FS - Thermal Bonding Epoxy - unused
Lemmy
PostPosted: Wed Jan 02, 2008 3:04 pm    Post subject: FS - Thermal Bonding Epoxy - unused Reply with quote  Mark this post and the followings unread
I bought this for potting my soundlab tempcos, but after looking at the toxic warnings on it I have decided not to use it! Should be fine if used with care though.
It's product number 155-8320 on the RS Components website. You can see a datasheet there. Quick summary:
Electrolube 2 Part Thermal Bonding Epoxy
* Two part, metal oxide loaded, thermal bonding system
Can be used to bond heat sinks assemblies in "piggy back" arrangements, assembly of complex heat sink and as a bonding medium in surface mounting assemblies
Excellent electrical insulation properties
Solvent free system ensures that mated surfaces cannot come into contact, ensuring no electrical leakage through the bond
Extremely thin curing coating of approx 200 microns
Bonds a wide range of surfaces; dissimilar metals, epoxies, acrylics, polycarbonates etc.
Room temperature curing. Mix ratio 3 to 1. Usable life when mixed: 3 to 4 hours
Specific heat capacity: 0.5cal/g/°C @ 30°C resin, 0.35cal/g/°C @ 30°C hardener
Cure time: 8 to 12 hrs @Room Temp; Hard 48 hrs @Room Temp; Full Cure 45 mins @100°C
Tensile strength 2200N/cm² Resistivity 1014 – 1015 Ω/cm
I'm in the UK. Please PM me if interested.
