Yusynth Minimoog Clone
Page 1 of 1 [22 Posts]
talkboxert
PostPosted: Thu Nov 27, 2008 10:52 am    Post subject: Yusynth Minimoog Clone Reply with quote  Mark this post and the followings unread
Hey There.
I ordered a minimoog filter component kit and pcb from bridechamber:
http://www.bridechamber.com/bridechamber.com/Yu%20Transistor%20PCB.html
Anyone here who built this, or can have a look?
2 questions:
1. On the parts placement schematic, that is here:
http://yusynth.net/Modular/Commun/MOOGVCF/Moogfilter-layout.jpg
you see the vertical line of four 47n capacitors.
On the PCB it actually says 22n where those are in the pic. Should I just use the 47n from the component kit and that's it?
The 3 matched transistor pairs (BC547) that lie in between have in my kit been replaced with 3 round IC's that read: LM394CH while bridechamber says on their site:
"includes 3 SSM2210 for matched pairs"
The LM394CH looks allmost the same as this:
http://media.digikey.com/photos/Analog%20Devices%20Photos/505-TO-78.jpg
Are these used instead of the SSM 2210? How do i place them exactly? (pin up or down etc)
Cheers Smile
Luka
PostPosted: Fri Nov 28, 2008 12:33 am    Post subject: Reply with quote  Mark this post and the followings unread
it says 47n on the schematic so id go with that
lm394 is ok and pin 1 (should have a dot on this corner) should be in the top left corner according of each bc547 pair
check out the datasheet if you need any more info
just google lm394 datasheet
if you look at the bc547 you will notice the lm394 is just 2 transistors and you can match the collectors/emiiters up with the board pattern
problemchild
melbourne australia
yusynth
PostPosted: Fri Nov 28, 2008 1:49 am    Post subject: Reply with quote  Mark this post and the followings unread
Question 1:
both 22nF and 47nF are correct but I have found that I got a faithfuller minimoog sounding using 47nF, therefore I'd suggest that you go for the 47nF caps.
Question 2:
Yes the LM394 are there provided as substitute for the SSM2210 which are already substitue for the BC547s.
See below the layout diagram
LM394 metal can pinout
 Filesize:  46.03 KB
 Viewed:  28945 Time(s)
 Filesize:  319.76 KB
 Viewed:  531 Time(s)
Yves
talkboxert
PostPosted: Fri Nov 28, 2008 1:04 pm    Post subject: Reply with quote  Mark this post and the followings unread
Can't be any clearer......Smile
talkboxert
PostPosted: Sat Nov 29, 2008 7:50 am    Post subject: What are these for?
Subject description: one more thing.....
I've finished placing all the components, but now these 2 are left (see pic)
Where do they go?
cheers
 Filesize:  229.41 KB
 Viewed:  502 Time(s)
yusynth
PostPosted: Sat Nov 29, 2008 8:03 am    Post subject: Reply with quote  Mark this post and the followings unread
Hi
These are inductors (a wire wound around a ferrite bead), they are provided as substitutes for the two 10 ohm resistors (R1 R2), if you check on bridechamber's site you'll see it mentioned :
R1 and R2 are replaced with ferrite beads.
Yves
Yves
talkboxert
PostPosted: Sat Nov 29, 2008 8:18 am    Post subject: thankx Reply with quote  Mark this post and the followings unread
thanks again!
LetterBeacon
PostPosted: Sat Nov 29, 2008 9:23 am    Post subject: Reply with quote  Mark this post and the followings unread
I'm hoping to build this soon, and so I'm just collecting the components together. You specify the 47nf caps to be matched to 1% - are these appropriate capacitors?
Also, on the wiring diagram it looks like the resistors all have 5% tolerance. Is that correct, or should I use ones with 1% tolerance?
Thanks a lot.
yusynth
PostPosted: Sat Nov 29, 2008 10:57 am    Post subject: Reply with quote  Mark this post and the followings unread
These caps are OK. When I say 1%, this means that you take a batch of 47nF caps and you measure them with a capacimeter, then you select those within 1%. What counts is not the accuracy with respect to 47nF but rather the closeness between the values : they don't need to be 47nF exactly , but the four caps must have the same value within 1%, that is, it can be four caps with a value of 44nF fo example.
Thanks a lot.
5% is OK.
Yves
LetterBeacon
PostPosted: Sat Nov 29, 2008 11:02 am    Post subject: Reply with quote  Mark this post and the followings unread
Great, thanks a lot!
talkboxert
PostPosted: Sun Nov 30, 2008 6:44 am    Post subject: Ferrite Beads Reply with quote  Mark this post and the followings unread
Just out of interest, why is this?
Also to make it sound more close to the original?
Funky40
G2 patch files: 5
PostPosted: Sun Nov 30, 2008 7:32 am    Post subject: Reply with quote  Mark this post and the followings unread
it is for power decoupling.
read this thread :
http://electro-music.com/forum/topic-25712.html
LetterBeacon
PostPosted: Sun Nov 30, 2008 9:43 am    Post subject: Reply with quote  Mark this post and the followings unread
Yves, just out of interest, what type of capacitor did you use in the circuit? I was going to use those polyester ones, but I've just read this:
Harry Bissell wrote:
For all frequency sensitive applications, film caps are the best choice. Polystyrene is the best, followed by polycarbonate, and polyester (Mylar). Mylar capacitors should always be avoided in Sample/Hold and VCO applications, and used with caution in VCF circuits. If the capacitance value is very small then mica or COG/NPO ceramics may be used.
yusynth
PostPosted: Sun Nov 30, 2008 10:19 am    Post subject: Reply with quote  Mark this post and the followings unread
I use polyester film capacitors for the filter.
Yves
jbeuckm
Audio files: 9
PostPosted: Sat Dec 13, 2008 1:19 am    Post subject: Self-oscillation
Subject description: can't get it :(
I have a working model built but can't achieve self oscillation even with the emphasis trimmer and pot all the way up. I have to admit that I did not know to match the 47n capacitors to each other when I picked them. Could mismatched capacitors cause weak emphasis? What else would prevent self-oscillation?
Thank you,
-joe
yusynth
PostPosted: Sat Dec 13, 2008 2:23 am    Post subject: Reply with quote  Mark this post and the followings unread
No, I think it should oscillate even with mismatched ladder caps.
OK check all the solders, swap or change the CA3046s.
Yves
numbertalk
PostPosted: Sat Dec 13, 2008 7:49 am    Post subject: Reply with quote  Mark this post and the followings unread
What voltage power supply are you using? I first tried this with 2 9V batteries, before I had a bench or cabinet power supply, and I had the same problem. I think it really needs the 15V to oscillate. If you're using a 15VDC supply maybe it's a problem with one of the soldered connections to power on that chip.
jbeuckm
Audio files: 9
PostPosted: Sat Dec 13, 2008 11:05 am    Post subject: Reply with quote  Mark this post and the followings unread
That was it! I thought I was using my 15v rack but it was 12v. It oscillates nicely on +/-15v. Nice filter. Thanks for the help.
LetterBeacon
PostPosted: Sun Jan 11, 2009 10:17 am    Post subject: Reply with quote  Mark this post and the followings unread
I can't seem to find a source for the large 10K and 1K trim pots in the UK. Can anyone point me to where I can find these online?
yusynth
PostPosted: Sun Jan 11, 2009 10:31 am    Post subject: Reply with quote  Mark this post and the followings unread
You'll find these very common components at maplin's :
http://www.maplin.co.uk/Module.aspx?ModuleNo=6499
or at Rapid electronics
http://www.rapidonline.com/Electronic-Components/Resistors-Potentiometer/Preset-Potentiometers/9mm-Cermet-skeleton-trimmer-potentiometer/61601/kw/potentiometer
Yves
LetterBeacon
PostPosted: Sun Jan 11, 2009 10:42 am    Post subject: Reply with quote  Mark this post and the followings unread
Thanks for that. I went to Maplin yesterday and bought what I thought were the ones you linked to, but it turns out I bought the smaller ones instead. Embarassed
furio
PostPosted: Fri Nov 25, 2011 3:40 pm    Post subject: Reply with quote  Mark this post and the followings unread
Tomorrow I try my new filter Very Happy
 Filesize:  463.71 KB
 Viewed:  386 Time(s)
 Filesize:  507.26 KB
 Viewed:  425 Time(s)
