 Forum index » Instruments and Equipment » Nord stage
Using the Nord Stage Ex with an external Sequencer
Page 1 of 1 [2 Posts]
Fairlight
PostPosted: Sat Apr 04, 2009 3:52 pm    Post subject: Using the Nord Stage Ex with an external Sequencer
Subject description: Big problem
Hello everybody,
I have got a midi problem with my Nord Stage Ex.
I want to use this instrument "stand alone" with an Akai MPC 500 as Sequencer and Drumcomputer. That´s my whole equipment.
I want to use the whole power of the Nord Stage by creating songs with two organs, two pianos and two synthesizerers. These six instrument should be controlled by the MPC as Sequencer.
The problem is: When I select an individuell midi-channel for each instrument, I can´t use the keyboard any more.
Even to chose an individuell channel for each panel is no solution, because I can´t use the different instruments in individuell tracks, only in some overdubs in one track.
It would be perfect, if I could (for example) play one piano live on the keyboard, while the sequencer plays the five other instruments.
Do you have a solution for this problem? Or is ist planed to add this feature in an update?
Kind regards,
Frank Hoogestraat
gearaholic
PostPosted: Thu Apr 09, 2009 10:57 am    Post subject: Reply with quote  Mark this post and the followings unread
set panel a/b midi to off
set instrument sections a/b to desired channels
set key zones to off(no zones lit) but make shure the instrument section is still lit up (on)
set piano a zone to on (no split,all three green led lit)
hope it helps
