An Analog Synthesizer for the 21st Century
Page 5 of 5 [123 Posts]
Goto page: Previous 1, 2, 3, 4, 5
flight
PostPosted: Thu Sep 27, 2007 6:24 am    Post subject: Reply with quote  Mark this post and the followings unread
(wow, I was expecting to get flamed for that post.)
The XR2206 is listed by Exar as NLIP; the ICL8038 - while still available through NTE- is discontinued or rather pricey for very low-budget people like myself; It does appear that I got the SSM2164 confused for a CEM chip... my bad. Isn't the LM13700 on the chopping block as well? I recall (hazily) something about the disappearance of the OTAs due to the old manufacturing process and some facilities being sold off...
Out of curiosity, by how much would the parts count increase if analog synth modules were designed using only discrete and common components? And is there any good literature on this? I know (from my EE professors) that engineers are "lazy", in the sense of "why reinvent the wheel" (which I totally understand from designing my own circuits, there is a substantial investment of time in designing from scratch), but is there a good place to look that explains the functioning of a synthesis system from the discrete level?
btw: Thanks for the welcome!
~flight
fluxmonkey
PostPosted: Thu Sep 27, 2007 7:08 am    Post subject: Reply with quote  Mark this post and the followings unread
2206 is available from Jameco ($3.59), Futurlec ($4.95) or Electronic Surplus ($7.95)
13700 is available from Jameco ($1.20), Mouser ($.77) or Futurlec ($1.10)
3080 is available from futurlec ($1.90), Jameco ($3.54)
8038 is getting scarcer, but is available from Electronic surplus (now up to $6.95, after a recent run on them by SDIYers) or Futurlec ($15.95)
all those are one-off prices. that's what i found w/ just a couple minutes checking, i'm sure there are other sources for all. If you really get stuck, post to the "Wanted/For Sale - parts and components" electromusic subforum, someone here probably has an couple extra chips they'd sell you.
b
PostPosted: Thu Sep 27, 2007 7:23 am    Post subject: Reply with quote  Mark this post and the followings unread
IMO your findings show that discontinuation of an IC does not necessary mean that it get's unavailable. new industrial/commercial solutions won't utilize obsolete ICs, i guess. so i bet there are zillions of leftovers of former common ICs like OTAs which will only be required by DIYers or repair services then. maybe i am wrong here, though.
Posted Image
Scott Stites
Audio files: 97
PostPosted: Thu Sep 27, 2007 8:23 am    Post subject: Reply with quote  Mark this post and the followings unread
I got a flyer just the other day from BGMicro - 10% off the 8038 if you included a word in the order (and, no I can't remember the word! - Newsletter or something like that). Even without the discount, it's pretty decently priced at $3.95.
http://www.bgmicro.com/index.asp?PageAction=PRODSEARCH&txtSearch=8038&Page=1
I don't banana jack myself, but they do have some cool banana jack stuff there, too.
Scott
My Site
Scott Stites
Audio files: 97
PostPosted: Thu Sep 27, 2007 8:50 am    Post subject: Reply with quote  Mark this post and the followings unread
Shocked Evil or Very Mad Evil or Very Mad
Holy cow. There's only one thing left to do.....hobo drinking
I think Fonik is right - sad as it is that these chips are appearing on the bean counters' chop list, they do tend to hang out there for very long periods of time. There are chips that were discontinued long before SMT became cool that you can still find with little effort.
As for OTAs getting axed - the venerable CA3080 and the uber-OTA CA3280 were just flat knocked off - no smt versions even. It was their way of saying "you don't need OTAs anymore, period."
The LM13700 getting it - dunno, wouldn't surprise me - National is a bean counter's paradise, IMO. NJM is putting those out (as well as LM13600) , though, and they're still cheap enough.
BBDs died a complete and utter death until a few years ago when Shanghai Belling picked them up. Our last hope may lie in China....Or someone does the discrete thing, though it'll have to be SMT.
Unless of course, we turn to (A) IPOD DIY (B) Cell Phone DIY (C) HD DIY or (C) Nintendo DIY.
This is the very reason I spend zero on front panel graphics. My money goes to parts. I figure even a Wii needs some sort of panel, so they're not going away. I'll save that for when the parts are....gone.
Scott
My Site
slo
PostPosted: Thu Oct 18, 2007 7:26 am    Post subject: Reply with quote  Mark this post and the followings unread
I'm trying to decide if I should put a level control at the output of the TH 21st Century ADSR, and if so what value pot. Looking at the patch over scheme the envelope has attenuation on the VCF input but not the VCA, in fact it goes into the Linear AM input on the VCA, which confuses me a bit. Should I build ADSR's with level amounts or just run it to a passive pot type module?
Tim Servo
PostPosted: Thu Oct 18, 2007 8:58 am    Post subject: An Analog Synthesizer for the 21st Century
Subject description: ADSR output level pot
Hey there,
Generally, most modular systems feature attenuators on inputs rather than outputs. In the case of an ADSR, you'd usually run this into a VCF or VCA which will have an attenuator pot on the mod input. This allows you to dial in a different amount of ADSR mod at each destination. If you wanted to hang a pot on the output, you could probably do just fine with a 100K linear (this is what most mod inputs have anyway, so you're mimicking that structure).
Tim (mod kinda guy) Servo
loss1234
PostPosted: Fri Nov 09, 2007 7:21 am    Post subject: icl8038 versus xr8038?? Reply with quote  Mark this post and the followings unread
can i use the xr8038 instead of the 8038? cant find the 8038 anywhere cheaper than 15!!!
etaoin
PostPosted: Fri Nov 09, 2007 7:24 am    Post subject: Reply with quote  Mark this post and the followings unread
I thought there only was one 8038 and that is the XR8038.
http://www.casia.org/modular/
loss1234
PostPosted: Fri Nov 09, 2007 8:30 am    Post subject: Reply with quote  Mark this post and the followings unread
no there is the icl8038 from intersil
does th ask for the icl or the xr? i realized they have different pinouts. i dont know which one he asks for in his books but i dont want to buy the books till i KNOW i can get all the chips
thanks everyone
etaoin
PostPosted: Fri Nov 09, 2007 8:39 am    Post subject: Reply with quote  Mark this post and the followings unread
TH doesn't specify a preference for one or the other. Just "8038 function generator".
They look identical to me...
Intersil on the left, XR on the right.
8038 pinouts
 Filesize:  19.39 KB
 Viewed:  26302 Time(s)
loss1234
PostPosted: Fri Nov 09, 2007 8:41 am    Post subject: Reply with quote  Mark this post and the followings unread
thats odd
my datasheet for the xr showed pins 8-16 being wrong.
let me find the sheet
i also had read a few other pages that said it wasnt a drop in replacement.
maybe i am totally wrong on this. i hope so because it would make it easier!!
thanks
loss1234
PostPosted: Fri Nov 09, 2007 8:43 am    Post subject: Reply with quote  Mark this post and the followings unread
im going to order some
thanks alot
philpeery
PostPosted: Fri Nov 09, 2007 9:24 am    Post subject: Reply with quote  Mark this post and the followings unread
thats odd
Hmm, I would definately check the datasheet you have. My intersil chips are 14 pin devices, and my pinout data is the same as what Etaoin posted.
Hope that helps!
loss1234
PostPosted: Fri Nov 09, 2007 9:56 am    Post subject: Reply with quote  Mark this post and the followings unread
thanks
yes it does help
i must have read it wrong before i drank my coffee
thanks as usual
i posted in the wanted section so maybe someone on here can sell me a few chips
Wink
philpeery
PostPosted: Fri Nov 09, 2007 10:07 am    Post subject: Reply with quote  Mark this post and the followings unread
How many do you need? I have a dozen, and could let a few go....
loss1234
PostPosted: Fri Nov 09, 2007 10:20 am    Post subject: Reply with quote  Mark this post and the followings unread
well i only need a few. but i was hoping to get a few of each of the three (2206, 566, 8038) so i wouldn't have to acquire massive shipping charges. but maybe if you only have the one type of chip, we could meet up sometime in the city.
just a thought.
why dont we PM and figure something out.
how close do you live to NYC? i have been dying to meet someone from the list in real life to discuss synth diy.
since i have started this stuff I have NEVER actually talked to anyone regarding this stuff (at least who cared Smile my wife gets so sick of listening to my talk about my new circuits,etc)
anyway
23isgood
PostPosted: Fri Nov 09, 2007 1:56 pm    Post subject: Reply with quote  Mark this post and the followings unread
According to Thomas, the XR version is slightly better than the ICL version. They are both the same chip and should work just fine. By the way these are getting scarcer every day. I bought four of the ICL version. I would like some of the XR's too. I have lots of 3080's if anyone wants to trade.
pete
Check out my music
JargMarbin
PostPosted: Thu Oct 29, 2009 12:03 am    Post subject: can we hear one? Reply with quote  Mark this post and the followings unread
Has anyone built one of these and posted results on youtube.com or soundcloud.com so we can hear it? I'd love to know more about this.
Listen to my album free here: http://JargMarbin.com
Tim Servo
PostPosted: Thu Oct 29, 2009 12:25 pm    Post subject: Re: can we hear one? Reply with quote  Mark this post and the followings unread
Hi Jarg,
There are some samples of the XR VCO on another thread in the Thomas Henry section:
http://electro-music.com/forum/topic-34944.html
I put these together using the Magic Smoke PCB (the Magic Smoke version has extra PWM and suboctave outputs). As far as the LFO, that's a little tougher to do an audio sample of, since it doesn't make any noise by itself, but maybe someone has a sample of something they've done with it. Question
Tim (makes lots of noise) Servo
Tim Servo
PostPosted: Thu Oct 29, 2009 12:31 pm    Post subject:
Subject description: AS21C stuff at AH Nor Cal synth meet
By the way, if you live in northern California, make sure to attend the AH Nor Cal synth gathering on November 14th in Mountain View.
http://fdiskc.com/ahcali
I'll be there with modules based on all the Magic Smoke PCBs (including the 8038 based LFO and the XR VCO), and a couple of new goodies including a new prototype VCO with phase variable outputs and a new Thomas Henry DVD Smile
Tim (red carpet time) Servo
if837
PostPosted: Tue Dec 29, 2009 11:20 am    Post subject: Reply with quote  Mark this post and the followings unread
why can´t the just tell the visitors (lulu.com) what payment opions are available, without having to sign-up and go through an shoppingcart?
Do they accept paypal?
Tim Servo
PostPosted: Tue Dec 29, 2009 4:06 pm    Post subject: Reply with quote  Mark this post and the followings unread
Hi If,
Yes, the navigation is a bit confusing at times. I've seen other sites like that where they keep most purchase-related info separate in the "shopping cart" area. There must be some reason for that, but I'm not a web / business guru so I don't really know why.
To answer your question - yes, they do accept PayPal. They also accept credit and debit cards, which is one more reason I like working with them. Smile
Tim (a bit confused at times) Servo
