T/G/T/S/H boards: going ... going .......
Page 2 of 2 [41 Posts]
Goto page: Previous 1, 2
endif
PostPosted: Mon Jul 16, 2007 5:30 pm    Post subject: Reply with quote  Mark this post and the followings unread
Wow. I very much like what i see and hear.
Been looking for something like this for a while.
Are there others available?
If you make them available again, I'll take one or two of the TGTSH pcbs, and can prepay as soon as you give me a go-ahead with pricing and availability. Following this up with a PM.
~ !J!
http://www.endif.org
http://www.crunchpod.com
http://www.myspace.com/endif
frijitz
Audio files: 54
PostPosted: Mon Jul 16, 2007 5:55 pm    Post subject: Re: GONE! Reply with quote  Mark this post and the followings unread
guitarfool wrote:
Okay. Seeing as how this could probably be used as a "conventional" S&H as well, I could go for 3 of them. Rolling Eyes
Oh yes, it works just fine as a stand-alone S/H. It doesn't include a clock as many traditional designs do, but it has a low droop rate and can sample at audio rates (meaning to over 5 kHz) for some truly horrid effects. Smile
frijitz
Audio files: 54
PostPosted: Mon Jul 16, 2007 6:12 pm    Post subject: Reply with quote  Mark this post and the followings unread
There is a chaos generators (true chaos) and a radical waveshaper available. Check out my site:
Boards for the circuits below are currently available.
http://home.comcast.net/~ijfritz/ch_cir1.htm (EZChaos)
http://home.comcast.net/~ijfritz/ch_cir2.htm (Jerkster) SOLD OUT!!!
http://home.comcast.net/~ijfritz/ch_cir3.htm (TGTSH) SOLD OUT!!!
http://home.comcast.net/~ijfritz/sy_cir8.htm (5Pulser)
These are priced at $9 (US) per BOARD to cover manufacturing costs.
Please add the following per SHIPMENT for shipping/handling:
$3 (US) for US or Canadian addresses
-or-
$6 (US) for other (overseas) addresses
Please send me your shipping address and deposit funds (sorry, NO CREDIT CARD payment) into my Paypal account, which is frijitz {{at}} yahoo {{dot}} com.
Thanks for your interest.
Ian
(edited to update availability)
Edit 07/09/20: No boards are currently available.
endif
PostPosted: Mon Jul 16, 2007 10:44 pm    Post subject: Reply with quote  Mark this post and the followings unread
Done and done. Check your mail. =]
~ !J!
kryptic
PostPosted: Thu Aug 02, 2007 2:16 pm    Post subject: Reply with quote  Mark this post and the followings unread
Hi Ian, I am very interested in 2 of these boards, will there be another run soon?
krisp14u
PostPosted: Thu Sep 20, 2007 1:55 pm    Post subject: Reply with quote  Mark this post and the followings unread
I've Had one of these built for about a month now and have had alot of fun with it
I put it in its panel today and thought I should post some pics of it hear
A big thanks to Mr Fritz for coming up with such a god module
I can't wait to get the rest of the parts to do the EZ Chaos to go with it
cheers
Paul D
MOTM panel in silver
 Filesize:  80.57 KB
 Viewed:  401 Time(s)
Mounted on 1/2 a stooge bracket
 Filesize:  127.77 KB
 Viewed:  379 Time(s)
EdisonRex
Audio files: 172
PostPosted: Thu Sep 20, 2007 2:25 pm    Post subject: Reply with quote  Mark this post and the followings unread
Wow. That is a rather beefy panel, if I may say so.
It looks very well done.
Garret: It's so retro.
frijitz
Audio files: 54
PostPosted: Thu Sep 20, 2007 5:42 pm    Post subject: Reply with quote  Mark this post and the followings unread
Looks great Paul Very Happy
Thanks for putting it up.
Ian
kryptic
PostPosted: Thu Sep 20, 2007 9:35 pm    Post subject: Reply with quote  Mark this post and the followings unread
Question
mono-poly
PostPosted: Fri Sep 21, 2007 5:10 am    Post subject: Reply with quote  Mark this post and the followings unread
Yeah another run would be great
frijitz
Audio files: 54
PostPosted: Fri Sep 21, 2007 6:26 am    Post subject: Reply with quote  Mark this post and the followings unread
Question
Maybe eventually, but not soon. I sold quite a number of these boards, but so far only a couple of people have actually built them out. Rolling Eyes
I don't care about making any money selling boards, but it does take a lot of time and effort to keep track of all the orders and to do the packaging and mailing. At this point, it doesn't seem worth the effort to do another run, but I appreciate your interest, and I will revisit this question in another six months or so.
Ian
EdisonRex
Audio files: 172
PostPosted: Fri Sep 21, 2007 6:30 am    Post subject: Reply with quote  Mark this post and the followings unread
frijitz wrote:
Question
Ian
Mine is at this point only lacking 4x 5.6V zener diodes. My next delivery should have those in them, and I'll be panel mounting mine. I'll take some pictures when that happens.
andrewF
PostPosted: Tue May 26, 2009 4:48 am    Post subject: Reply with quote  Mark this post and the followings unread
Hi Ian
am in the process of building my 2nd TGTSH board and am curious about the pcb layout design.
There are a couple of sections where the tracks travel in loops around some components. I assume this is some kind of shielding against noise? Could you tell us a bit more about it? Thanks
Andrew
frijitz
Audio files: 54
PostPosted: Tue May 26, 2009 5:07 am    Post subject: Reply with quote  Mark this post and the followings unread
andrewF wrote:
Hi Ian
Andrew
Right. This is a standard "guard ring" arrangement. It's purpose is to prevent surface leakage currents from draining the holding cap. The guarded circuit is a high impedance point. The guard ring is at the same potential but at a low impedance. Since both nodes are at the same potential, no current can flow.
Ian
andrewF
PostPosted: Tue May 26, 2009 5:54 am    Post subject: Reply with quote  Mark this post and the followings unread
Thanks - thats a very interesting way of doing it.
Redline
PostPosted: Wed Oct 13, 2021 7:11 am    Post subject: Reply with quote  Mark this post and the followings unread
Sorry to necro-bump a very old post but seems the right place for it...
Does anyone have the info doc / BOM / and particularly the connection info for J2 and J3 for the 2007 rev. large format PCB?
EDIT: Ian kindly provided this, attached in case it's useful here
tgtsh_board_doc.pdf
 Filename:  tgtsh_board_doc.pdf
 Filesize:  152 KB
 Downloaded:  266 Time(s)
