Karplus Strong
Page 1 of 1 [16 Posts]
Alexander
G2 patch files: 4
PostPosted: Thu Sep 04, 2008 5:44 am    Post subject: Karplus Strong
Subject description: ...how
Hello everyone,
I have been trying to make this:
Posted Image
..on my engine, but can't seem to get it to work. I only have internet here at school and haven't brought any patches. But please, can someone patch this up and post a working patch, so I can figure out what I did wrong.
Here's the wiki on karplus strong:
http://en.wikipedia.org/wiki/Karplus-Strong_string_synthesis
thank you.
http://husc-sound.com
Roland Kuit
G2 patch files: 127
PostPosted: Thu Sep 04, 2008 8:05 am    Post subject: Reply with quote  Mark this post and the followings unread
Hi Alexander, have a look at this one, from Robby. There are more karplus pch's here.
From Rob Hordijk(a Dutchy also:))
http://www.electro-music.com/forum/topic-5213.html
Former site admin
Audio files: 353
PostPosted: Thu Sep 04, 2008 9:32 am    Post subject: Reply with quote  Mark this post and the followings unread
Have a look at Chet's stuff and at James' stuff too (even when it is for the NM Classic).
Roland Kuit
G2 patch files: 127
PostPosted: Thu Sep 04, 2008 10:28 am    Post subject: Reply with quote  Mark this post and the followings unread
to bad that chat's pages are missing(his links)
Former site admin
Audio files: 353
PostPosted: Thu Sep 04, 2008 10:31 am    Post subject: Reply with quote  Mark this post and the followings unread
The links seem to work here, but note that not every underlined text is a link.
Tim Kleinert
G2 patch files: 236
PostPosted: Thu Sep 04, 2008 11:46 am    Post subject: Reply with quote  Mark this post and the followings unread
Here's a quick'n dirty Karplus-Strong demo.
Press the "Press!" button (duh Laughing) to trigger the noise burst going into the resonator. The resonator is just three modules -a delay line, a filter and a mixer for the feedback. That's all there is to that.
As a comparison, you can toggle between the delay-feedback-loop and the String Oscillator module which does exactly the same thing (but with the benefit of exponential tracking (which can be patched with the DIY approach also, although tuning is an issue)).
tim
KS demo.pch2
very basic Karplus-Strong demo for Alexander
 Filename:  KS demo.pch2
 Filesize:  1.32 KB
 Downloaded:  2401 Time(s)
Alexander
G2 patch files: 4
PostPosted: Fri Sep 05, 2008 5:38 am    Post subject: Reply with quote  Mark this post and the followings unread
Thank you, I am now putting everything on my usb stick and will be working with it later this weekend. Thanks to our lovely provider I am again internetless for the next few weeks.
Great for my productivity, but for the g2 I still rely on you guys.
Thanks again for the quick and useful replies!! Very Happy
Audio files: 373
PostPosted: Sat Sep 06, 2008 4:45 am    Post subject: Reply with quote  Mark this post and the followings unread
tim
What i would love would be to have some easy way of tuning this so I could play it using a keyboard. I've asked about this before, and people say "comb filter", but that's too much of a black box for me - I want to put stuff (enveloped amplifiers, wave shapers etc) inside the delay loop and see what it sounds like. Anyone know if there is an example (or if it's possible at all) for setting up some logarithm transform so that one could translate MIDI notes to part of a delay time (compensating for whatever delay is imposed by filters and other modules in the delay loop)?
I've experimented some with building translation tables using control sequencers, which is kind of fun and produces a lo-fi rough tuning, but it uses a lot of space and cycles and it would be fun to hear what it would it would sound like with a perfect tuning.
Not that all the PM patches here aren't great, I just have this constant urge to try to dive beneath this particular surface. Smile
/Stefan
Tim Kleinert
G2 patch files: 236
PostPosted: Sat Sep 06, 2008 12:31 pm    Post subject: Reply with quote  Mark this post and the followings unread
I've experimented some with building translation tables using control sequencers, which is kind of fun and produces a lo-fi rough tuning, but it uses a lot of space and cycles and it would be fun to hear what it would it would sound like with a perfect tuning./Stefan
Lin->log response from note numbers is easily generated with the NoteScaler module. Just set a slope of -6dB throughout, turn on the keyboard tracking, and patch the output (not from the internal VCA circuit)to the delay time input. I'm not at G2 now so I can't patch a quick demo for you, but try it, it is simple.
Credit for this solution goes to Rob Hordijk, who did this on the classic.
However, tuning isn't 100% accurate here either, though usable. Best thing is to add a ControlSequencer driven by the note number to the circuit in order to add fine-tune functionality. Check out Chet Singers patches. He always does it this way.
tim
Audio files: 373
PostPosted: Sat Sep 06, 2008 3:05 pm    Post subject: Reply with quote  Mark this post and the followings unread
Hmm, you mean something like this? I guess you mean the LevScaler (couldn't find anything saying -6dB on the NoteScaler)?
I get something like an expected result in some note intervals, but mostly there is just a tiny rise/drop in pitch between notes. I tried running the value through several scalers, but I can't get it right, though it's fun to play these weird tones. I got a better result in a limited interval running the note output from the keyboard through the LevScaler, but then it was backwards.
I've used the controlsequencer approach as well - though looking quickly at Chet's patches it seems he mostly uses them to fine tune comb filter pitch inputs, not pure delay times.
/Stefan
ks_demo_tuning_test.pch2
 Filename:  ks_demo_tuning_test.pch2
 Filesize:  1.44 KB
 Downloaded:  2481 Time(s)
Former site admin
Audio files: 353
PostPosted: Sat Sep 06, 2008 3:44 pm    Post subject: Reply with quote  Mark this post and the followings unread
Your patch is OK Stefan, you must just set the delay fixed time too zero (0.01m) and then tweak E4 in the LevScaler till your range is what you want. Then you can fine tune with the same method Chet is using.
Audio files: 373
PostPosted: Sat Sep 06, 2008 4:52 pm    Post subject: Reply with quote  Mark this post and the followings unread
Aha! Brilliant! Very Happy Thanks for this revelation, Tim and Jan! The LevScaler was one of those modules that I've looked at and not really thought I had a use for - now I know better.
/Stefan
Audio files: 373
PostPosted: Sat Sep 06, 2008 5:01 pm    Post subject: Reply with quote  Mark this post and the followings unread
OK, so just for reference - here is a tweaked version of Tims example patch above which plays notes from the keyboard. The notes are a bit off if you compare with another keyboard, this can be fixed with Chet's control sequencer fine tuning mentioned above, or maybe you can just fine tune all the other synths instead.
/Stefan
 Filesize:  1.45 KB
 Downloaded:  2460 Time(s)
Former site admin
Audio files: 353
PostPosted: Sat Sep 06, 2008 5:34 pm    Post subject: Reply with quote  Mark this post and the followings unread
Or maybe, as the delay loop inserts add linear time delay, you could just subtract a bit from the LevScaler output to compensate for that extra delay.
Like in attached.
ks_demo_tuning_test_bh.pch2
 Filename:  ks_demo_tuning_test_bh.pch2
 Filesize:  1.71 KB
 Downloaded:  2966 Time(s)
Tim Kleinert
G2 patch files: 236
PostPosted: Sun Sep 07, 2008 1:37 am    Post subject: Reply with quote  Mark this post and the followings unread
yeah, doh doh, I meant the LevelScaler, sorry. I don't have my stuff here (I'm writing this from a hotel lobby internet station).
Glad you figured it out.
I use this approach not only for PM stuff, but also for DIY oscillators and my granular thingies (which are based on DIY oscillators).
I tried various things in order to correct the tuning issue, but none worked. It's not like a constant linear offset or something. I think it's a calculation precision issue, as the detunings are sometimes sharp, sometimes flat, and quite randomly dispersed over the note range.
Audio files: 373
PostPosted: Sun Sep 07, 2008 1:49 am    Post subject: Reply with quote  Mark this post and the followings unread
Neat! I didn't think that would work across the whole range. Now I've got something to sink my teeth into. clown
/Stefan
