should I sell my A6 and get a poly Rozzbox ?
Page 1 of 1 [11 Posts]
amnesia
PostPosted: Thu Feb 07, 2008 2:27 am    Post subject: should I sell my A6 and get a poly Rozzbox ? Reply with quote  Mark this post and the followings unread
It just sounds so nice
sunny pedaal
Audio files: 12
PostPosted: Thu Feb 07, 2008 9:34 am    Post subject: Reply with quote  Mark this post and the followings unread
a what?
Former site admin
Audio files: 353
PostPosted: Thu Feb 07, 2008 9:45 am    Post subject: Reply with quote  Mark this post and the followings unread
http://www.rozzbox.de/
http://www.rozzbox.de/inhalte/seite.php?item=28e
Posted Image
Audio files: 21
PostPosted: Thu Feb 07, 2008 9:49 am    Post subject: Reply with quote  Mark this post and the followings unread
Flickr
sunny pedaal
Audio files: 12
PostPosted: Fri Feb 08, 2008 2:21 am    Post subject: Reply with quote  Mark this post and the followings unread
looks a bit more like a elaborate monophonic. I personnally don't like 5voices max, a polysynth to my opinion needs 8 voices at least, otherwise it hinders in playing and i might as well go for a monophonic synth.
for the rest it looks oke, although listening would be prefered first.
might be nice for dance, don't think i would swap it for my a6 though that's always a very personal decision afcourse. after all i have also enough other synth's to use.
(hereby some spec'sSmile
The RozzBox One V2 has the following Features:
Oscillators & Signal Sources
Count: 4 OSCs plus noise, external input, and ring modulator
Octave Range: 4' to 32'
Glide: adjustable
FM: fully functional 4 operator FM engine with 7 algorithms
Waves: - Standard Waveforms: Saw, Pulse (PWM), Triangle, Wave
- 14 additional waveforms for the OSCs as factory presets
- 2 additional waveforms that can be “drawn“ with the User Interface, storable with each Patch
Sync: Hardsync possible
Other functions: Pitch Tracking of OSC1 can be disabled
Filters
Count: 2 Filters in serial connection
Tube Version only: 3 Filters in serial/parallel connections
Filter 1: - Digital high pass/low pass filter with resonance and 24dB/octave (4 filter poles)
Filter 2: - Analog lowpass ladder filter with resonance and 24dB/octave (4 filter poles)
Filter 3:
Tube Version only - Completely Tube-driven analog lowpass filter with resonance and 12B/octave (2 filter poles)
Filtertracking: individually adjustable
Filtermodes:
Tube Version only: - Digital filter, Transistor filter, serial
- Digital filter, Tube filter, serial
- Transistor filter, Tube filter, serial
- Transistor filter, Tube filter, parallel
The Tube Filter can be switched to be used on Voice 1 (local), or to be used on all Voices (global).
Misc: The two Filters selected can be modulated individually.
Low Frequency Oscillators
Count: 2
Frequency Range: Frequency ranging from very slow to very fast Smile
Waveforms: a, Sawtooth, Triangle, Square, Sample&Hold (random generator)
b, Sawtooth, Triangle and
“Wave“ plays one of the 2 user waveforms available
“Wave Tracking Generator“ using one of the 2 user Waveforms to follow the envelopes.
Envelopes
Count: 2
Parameters: Attack, Decay, Sustain, Release
Trigger Modes: single, multi
Shapes available: linear, exponential
Rozzy Modulation Sources
Audio-In: Use that feature for example to modulate the Oscillators Frequency.
Envelope Follower: Uses the Envelope of an incoming signal to generate a Modulation-Signal. (The follower has its own, independent input)
Mixer: Adds the Audio-Signals alltogether. Fine for very weird modulations Smile
Sequencers
Count: 4 independent Seqs per Voice
Internal Connections (each)
Inputs: - Clock in, routable by Trigger Matrix
- Reset in, routable by Trigger Matrix
- Start in, routable by Trigger Matrix
- Stop in, routable by Trigger Matrix
Outputs: - Continuous, routable by Modulation Matrix
- Gate out, routable by Modulation Matrix, Trigger Matrix
- Duration out, routable by Trigger Matrix
Dimension: up to 16 Steps, 1 Track
Running Modes: Forward, Backward, Bounce, Random, One Shot
Sync Modes: Step-Follow Seq 1 - 4
Clocking Options: fully selectable by Trigger Matrix, for example
- Trigger by MIDI “Note on“
- Trigger by LFO 1
- Trigger by MIDI Clock
Modulation
Fixed Modulation Paths with Attenuator:
Envelope 1 => Filter cutoff 1
Keytrack => Filter cutoff 1
Envelope 1 => Filter cutoff 2
Keytrack => Filter cutoff 2
LFO1 => Oscillator 1 PWM
LFO1 => Oscillator 2 PWM
LFO1 => Oscillator 3 PWM
LFO1 => Oscillator 4 PWM
Velocity => Envelope 2 general amount
Velocity => Envelope 1 general amount
LFO1, LFO2, ENV1, ENV2 or Velocity => Oscillator 1 Volume
LFO1, LFO2, ENV1, ENV2 or Velocity => Oscillator 2 Volume
LFO1, LFO2, ENV1, ENV2 or Velocity => Oscillator 3 Volume
Matrix connection Count: 4
Sources: ENV1, ENV2, LFO1, LFO2, Velocity, Modulation Wheel, Modulation Wheel*LFO1, Oscillator1-2, Oscillator Mix, Envelope Follower, Sequencer 1-4
Destinations: Pitch OSC 1-4, Pitch (general), Pulsewith OSC 1-2, Cutoff VCF 1, Cutoff VCF 2, Cutoff (general), Resonance VCF 1, Resonance VCF 2, LFO 1 Speed, LFO 2 Speed, MOD 1 Amount, Volume
Polarity: positive and negative (inverted)
Trigger Matrix
Connection Count: not limited
Sources: - Sequencer 1-4 Gate, Duration (8 Sources)
- Midi gate (of used Voice)
- Midi gate (General)
- Midi controller
- LFO 1
- LFO 2
- Env Follow Trigger
- MIDI Clock
- Inverted Gate
Destinations: - Sequencer 1-4 Clock, Reset, Start, Stop (16 Destinations)
- ENV1 Trigger
- ENV2 Trigger
- LFO1 Reset
- LFO2 Reset
Special Rozz-Functions
Oscillator Mode: Aliasing on/off
Output Hacker: Adds "artificial" Aliasing to the Output
Filter Mode: Clean/Chaos (chaotic behavior)
Mixer: 4 different clipping/distortion modes, intensity adjustable
Sample Rate: Full/Half
Bit Resolution: adjustable 1-16 Bit
Other Features
Multimodes:
(polyphonic Version only) - Poly operation
- Mono operation (1 voice)
- Mono operation (unisono)
- Multimode: 5
- Multimode: 1 - 4
- Multimode: 2 - 3
- Multimode: 1 - 2 - 2
- Multimode: 1 - 1 - 1 - 2
- Multimode: 1 - 1 - 1 - 1 - 1 (5 independent "monophonic Synthesizers")
Multimode Parameters:
(polyphonic Version only) - Midi Channel
- Patch
- Detune
- Note Offset
- Note Frame (specifies Range, in which the Voice reacts on incoming Note-Messages, eg. for Drum-Maps)
Patch Memory: Internal patch memory for 100 Programs, expandable via external memory jack.
Multimode Memory: Internal patch memory for 100 Multimode Configurations.
MIDI-Control: Complete MIDI-control of every parameter via Controllers & NRPNs
Additional functions: Waveform Dump
Memory Dump
OS Dump
RozzControl Support
("RozzControl" is a separate Controllerbox with extra Knobs for your RozzBox)
Mechanical Specs
Enclosure: Aluminum enclosure with maple sides
Dimensions(WxHxD): 253x90x150mm with Knobs
User Interface: 27 knobs
29 slide switches
4 Buttons for Memory and additional functions
Full Graphic OLED-Display
1 endless-turn rotary encoder for additional parameters
External Connections: Audio Input
Envelope Follower Input
Audio Outputs (Main Mix, Voice Outputs 1-5)
MIDI In
MIDI Out
Memory / Accessory
Power In (power supply is included)
bigcitymusic
PostPosted: Sat Feb 09, 2008 10:01 am    Post subject: Re: should I sell my A6 and get a poly Rozzbox ?
Subject description: Poly RozzBox
Hi Amnesia. If you are in the Los Angeles area, please come to our shop in Studio City to hear the Poly RozzBox firsthand. Bring your Andromeda. I think you will find that the RozzBox is pretty amazing.
Check out our relatively low-fi videos of the RozzBox
here on YouTube.
Peake
PostPosted: Sat Feb 09, 2008 1:32 pm    Post subject: Reply with quote  Mark this post and the followings unread
I liked an MP3 I found from the NAMM show.
Mohoyoho
PostPosted: Sat Feb 09, 2008 6:31 pm    Post subject: Reply with quote  Mark this post and the followings unread
I haven't heard any impressive demos yet; not to say there aren't any. However, I would hold on to the A6.
Mark Mahoney
Kingsport, Tennessee
www.cdbaby.com/cd/markmahoney
Peake
PostPosted: Sun Feb 10, 2008 10:36 pm    Post subject: Reply with quote  Mark this post and the followings unread
I was impressed by one demo and not another-- opinions may vary Wink
prophei
PostPosted: Sat Mar 01, 2008 11:24 pm    Post subject: Reply with quote  Mark this post and the followings unread
should you sell your andromeda for a rozzbox....?
umm. NO
not even a little bit.
amnesia
PostPosted: Mon Mar 03, 2008 1:46 am    Post subject: Reply with quote  Mark this post and the followings unread
i love the rozzbox sound its real raw..but i also love the A6 so it stays
