Sawtooth different from LFO to OSC ??
Page 1 of 1 [3 Posts]
gal
G2 patch files: 10
PostPosted: Sat Jun 12, 2004 10:19 am    Post subject: Sawtooth different from LFO to OSC ?? Reply with quote  Mark this post and the followings unread
Hi
Does anybody know, why the sawtooth waveform is not the same on LFO and normal Oscillators of the G2?
On Oscillators the sawtooth looks to upper right. That is the normal behaviour for an analog VCO (but the display on osc shows upper left).
On LFO it looks to upper left, which means it's inverted. Is that normal? And if it is, why?
The patch demonstrates it. Just use the switch to change the modulation source. I couldn't try the same on the old Nord Modular, just on G2.
Thanks, Gal
saw_LFO_OSC.pch2
This patch demonstrates the difference between sawtooth waveform of an LFO and an Oscillator.
 Filename:  saw_LFO_OSC.pch2
 Filesize:  1.17 KB
 Downloaded:  1764 Time(s)
Rob
G2 patch files: 109
PostPosted: Sat Jun 12, 2004 11:23 am    Post subject: Reply with quote  Mark this post and the followings unread
On the LFO it doesn't really matter as there is the invert control next to the output.
The only difference between LFO sawtooths and OSC sawtooths is that the OSCS are anti-aliased and run on four times the sample rate. There is no audible difference between a sawtooth and an inverted sawtooth, unless asymmetric distortion is applied afterwards, then it can differ a lot. But of course that is due to the asymmetry caused be the distortion and not a property of the sawtooth itself.
gal
G2 patch files: 10
PostPosted: Sat Jun 12, 2004 11:51 am    Post subject: Reply with quote  Mark this post and the followings unread
Thanks for this statement, Rob
