for hot parts, offboard connections where they are appropriate, sufficient traces for high current etc.
If you don't see the stripboard layout as a "temporary", "make shift", or "rough version" etc. it won't be.
Include proper insulated mounting holes. Mark your cuts with a felt pen before cutting them. Maximise the length of traces connected to Ground and minimise all others.
Use PCB "pins" with heatshrink for off board connections, or .1"molex connectors, or .2" screw down terminals. Count your wire links, and count them again,........ and again. Very Happy
Any issues with noise immunity can be fixed with small brass sheet "Faraday cages" in a way which is actually better than most PCBs. It would be pretty rare though.
picsynth
PostPosted: Mon Dec 08, 2008 6:59 pm    Post subject: Reply with quote  Mark this post and the followings unread
I use stripboard for everything, including a replacement 24v 2amp power supply for my oscilloscope !
In PICSynth all of the boards are stripboards. You can get quite fast at doing layouts using math paper...and pencil.
The only exception I can see is if you are working at high frequencies eg Radio RF work and the capacitances between the tracks become important.
Not a porblem at Synth frequencies.
I don't bother making PC boards, I am usually pulling apart and remaking far to often for that Wink
Kevin
http://www.geocities.com/picsynth
kxspxr
PostPosted: Tue Dec 09, 2008 2:24 am    Post subject: Reply with quote  Mark this post and the followings unread
You can download DIY Layout Creator and use it on any computer that supports Java. You can use it to layout stripboards before soldering. Oh, and it's free Smile
Linux/OSX/Win:
http://www.storm-software.co.yu/diy/forums.html?project=software
MrUmunhum
PostPosted: Sun Apr 05, 2009 4:55 pm    Post subject: Dead link Reply with quote  Mark this post and the followings unread
Linux/OSX/Win:
This is a dead link. Do you have a current one for Linux?
kxspxr
PostPosted: Mon Apr 06, 2009 2:34 am    Post subject: Re: Dead link Reply with quote  Mark this post and the followings unread
No sorry. This was the place I found it. I have DIY Layout Creator (multiplatform version) since I use mac, so if your box runs java I can upload the software to my ftp (yes I saved a copy) and post the link here.
Tell me if you're interested.
-kasper
aerogramma
Audio files: 15
PostPosted: Mon Apr 06, 2009 8:01 am    Post subject: Reply with quote  Mark this post and the followings unread
I would be too Wink
thanks!
aero
MrUmunhum
PostPosted: Mon Apr 06, 2009 11:05 am    Post subject: Re: Dead link Reply with quote  Mark this post and the followings unread
-kasper
Yes please, I have been trying for days to find it. It happers that the site has lost its Domain Name?
slacker
PostPosted: Mon Apr 06, 2009 3:00 pm    Post subject: Reply with quote  Mark this post and the followings unread
He's changed the name of his website, it's now here http://diy-fever.com/forums.html?project=software
MrUmunhum
PostPosted: Tue Apr 07, 2009 9:04 am    Post subject:  Got it to run but! Reply with quote  Mark this post and the followings unread
OK, downloaded it unzipped it and ran under Java. It comes up but page is blank and no library routines ( library window is blank ).
Do I need to start it with some options? Is there a tutorial somewhere? The help references the old web site.
Sorry to be a pain. This looks like to best fic for my needs.
kxspxr
PostPosted: Wed Apr 08, 2009 4:50 pm    Post subject: Re: Got it to run but! Reply with quote  Mark this post and the followings unread
Sorry for the delay in my reply ... been soldering my pants off the past 2 weeks.
DIY Layout Creator Beta with Library --->
http://www.perlepladesyndikatet.org/temp/diylc_beta.zip
-kasper
MrUmunhum
PostPosted: Fri Apr 10, 2009 8:58 am    Post subject: I quit! Reply with quote  Mark this post and the followings unread
Sorry to be a pain. This looks like to best fit for my needs.
-kasper
Kasper,
Thanks for all of your help but I can't get it to work. I downloaded the last zip file, unzip it and ran 'java -jar DIYLC.jar' and it just when into a loop. This is the output:
$ java -jar DIYLC.jar
Component [Blank Board] successfully loaded from the file /src/DIY_Layout/PBL2/diylc_beta/library/blank-board.xml
Component [Capacitor (Axial)] successfully loaded from the file /src/DIY_Layout/PBL2/diylc_beta/library/capacitor-axial.xml
Component [Capacitor (Ceramic)] successfully loaded from the file /src/DIY_Layout/PBL2/diylc_beta/library/capacitor-ceramic.xml
Killed
I quit. Thanks again and sorry to take up your time.
Sine
PostPosted: Fri Apr 24, 2009 4:40 pm    Post subject: Re: I quit! Reply with quote  Mark this post and the followings unread
I use matrixboard for about everything I build ... except for projects where reasonable priced boards are available. ( such as MOFS and CGS boards )
Building a circuit on strip/matrix board is VERY time consuming, if I can buy a board for a few bucks I will go for it.
Personally I don't use stripboard, its way too messy for me and compact building is virtually impossible, matrix board is a bit more work but I think it gets a much better result.
Try this on strip :
Posted Image
PostPosted: Sat Apr 25, 2009 5:56 pm    Post subject: Reply with quote  Mark this post and the followings unread
in the electronotes bernie hutchins recommended just surface mounting the parts on an etched PCB, so no drilling is needed. does anybody use this method? i am just curious.
Posted Image
