A6 as VI controller in Logic?
Page 1 of 1 [2 Posts]
rufuss sewell
PostPosted: Thu Oct 02, 2008 4:08 am    Post subject: A6 as VI controller in Logic? Reply with quote  Mark this post and the followings unread
Any clues on how to get the panel knobs to control AU instruments in Logic?
I've gone into the controller assignments in Logic and done your basic midi learn type stuff. It definitely picks up the knob I'm moving on the andy. The midi input in Logic is showing several ramps from 0 to 127. And occasionally... if the VI knob happens to be in the right place... I get a tiny amount of movement from the knob on the screen when I fully adjust the andy knob.
In the A6 I have TXMODE set to LOCMID. CC TX on. PTHRU I've tried both all and none. I've tried different settings on TXTHIN. Nothing. What's up?
husker
PostPosted: Fri Oct 03, 2008 3:24 pm    Post subject: Reply with quote  Mark this post and the followings unread
The panel knobs output 14bit NRPN (12 bits are actually used) - it sounds like Logic is picking up parts of those messages as straight 7 bit CC. Can you config Logic to look for NRPN?
