Coming up on Radio 1 at
 Forum index » Clavia Nord Modular » Editor programs » Nomad - NM1 Open Source Editor
Problems with MidiHubble and NOMAD
Page 1 of 1 [3 Posts]
m:o
PostPosted: Mon Mar 10, 2008 1:45 pm    Post subject: Problems with MidiHubble and NOMAD Reply with quote  Mark this post and the followings unread
Hi, i just want to try the NOMAD 0.3 but i can't get the connection to my Nord Modular. If i assign the needed Midi ports of my MidiHubble following message appears:
net.sf.nmedit.jsynth.SynthException: Invalid plug MidiPlug[name=MIDI HUBBLE MIDI 2,vendor=Unknown vendor,description=No details available] for net.sf.nmedit.jsynth.midi.MidiPort[name='pc-out',type=TRANSMITTER,plug=MidiPlug[name=Microsoft MIDI-Mapper,vendor=Unknown vendor,description=Windows MIDI_MAPPER]].
at net.sf.nmedit.jsynth.midi.MidiPort.setPlug(MidiPort.java:110)
at net.sf.nmedit.jsynth.nomad.forms.SynthPropertiesDialog$PortSettingsDialog.applyPortSettings(SynthPropertiesDialog.java:248)
at net.sf.nmedit.jsynth.nomad.forms.SynthPropertiesDialog$PortSettingsDialog$MyAction.run(SynthPropertiesDialog.java:223)
at java.awt.event.InvocationEvent.dispatch(Unknown Source)
at java.awt.EventQueue.dispatchEvent(Unknown Source)
at java.awt.EventDispatchThread.pumpOneEventForFilters(Unknown Source)
at java.awt.EventDispatchThread.pumpEventsForFilter(Unknown Source)
at java.awt.Dialog$1.run(Unknown Source)
at java.awt.Dialog$3.run(Unknown Source)
at java.security.AccessController.doPrivileged(Native Method)
at java.awt.Dialog.show(Unknown Source)
at java.awt.Component.show(Unknown Source)
at java.awt.Component.setVisible(Unknown Source)
at java.awt.Window.setVisible(Unknown Source)
at java.awt.Dialog.setVisible(Unknown Source)
at net.sf.nmedit.jsynth.nomad.forms.SynthObjectForm.showSettings(SynthObjectForm.java:1257)
at net.sf.nmedit.jsynth.nomad.forms.SynthObjectForm$2.actionPerformed(SynthObjectForm.java:609)
at javax.swing.AbstractButton.fireActionPerformed(Unknown Source)
at javax.swing.AbstractButton$Handler.actionPerformed(Unknown Source)
at javax.swing.DefaultButtonModel.fireActionPerformed(Unknown Source)
at javax.swing.DefaultButtonModel.setPressed(Unknown Source)
at javax.swing.plaf.basic.BasicButtonListener.mouseReleased(Unknown Source)
at java.awt.Component.processMouseEvent(Unknown Source)
at javax.swing.JComponent.processMouseEvent(Unknown Source)
at java.awt.Component.processEvent(Unknown Source)
at java.awt.Container.processEvent(Unknown Source)
at java.awt.Component.dispatchEventImpl(Unknown Source)
at java.awt.Container.dispatchEventImpl(Unknown Source)
at java.awt.Component.dispatchEvent(Unknown Source)
at java.awt.LightweightDispatcher.retargetMouseEvent(Unknown Source)
at java.awt.LightweightDispatcher.processMouseEvent(Unknown Source)
at java.awt.LightweightDispatcher.dispatchEvent(Unknown Source)
at java.awt.Window.dispatchEventImpl(Unknown Source)
at java.awt.EventDispatchThread.pumpEventsForHierarchy(Unknown Source)
at java.awt.EventDispatchThread.pumpEvents(Unknown Source)
at java.awt.EventDispatchThread.run(Unknown Source)
whats the problem here ?
thanks!
chresan
PostPosted: Mon Mar 10, 2008 2:20 pm    Post subject: Reply with quote  Mark this post and the followings unread
Hi mSurprised ,
you are the second one to have this problem (there are probably more). We will examine the problem, but it looks like a bug in the Java-JRE . Would you be so kind and post the logfile.txt which you can find in the nomad directory ?
Christian
http://nmedit.sf.net
m:o
PostPosted: Mon Mar 10, 2008 2:33 pm    Post subject: Reply with quote  Mark this post and the followings unread
chresan wrote:
Hi mSurprised ,
Christian
Hi Christian,
thanks for your fast reply. Here's the logfile. Hopefully it will get sorted out.
logfile.txt
 Filename:  logfile.txt
 Filesize:  4.64 KB
 Downloaded:  657 Time(s)
