Coming up on Radio 1 at
Photos of what you've built with JH PCBs
Page 1 of 9 [215 Posts]
Goto page: 1, 2, 3, ..., 7, 8, 9 Next
jhaible
PostPosted: Sun Feb 17, 2008 3:06 pm    Post subject: Photos of what you've built with JH PCBs Reply with quote  Mark this post and the followings unread
One pleasant aspect of just selling boards, and not finished products, is that you all surprise me with so many different ways how you build your effect. I love variety Smile
If you want to show me what you've built, and be an inspiration to others, here's where you can put up your photos.
I just got the idea when I saw the latest post in the Triple Chorus thread, with a clever way to improvise standoffs for PCB mounting. And while you're also welcome to post directly in the respective threads, I thought I just start an extra thread especially for pictures. Make this thread your gallery!
JH.
jhaible
PostPosted: Sun Feb 17, 2008 3:17 pm    Post subject: Reply with quote  Mark this post and the followings unread
I guess I just start posting pictures. Smile
Sorry for the low resolution.
JH.
 Filesize:  76.45 KB
 Viewed:  1196 Time(s)
 Filesize:  123.27 KB
 Viewed:  1178 Time(s)
markusw
PostPosted: Tue Feb 19, 2008 2:47 pm    Post subject: Reply with quote  Mark this post and the followings unread
Once the Krautrock phaser PCB is populated, both the Krautrock and the Tau Pipe will be put in sloped Hammond enclosures.
Will take a while though.
However, as soon as they are done I will post pics. Smile
Regards,
Markus
yusynth
PostPosted: Tue Feb 19, 2008 3:37 pm    Post subject: Reply with quote  Mark this post and the followings unread
I built the JH-Tau-Phase and add it to my yusynth modular, here is the finished module :
 Filesize:  31.8 KB
 Viewed:  59261 Time(s)
Yves
The Alison Project
PostPosted: Wed Feb 27, 2008 6:28 pm    Post subject: Reply with quote  Mark this post and the followings unread
I will upload new photos when I get FPE panels made. The Triple Chorus will be soon but I am holding off on the Tau incase the Debounce circuit comes to life.
Here are my previous pics I posted in the Tau amd Chorus topics.
 Filesize:  84.31 KB
 Viewed:  59095 Time(s)
 Filesize:  173.38 KB
 Viewed:  1058 Time(s)
The Alison Project
www.thealisonproject.com
PostPosted: Mon Mar 03, 2008 2:18 pm    Post subject: Reply with quote  Mark this post and the followings unread
nice topic. i love these threads where one can take a look at what people built. great inspiration...
here's the wasp vcf clone, i built:
Posted Image
Posted Image
Usine Karate
PostPosted: Tue Mar 11, 2008 6:06 am    Post subject: Reply with quote  Mark this post and the followings unread
Hi, I thought I'd treat ( Wink ) you to a photo of my Frac Chorus in a temporary panel for testing, hope you like,
Usine
Paper and MDF
 Filesize:  2.95 MB
 Viewed:  1193 Time(s)
funkyfarm
PostPosted: Mon Mar 17, 2008 4:41 am    Post subject: Reply with quote  Mark this post and the followings unread
Big caps tau !
Cool
 Filesize:  597.44 KB
 Viewed:  1078 Time(s)
jhaible
PostPosted: Mon Mar 17, 2008 4:44 am    Post subject: Reply with quote  Mark this post and the followings unread
funkyfarm wrote:
Big caps tau !
Cool
Polystyrene?
JH.
funkyfarm
PostPosted: Mon Mar 17, 2008 4:50 am    Post subject: Reply with quote  Mark this post and the followings unread
surely...1% type...the last forth row is under the pcb Embarassed
alain6870
PostPosted: Mon May 05, 2008 12:10 pm    Post subject: Reply with quote  Mark this post and the followings unread
My "traditional" triple chorus in his cas (1U rack) cool.
Thank you Jürgen,
 Filesize:  612.2 KB
 Viewed:  1102 Time(s)
jhaible
PostPosted: Mon May 05, 2008 2:37 pm    Post subject: Reply with quote  Mark this post and the followings unread
Nice to see somebody else combining a wooden enclosure with a metal front panel. I did this a lot myself - it's unexpensive, and in the rack , you only see the front panel anyway.
Keep those pictures coming, of what you've built!
JH.
riku
PostPosted: Mon May 12, 2008 3:52 am    Post subject: Compact clone Reply with quote  Mark this post and the followings unread
Hi all. Here my 1U rack version of Compact clone and first post to the board.
I've added some extra features here. The manual switch is done with the same relay + CD4007 circuit as in the bypass switch. Mainly for looks of the front panel... Wink
On the back there is two extra jacks for CV IN to drive lamps with sequencers etc. (as JH mentioned over here) and CV OUT from the oscillator to use it with other gear. These are not tested yet and I think some sort of buffering (opamp as voltage follower) would be good idea to use with the CV OUT.
The sound of this phaser is awesome! Thanks for sharing this project.
 Filesize:  177.07 KB
 Viewed:  1063 Time(s)
 Filesize:  170.64 KB
 Viewed:  1071 Time(s)
jhaible
PostPosted: Mon May 12, 2008 10:58 am    Post subject: Reply with quote  Mark this post and the followings unread
Looks great.
Very clean, and you're using good potentiometers!
But tell me please: how do you fit the lamps and LDRs into 1U height?
JH.
riku
PostPosted: Wed May 14, 2008 12:27 am    Post subject: Reply with quote  Mark this post and the followings unread
jhaible wrote:
Looks great.
I cutted the lamp sockets legs so the bottom of the socket touches to PCB. This made those about 3mm shorter. Secondly the studs are the shortest ones which I founded. 40mm inner height of case height helps alot too.
I had a plan b to drill holes big enough to mount lamp sockets trough the PCB.
bridechamber
PostPosted: Fri May 23, 2008 1:17 pm    Post subject: Reply with quote  Mark this post and the followings unread
Here's a Tau Pipe Phaser built w/ a Bridechamber panel, a custom "shallow" build for a portable cabinet.
It sounds so amazing!!
Scott @ The Bridechamber
 Filesize:  535.28 KB
 Viewed:  1115 Time(s)
whomper
PostPosted: Sat Jun 07, 2008 9:57 pm    Post subject:   Reply with quote  Mark this post and the followings unread
This is my "DIY" panel for the great sounding Schulte Phaser Smile
Whomper
 Filesize:  64.79 KB
 Viewed:  1042 Time(s)
jhaible
PostPosted: Sun Jun 08, 2008 2:54 am    Post subject: Reply with quote  Mark this post and the followings unread
whomper wrote:
Whomper
Glad to see this working!
JH.
whomper
PostPosted: Sun Jun 08, 2008 4:19 am    Post subject: Reply with quote  Mark this post and the followings unread
jhaible wrote:
whomper wrote:
Whomper
JH.
Yeah, learned a lesson while building the kit; never trust a component supplier on resistor values. Always check!
I had the 2.43K labeled as such but replaced with a 243K. Spent days on this until a run a complete resistor value check of the board to find the error.
Whomper
austrohungaro
PostPosted: Sun Jul 13, 2008 5:12 am    Post subject: Two Phasers in a Box
Subject description: Finished Panel
This my Two Phasers case.
JH. 20-pole Phaser and JH. Krautrock Phaser.
I found the case on the street and removed everything (UHF video gear). I am using its mounting brackets inside to fix boards and transformer. When everything gets wired I will post a picture of panel+brackets. 20-pole Phaser is not finished yet. Krautrock Phaser has some issues (Bypass led and 3rd lightbulb not working).
I had an aluminium panel cut to substitute the original panel, and my friend (who is into DIY engraving/printing) etched for me some clouds. No names for pots, switches and jacks, because I was not yet decided on how to do it.
BTW, I found two identical cases. The second one is waiting for another project.
A case for 2 Phasers: 20-pole and Krautrock
 Filesize:  515.9 KB
 Viewed:  1027 Time(s)
jhaible
PostPosted: Sun Jul 20, 2008 4:28 pm    Post subject: Reply with quote  Mark this post and the followings unread
My 2008 Scanner Vibrato Prototype.
http://www.jhaible.heim.at/interpolating_scanner_and_scanvib/jh_scanvib_proto_1.jpg
(just finished a couple of hours ago)
JH.
austrohungaro
PostPosted: Sun Jul 27, 2008 3:39 am    Post subject: Two Phasers in a Box Reply with quote  Mark this post and the followings unread
Both Phasers are finished and working.
The case.
 Filesize:  58.91 KB
 Viewed:  57117 Time(s)
Inside the Box
 Filesize:  64.11 KB
riley smith
PostPosted: Thu Sep 04, 2008 10:56 pm    Post subject: JH Frequency Shifter
Subject description: Pic of Freq Shifter
I just finished building Jurgen's Frequency Shifter and it sounds - quiet and clean. I'm so used to hearing digital pitch shifters that I was surprised not to hear the window glitching. For small shift amounts this one can't be beat.
Very impressive design. It sounds amazing for "natural" sounds such as voice and instruments, but is also a great timbral modifier for synthesized sounds. I've always wanted a pitch shifter and I wasn't disappointed. It was a big project, but I had a lot of fun building it. Thanks Jurgen!
I had the front panel ecthed at Front Panel Express up in Seattle Washington. Nice folks and they did a great job. The panel is based on Jurgen's orginal hand drawn design with a few small mods. I'm happy with the control layout.
- Riley
 Filesize:  143.83 KB
 Viewed:  1187 Time(s)
Luka
PostPosted: Thu Sep 04, 2008 11:27 pm    Post subject: Reply with quote  Mark this post and the followings unread
hey good work
it is good to see some completed FS-1s
inspiration indeed. i dont think ill start mine till next year unfortunately
problemchild
melbourne australia
jhaible
PostPosted: Thu Sep 04, 2008 11:53 pm    Post subject: Re: JH Frequency Shifter
- Riley
This looks beautiful!
I wish I'd found the time to put mine into such an enclosure; my FS-1a prototypes are still bare PCBs mounted on a piece of plywood ...
JH.
