Tube Amp Models
Page 3 of 4 [87 Posts]
FreeElectrons
PostPosted: Fri May 02, 2008 5:02 pm    Post subject: Reply with quote  Mark this post and the followings unread
Most tubes, save for those few types with known design issues, are way more reliable than what people tend to 'remember'. Many of the tube problems back in the day were actually due to problems located elsewhere in el cheapo consumer electronics. In particular bad passive components indirectly led to premature tube failure due to massive overload. As tubes are generally fairly resilient to power overload, they will frequently last a fair while even when run wildly out of specs.
The classic problem with consumer electronics from the tube age are bad capacitors with paper insulation, and power resistors to a lesser degree. The paper in the capacitors deteriorates over time due to moisture in the air, causing a 'leaky' capacitor, and eventually indirect tube failure. Even today many people try to 'restore' old radios by buying new 'tube sets' on ePrey and elsewhere, believing that the problems are fixed by replacing the 'unreliable' tubes. Sure enough, the old radio may even play for a while, while the new set of tubes silently scream out their pain over a very short lifespan. Silly semiconductors would just have fried instantly if given the same treatment.
My daily driver FM receiver is a Grundig of Germany from 1956. When I restored it, I *did* replace one of the original tubes with another used one, though it would have worked without replacement. But all the rest, including the full class A audio output power tube are the factory original ones. Of course I replaced about 25 faulty passive components before putting the radio back into service...
It just so happens that I have another 13 of the same audio output tube as used in the above radio. The particular type, EL84 / 6BQ5, was extremely common in consumer electronics in the fifties and sixties. The type was almost exclusively used in class A audio output stages, running at full dissipation 100% of the time. All my 13 used EL84s works perfectly, as tested on my transconductance tester, which also tests for the presence of gas leaks and heater/cathode shorts/low resistance.
Operated within spec and in circuitry designed for the peculiarities of tubes, they last thousands of hours, usually much longer.
When was the last time you saw the picture tube in a TV or a computer monitor die and needing replacement?
Which leads to my next comment: If you don't have any experience with tubes, then your guitar amp simulation is in trouble IMHO. I don't believe the answer to your chosen problem lies in a few neat formulas you might find on the 'net, but more in an understanding on how tubes actually work and were (properly) used by the big manufacturers like Mullard, Philips, GEC, Telefunken, RCA, GE, Raytheon and their likes.
Frank.
Inventor
Audio files: 270
PostPosted: Fri May 02, 2008 6:15 pm    Post subject: Reply with quote  Mark this post and the followings unread
Frank.
That's very frank, Frank! But joking aside, I enjoyed your history lesson above, it's always a good read when someone entertains us with tales of yesteryear. And I think you're right, if i don't have any experience with tubes then my guitar amp simulation is in trouble... So I will get experience with tubes! I can read about them and learn different aspects of them from the web and from books. I can design and simulate them. I can continue to model them better and better also. It's a gradual learning process and I'm sure it will be enjoyable for the most part. That's the plan anyway, wish me luck!
Inventor
Audio files: 270
PostPosted: Fri May 02, 2008 6:25 pm    Post subject: Reply with quote  Mark this post and the followings unread
I also have some better news about that Fourier signal warmer thingie that I made. I had to really tweak it and track down a few glaring errors in my coding, but eventually I got it working. It produces a sinusoid as shown in the right half of the photo, ramped up to a pointy thing in the left half. You can hear the 10-second ramp three times in the audio file.
Although I do warn that there could still be something wrong here, it does look in the waveform like the signals are believable and the sound has a quality that varies in a pleasing way. So it seems OK at first glance...
Tube_FFT_Warmer.mp3
The sound of "warmth", ahhh! Or so I think, you decide!
 Filesize:  468.68 KB
 Duration: 0:30
 Viewed:  2891 Time(s)
Audacity waveform view of Fourier Signal Warmer output signal at transition of phasor from 1 to 0.
 Filesize:  14.21 KB
 Viewed:  21589 Time(s)
Inventor
Audio files: 270
PostPosted: Sun May 04, 2008 4:18 pm    Post subject: Reply with quote  Mark this post and the followings unread
Well, I'm taking a break and asking for comments. Specifically, I'd like for my next step to be expanding that signal warmer to include arbitrary music signals, warming them up in a tube-like way. Also I'd like to entertain your comments on whether this "signal warming" approach is any good.
Naturally once that is all said and done, I'll get back to really modifying the device models. I have learned more about what a pentode does and why it does it, so I can perhaps model that next. I also have some thoughts about saturation modeling so that's all good.
Just waiting for your comments and when the mood is right, or the phase of the moon, I'll get back into it for sure! Comments anyone?
Inventor
Audio files: 270
PostPosted: Mon May 05, 2008 2:53 am    Post subject: Reply with quote  Mark this post and the followings unread
I altered the tube-warming program to work on arbitrary signals and fed a guitar solo into it (from my Guitar Lab software). It does add some sound to the clean guitar signal, but honestly it sounds like the guitar is wrapped in aluminum foil which is vibrating, haha. Not so good first try so I won't bother to post the input and output files here. But do let me know what you think of the sample I provided, I'd like to get comments on that, thanks.
Former site admin
Audio files: 353
PostPosted: Mon May 05, 2008 12:48 pm    Post subject: Reply with quote  Mark this post and the followings unread
It sounds like noisy mains hum Shocked Laughing
But it's hard to make out a meaning from this sample, as it's isolated, just a single tone and there is no reference to the original sound.
When you say it does not work as intended on your guitar sounds I think that statement has more meaning than the sample you posted .. I would be interested to hear a guitar wrapped in alu-foil BTW as I've always liked to put tea spoons or bits of cardboard between the strings of a guitar.
Inventor
Audio files: 270
PostPosted: Mon May 05, 2008 1:05 pm    Post subject: Reply with quote  Mark this post and the followings unread
OK, Jan, below are the unmodified original synthesized guitar sound, plus the enhanced one. I see what you mean about the original sample being like ground noise or power supply noise. Maybe this technique is not so hot after all. Just exploring, and occasional failures are part of the picture!
Tube_Warmer_in.mp3
The "clean" guitar signal recorded from Guitar Lab.
 Filesize:  466.12 KB
 Duration: 0:30
 Viewed:  2887 Time(s)
Tube_Warmer_out.mp3
The "distorted" output signal with harmonics added.
 Filesize:  468.57 KB
 Duration: 0:30
 Viewed:  2791 Time(s)
Former site admin
Audio files: 353
PostPosted: Mon May 05, 2008 1:26 pm    Post subject: Reply with quote  Mark this post and the followings unread
The purpose of doing the experiment is to determine the nature of it's failure, as Jan Booerman used to say, except that he said it in Dutch of course.
It's not a tube warmer that I hear, and not alu-foil either, but I do like the effect!
Cooledit has a spectral noise removal tool (I think Audacity has it too), you point it to an example of noise and then it builds a filter from that to silence it. When you apply that filter to a signal in heavy reduction mode it will produce similar sounding stuff. I use that quite a lot actually.
I think it's inherent to banding the signal frequency wise?
Inventor
Audio files: 270
PostPosted: Mon May 05, 2008 1:37 pm    Post subject: Reply with quote  Mark this post and the followings unread
Well, what it's doing is making reduced-amplitude harmonic copies of each signal in a frequency bin of about 10 Hz. So it reads the frequency bin of 10 Hz and puts k*amplitude into 20 Hz, k*k*amplitude into 30 Hz and so on up to six harmonics. Then it starts again with 20 Hz as the fundamental, and repeats, etc.
I know that technique is creating multiple overlaps of signal enhancement, but it was the only way i could think to enhance a non-periodic spectrum of sound... Perhaps it needs more work.
At any rate, I've thought of how to do saturation with the tube model so I'll get to that tonight or tomorrow, but please keep the comments rolling in, I appreciate them!
DrJustice
PostPosted: Mon May 05, 2008 3:43 pm    Post subject: Reply with quote  Mark this post and the followings unread
I would not call what I hear a 'tube warmer', but I think the effect in itself is quite interesting. There's certainly nothing wrong with a bit of alu foil once in a while Very Happy
It's an interesting choice to go to the frequency domain for this. I suppose one could do a (multiple?) fundamental estimation and work from there. The repeated harmonic copies technique, and variants on the theme, could be a new effect class in itself though!
I would imagine that tube warming is better suited for time domain processing. But that is just a hunch...
DJ
Inventor
Audio files: 270
PostPosted: Mon May 05, 2008 5:54 pm    Post subject: Reply with quote  Mark this post and the followings unread
OK, so I've got two clear opinions that adding in harmonics does not appear to be a promising tube-substitute. So there must be more to it than that. No problem, I can get back on the main track of things. Next I'd like to model saturation using our existing amplifier model. We have numbers for the (not so) linear region, I can expand the sweep of input voltage to cover some saturation and make a table accordingly. Then the proper use of gains and biases will position the overdriven input signal just right on the tube's transfer function and we'll get some nice saturation. I can work with the existing two files that we were using already. Maybe tonight, maybe tomorrow, I'll do this one next...
Inventor
Audio files: 270
PostPosted: Tue May 06, 2008 8:57 am    Post subject: Reply with quote  Mark this post and the followings unread
OK, it took a lot of finagling around with gains and offsets and such, but I managed to get the model to properly simulate a saturated tube, or so I believe. Looking at the photo below, you see the tube-saturated sinusoid on the left half and the newly beginning zero-amplitude sinusoid on the right half. This waveform is exactly the shape you would expect from an overdriven tube amp, including the rounded corners at the maxima. Listening to the attached audio file will give you a feel for how it sounds. I'm happy with the results - are you?
Tube_Amp_out7.mp3
Tube Amp sound in response to overdriven sinusoid.
 Filesize:  469.79 KB
 Duration: 0:30
 Viewed:  2778 Time(s)
The tube-clipped waveform at its peak amplitude.
 Filesize:  12.75 KB
 Viewed:  21506 Time(s)
DrJustice
PostPosted: Tue May 06, 2008 10:22 am    Post subject: Reply with quote  Mark this post and the followings unread
Best so far in this thread! But, as Jan mentioned a few posts back, it is much easier to evaluate the effect with a phrase played on an instrument. Perhaps continue to use that previous sample as a refererence? If testing for authenticity, then it might even be an idea to use an actual electric guitar sample.
DJ
Inventor
Audio files: 270
PostPosted: Tue May 06, 2008 2:39 pm    Post subject: Reply with quote  Mark this post and the followings unread
OK, I did the best I could. Since I don't have an actual electric guitar sample, I used a Guitar Lab sample - the same one as before. I'll have a guitar in a few weeks so then I can test with real sound.
I had to expand the amount of saturation that was modeled before getting good results, and you'll notice from the waveform that the clipping is pronounced but I can hardly hear it, strange.
Tube_Amp_out10.mp3
The tube-model distorted output signal.
 Filesize:  469.79 KB
 Duration: 0:30
 Viewed:  2738 Time(s)
The distorted "guitar" signal.
 Filesize:  20.02 KB
 Viewed:  21493 Time(s)
PostPosted: Tue May 06, 2008 5:42 pm    Post subject: Reply with quote  Mark this post and the followings unread
did you have a ring mod and reverb on there as well? Unless it's just the original sample.
Former site admin
Audio files: 353
PostPosted: Tue May 06, 2008 6:01 pm    Post subject: Reply with quote  Mark this post and the followings unread
jk: see tube warmer in - a couple of posts above.
Think this would be a nice distortion for on an acoustics based guitar .. erm .. a real one I mean Wink
DrJustice
PostPosted: Tue May 06, 2008 7:25 pm    Post subject: Reply with quote  Mark this post and the followings unread
It is louder than the unprocessed version, which must be taken into account on auditioning. It sounds like there's a bit of compression, and there's distortion as far as I can make out. Kind of what you want then... And as noted there's the reverb; perhaps it's better to do without it?
IMO you're getting somewhere now Smile Look forward to hearing that with a guitar (and the inevitable further algorithm development!).
DJ
Inventor
Audio files: 270
PostPosted: Tue May 06, 2008 8:10 pm    Post subject: Reply with quote  Mark this post and the followings unread
Well, that's the funny thing, you all detected the ringing but it comes from the tube amp model only for some reason. I haven't used a ring modulator and the "clean" signal has no reverb or echo in it, yet you hear something sort of like this in the tube-amped signal. Oops, I forgot to mention that this song uses the above Tube_Warmer_In.mp3 file as its source file, the "clean" guitar.
So now I'm wondering if ringing is caused by tube distortion or if it is this wrap-around effect that occurs. See, the table-lookup gizmo that I'm using is imperfect. If you exceed the table values, it wraps the signal around to the other side of the output rails. So if you put in a value of 1.10, out comes -0.9 for some reason. It puts the "peaks" on the opposite rail. I had to expand the clipping zone to prevent this, and perhaps it needs even more expansion.
Well, I will play around some more and see if I can get a "tube" sound without the ringing somehow. Thanks for checking the thread and adding your comments, they are helpful.
Inventor
Audio files: 270
PostPosted: Tue May 13, 2008 4:55 am    Post subject: Reply with quote  Mark this post and the followings unread
Hi folks, just thought I'd leave a quick note to let you know I haven't dropped the tube amp model project. I've been busy doing other things, primarily making a chainmaille guitar strap and visiting with my mom and chatting online.
The ringing sound I believe is due to the coarseness of the lookup table that I'm using. It's based on line-segments, and I just have fewer than 8 or 10 segments defining the entire linear region, which makes angles and doesn't model the soft tails that transition between cutoff, linear, and saturation modes. So after thinking about it for some time, I believe I will customize that table so that there are more entries in the linear region and fewer in the cutoff and saturation regions.
That should reduce the slight ringing that people heard. In addition to that I will scale the whole thing to a wider range so that even more of an effect is produced and we can hear it better. Plus also I buy my guitar in about ten days, so we can run the model with real guitar input pretty soon. I'm *really* looking forward to that!
So, like anything else that's good, we have to be patient and we'll get there soon enough. Thanks to all who've contributed and I'll keep you posted on progress.
DrJustice
PostPosted: Tue May 13, 2008 5:57 am    Post subject: Reply with quote  Mark this post and the followings unread
Hm.... listening again I'm quite certain that there's reverb on the input sample. Either that or something which sounds exactly like it Smile
If using a lookup table, there can never be too many entries - well, it depends on the interpolation method. What order/method of interpolation are you using?
DJ
Inventor
Audio files: 270
PostPosted: Tue May 13, 2008 6:39 am    Post subject: Reply with quote  Mark this post and the followings unread
H Dr. J, I am using a ChucK feature called a GenX, specifically the Gen7 version of it. You specify a table like this:
Code:
[0.000000,
0.025000, 0.000000,
0.025000, 0.000000,
0.025000, 0.000000,
0.025000, 0.000000,
0.025000, 0.000000,
0.025000, 0.000000,
0.025000, 0.000000,
0.025000, 0.000000,
0.025000, 0.000000,
0.025000, 0.000000,
0.025000, 0.000000,
0.025000, 0.000000,
0.025000, 0.000000,
0.025000, 0.000000,
0.025000, 0.000000,
0.025000, 0.000000,
0.025000, 0.035097,
0.025000, 0.151663,
0.025000, 0.292996,
0.025000, 0.447347,
0.025000, 0.611553,
0.025000, 0.786116,
0.025000, 0.965360,
0.025000, 1.000000,
0.025000, 1.000000,
0.025000, 1.000000,
0.025000, 1.000000,
0.025000, 1.000000,
0.025000, 1.000000,
0.025000, 1.000000,
0.025000, 1.000000,
0.025000, 1.000000,
0.025000, 1.000000,
0.025000, 1.000000,
0.025000, 1.000000,
0.025000, 1.000000,
0.025000, 1.000000,
0.025000, 1.000000,
0.025000, 1.000000] => gen7.coefs;
In fact, that is the actual table from the latest code. Notice that I only have 7 data points, forming 8 line segments to describe the entire linear region. That's not very good. Plus I'm spending lots of computer resources defining duplicate little line segments in the cutoff and saturation regions, duh!
Oh, I forgot to mention: it's linear interpolation, which is also not the best.
But as we said it's a process of learning and improving. So what I plan to do next is add code to the equation solver that makes one big long line segment for the cutoff region and one for the saturation region, plus make little bitty steps in the active region. That should be much better.
You'll also notice that the table varies only from 0 to 1, that is a limitation of Gen7, which was originally intended for mapping HID sensor inputs. That's why I had to do a lot of tricky trial-and-error attempts to get the biasing and gains right. I have to do attenuation and offset on the input side, then gain and reverse offset on the output side. It's still not "just right", as you or someone observed that the output is louder than the input, but I'm getting there.
Now, if I could only make some progress on this chainmaille guitar strap, then I can get back to the tube model and do what I just said I would do. BTW, the chainmaille guitar strap is over two feet long now, and it looks wicked cool! A little heavy, but that's OK by me. Keep on truckin'!
Inventor
Audio files: 270
PostPosted: Fri May 23, 2008 2:58 pm    Post subject: Reply with quote  Mark this post and the followings unread
I now have a real guitar to play so I created an input file by slowly playing all six strings in sequence from lowest to highest, with no fingers on the fretboard (producing EADGBE notes). I also happen to have exchanged the Line 6 amp that the salesperson talked me into for the amp I wanted in the first place, which is a Fender Frontman 15G. The Fender amp has a beautiful tube amp simulation which I tried and it sounds a lot like my simulation in the output file here but perhaps better than mine.
Anyway, you can hear the effect most prominently on the first note and to varying degrees on the other notes. If you can hear a faint ticking sound and a faint breathing sound, that is my apartment somehow making the amp tick and myself breathing because the Apple eMac mic is on maximum sensitivity and it picks up everything including my thoughts (now *that* is sensitive).
I also looked at the waveform of the output signal and it sure looks tube-like to me, with soft clipping, though the soft bending occurs in only the upper 5% and lower 5% of the signal. Perhaps a pentode simulation, which is next on the list to do, would be more "bendy" at the extremes, I don't know.
So... success or not? You decide! It seems totally tubular to me, but what do I know, I'm biased. What do you think?
Tube_Amp_in12.mp3
The input file, six guitar notes: EADGBE
 Filesize:  423.26 KB
 Duration: 0:27
 Viewed:  2746 Time(s)
Tube_Amp_out12.mp3
The output file after tube simulator - best representation is the first note
 Filesize:  469.79 KB
 Duration: 0:30
 Viewed:  2683 Time(s)
DrJustice
PostPosted: Sat May 24, 2008 3:54 am    Post subject: Reply with quote  Mark this post and the followings unread
Yay! Congratulations!
Your G and B strings are tuned to G# and C. Maybe it's not tuned yet? Guitar ownership will soon get your tuning habits sharpened anyway Wink
Don't worry, tubes are biased too Smile
What do you think?
As for the exact degree of tubularity, I'll leave that to someone who really knows their references. There's certainly lots of harmonics, but probably also lots of aliasing. It does sound a bit harsh in my ears. Looking at the waveform it may seem like the clipping is somewhat brutal, and an FFT reveals quite a bit of content below the fundamental (at lest the background noises are showing up. I think that at this level of squaring off, band limiting is in order. Of course any kind of non linear function should ideally be oversampled anyway.
One test you could do is to run a slow sine oscillator sweep from 20Hz - 20kHz through the transfer function and listen for artefacts (mainly aliasing).
DJ
Former site admin
Audio files: 353
PostPosted: Sat May 24, 2008 4:09 am    Post subject: Reply with quote  Mark this post and the followings unread
http://rudhar.com/musica/tuneguit/tuneguit.htm Wink
I did like the rough distortion, sounds usable to me.
@DJ, you have good ears, I just heard something "strange" with the untreated sample.
Inventor
Audio files: 270
PostPosted: Sat May 24, 2008 4:44 am    Post subject: Reply with quote  Mark this post and the followings unread
Yes, well, I did a crude, rough and tumble tuning job with a ChucK tuner that I cooked up really quickly by taking the FFT and looking for the first harmonic, but it doesn't work very well at all! An FFT approach is not the best for a tuner, as I have learned. Perhaps I will figure out how tuners work and code that up in ChucK. After spending all I had and then some on the guitar and amp, I just couldn't get a tuner just yet. So I'll ChucK it for now.
Thanks for studying the signals that way, Dr. J! You know, I have some background noise coming from my apartment somehow. It occurred on both amplifiers, the one they sold me which was a Line 6 Spyder III, and the one I exchanged it for, which is a Fender Frontman 15G. There is a tickitty-tick sound that I recorded and attached to this post so y'all could hear it.
The ticking is not as loud as you hear in the recording, I boosted it 12 dB with Audacity, but it is quite noticeable while the guitar is not playing. I have tried shutting off every electric device I have except the refrigerator and the ticking does not subside (computer, arcade game, scope, tv, radio, clocks, printer, cell phone, lights). The Guitar Center expert suggested it could be from a neighbor with a shortwave radio, I don't know. When I unplug the guitar but leave the cable connected to the amp, the ticking gets louder and when I unplug the cable from the amp, the ticking goes away. Also with guitar plugged into amp, when I lower the guitar volume (the Strat has a volume knob), the ticking goes away. Vewwy stwange, mistwer Bugs, vewwy stwange indeed!
DJ
OK, I'll run that test sometime soon. Good Idea!
Guitar_Noise.mp3
11 seconds of the bizarre ticking noise that my amp picks up from my apartment.
 Filesize:  178.9 KB
 Duration: 0:11
 Viewed:  2701 Time(s)
