 Forum index » Clavia Nord Modular » Editor programs » Nomad - NM1 Open Source Editor
NM 3.03, Nomad, Leopard -> no connection
Page 1 of 1 [2 Posts]
hanplat
PostPosted: Wed Oct 29, 2008 3:37 am    Post subject: NM 3.03, Nomad, Leopard -> no connection Reply with quote  Mark this post and the followings unread
Hello out there,
I know, this topic has been discussed times and times, but I just happen not to be able to solve my problem.
I've got a Nord Modular Rack 3.03, a Powerbook G4 with Leopard, the latest Java version and a M-Audio Firewire 410 as MIDI-Device. I tried all these Java MIDI thingies (MMJ, OSX MIDISPI and Mandolane) and only with Mandolane the M-Audio happens to appear in the preferences.
Nontheless when I try to connect to the NM I get this Error Message (no matter if I set the MIDI-Clock to internal or external):
net.sf.nmedit.jsynth.SynthException: Invalid plug MidiPlug[name=FireWire 410 (MidiIN:1),vendor=M-Audio,description=Midi IN port:1] for net.sf.nmedit.jsynth.midi.MidiPort[name='pc-out',type=TRANSMITTER,plug=MidiPlug[name=Bus 1 (MidiOUT:0),vendor=Apple Computer, Inc.,description=Midi OUT port:0]].
at net.sf.nmedit.jsynth.midi.MidiPort.setPlug(MidiPort.java:110)
at net.sf.nmedit.jsynth.nomad.forms.SynthPropertiesDialog$PortSettingsDialog.applyPortSettings(SynthPropertiesDialog.java:248)
at net.sf.nmedit.jsynth.nomad.forms.SynthPropertiesDialog$PortSettingsDialog$MyAction.run(SynthPropertiesDialog.java:223)
at java.awt.event.InvocationEvent.dispatch(InvocationEvent.java:209)
at java.awt.EventQueue.dispatchEvent(EventQueue.java:461)
at java.awt.EventDispatchThread.pumpOneEventForHierarchy(EventDispatchThread.java:269)
at java.awt.EventDispatchThread.pumpEventsForHierarchy(EventDispatchThread.java:190)
at java.awt.EventDispatchThread.pumpEventsForHierarchy(EventDispatchThread.java:180)
at java.awt.Dialog$1.run(Dialog.java:535)
at java.awt.Dialog$2.run(Dialog.java:565)
at java.security.AccessController.doPrivileged(Native Method)
at java.awt.Dialog.show(Dialog.java:563)
at java.awt.Component.show(Component.java:1302)
at java.awt.Component.setVisible(Component.java:1255)
at net.sf.nmedit.jsynth.nomad.forms.SynthObjectForm.showSettings(SynthObjectForm.java:1257)
at net.sf.nmedit.jsynth.nomad.forms.SynthObjectForm$2.actionPerformed(SynthObjectForm.java:609)
at javax.swing.AbstractButton.fireActionPerformed(AbstractButton.java:1882)
at javax.swing.AbstractButton$Handler.actionPerformed(AbstractButton.java:2202)
at javax.swing.DefaultButtonModel.fireActionPerformed(DefaultButtonModel.java:420)
at javax.swing.DefaultButtonModel.setPressed(DefaultButtonModel.java:258)
at javax.swing.plaf.basic.BasicButtonListener.mouseReleased(BasicButtonListener.java:236)
at java.awt.Component.processMouseEvent(Component.java:5602)
at javax.swing.JComponent.processMouseEvent(JComponent.java:3135)
at java.awt.Component.processEvent(Component.java:5367)
at java.awt.Container.processEvent(Container.java:2010)
at java.awt.Component.dispatchEventImpl(Component.java:4068)
at java.awt.Container.dispatchEventImpl(Container.java:2068)
at java.awt.Component.dispatchEvent(Component.java:3903)
at java.awt.LightweightDispatcher.retargetMouseEvent(Container.java:4256)
at java.awt.LightweightDispatcher.processMouseEvent(Container.java:3936)
at java.awt.LightweightDispatcher.dispatchEvent(Container.java:3866)
at java.awt.Container.dispatchEventImpl(Container.java:2054)
at java.awt.Window.dispatchEventImpl(Window.java:1801)
at java.awt.EventQueue.dispatchEvent(EventQueue.java:463)
at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:184)
at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:176)
at java.awt.EventDispatchThread.run(EventDispatchThread.java:110)
I would be really grateful, if someone could help me, as I can't stand working with the Clavia Editor anymore, as it crashes all the time.
Kindest regards and thanks a lot in advance,
Hannes
julien
PostPosted: Wed Oct 29, 2008 6:42 am    Post subject: Reply with quote  Mark this post and the followings unread
You can try to upgrade to the last Java version, if not done yet.
Can you try another midi interface ? It might help also.
