Upcasting of classes?
Page 1 of 1 [11 Posts]
djdaphalgan
PostPosted: Fri Sep 07, 2007 3:03 am    Post subject: Upcasting of classes? Reply with quote  Mark this post and the followings unread
Hi, is upcasting/downcasting of classes possible? Example: I make an array of Instruments, and I put a Moog, a Flute, ect. in there. Chuck will see an Instrument if I get an element out of this array, so I can only use the methods (functions) of Instrument. If I would like to use other methods (like the once of Moog), that I have to upcast my Instrument to a Moog object (don't know for sure if upcast/dawoncast is the correct term). Is this possible in chuck?
spencer
PostPosted: Thu Sep 13, 2007 12:08 am    Post subject: Reply with quote  Mark this post and the followings unread
Hi djdaphalgan,
Yep--the $ cast operator works on objects as well as primitive types. E.g.
Code:
UGen ugens[10];
new SinOsc @=> ugens[0];
440 => ( ugens[0] $ SinOsc ).freq;
ugens[0] => dac;
1::day => now;
will do the right thing. But, uh, casting to an class that is not the object's class hierarchy can crash chuck.
spencer
djdaphalgan
PostPosted: Thu Sep 13, 2007 12:26 am    Post subject: Reply with quote  Mark this post and the followings unread
I did'nt not know the cast $ operator.
thanx for the info.
robin746
PostPosted: Wed Sep 19, 2007 4:58 am    Post subject: Reply with quote  Mark this post and the followings unread
Can you explain, for us newbies, what that code is supposed to do that couldn't be done without the cast?
kijjaz
PostPosted: Wed Sep 19, 2007 5:06 am    Post subject: Reply with quote  Mark this post and the followings unread
This is something I haven't done before also..
but it's just cool.
I once tried putting different instances of UGens in an array of UGen,
i couldn't access each UGen's individual functions and value
(because it's refered to as only a UGen, not a particular kind of UGen)
so casting like this is just the right way to work out the problem.
thanks! .. I didn't think about this at all hahah ^_^
robin746
PostPosted: Wed Sep 19, 2007 5:15 am    Post subject: Reply with quote  Mark this post and the followings unread
OK, I think I follow that. In my dabbling I had a similar problem. Unfortunately this method still doesn't solve it because different Ugens have different methods that need to be used to, say, play a note.
If I could subclass Ugens then I could create my own PlayNote method for each, which does different things depending on the parent class. Then all I would need to do, no matter which Ugen, is say PlayNote.
This seems like obvious functionality to someone from Python, but I don't think it can be done at all in ChucK.
Kassen
PostPosted: Wed Sep 19, 2007 6:55 am    Post subject: Reply with quote  Mark this post and the followings unread
No, it would be good to be able to write our own proper Ugens (or extend existing ones) and it *is* obvious functionality.
ChucK isn't "finished" yet. Personally I hope it never will be, aside from the usefulness the development itself is exciting to me.
Kassen
robin746
PostPosted: Wed Sep 19, 2007 6:59 am    Post subject: Reply with quote  Mark this post and the followings unread
I am glad that "no" means we agree. Smile
I still think maybe I'm missing things since I am so completely new to ChucK. I don't mean to be hammering on about things that are missing!
kijjaz
PostPosted: Wed Sep 19, 2007 7:15 am    Post subject: Reply with quote  Mark this post and the followings unread
Or maybe you can use another int array to store "UGen types" in the ugen array..
and use if statement to select the proper casting and note-playing method for each UGen in the UGen array.
I haven't tried this yet, but i'll work it out as one homework and post it,
if i've got more time this week ^_^
robin746
PostPosted: Wed Sep 19, 2007 7:33 am    Post subject: Reply with quote  Mark this post and the followings unread
That gets messy since there is no case statement or equivalent. (Unless I've missed that too!)
Kassen
PostPosted: Wed Sep 19, 2007 7:40 am    Post subject: Reply with quote  Mark this post and the followings unread
Well, your statement was in a negative form so I thought that was the right way to agree. Maybe this was just me applying Dutch syntax to English, this happens.
The fun thing with a occasionally buggy and incomplete language is that hammering on things you are missing is often very constructive; I do it a lot too but only because Ge inexplicitly asked for it many times. I don't think anybody said "ChucK can be buggy and is incomplete" more times then Ge did.
As long as it's friendly hammering nobody will mind, hammering is cool, constructive hammering will build one a nice house.
Kassen
