assigning knobs to control ext gear
Page 1 of 1 [6 Posts]
ridethefader
PostPosted: Tue Aug 21, 2007 10:49 pm    Post subject: assigning knobs to control ext gear Reply with quote  Mark this post and the followings unread
so i recently got an elektron monomachine. but the first day i had it one of the knobs broke off. i was planning on hooking the nord and the mm via midi. my question is can i assign a knob on the nord modular to control the knob on the monomachine. i tried putting an unpatched module in on my patch then assigning the knob to a midi controller and a knob on the nord. i have a list in the manual of the monomacine that has control change numbers. i tried to match that up with the number in the midi controller page in the nord modular editor but no luck. any ideas here?
Wout Blommers
Audio files: 123
G2 patch files: 12
PostPosted: Tue Aug 21, 2007 11:11 pm    Post subject: Reply with quote  Mark this post and the followings unread
It's the way to do it. I use Constant modules, assigned to Midi CC and a physical knob.
BTW the Midi is coming out via the normal MidiOut, not the Editor connection.
Wout
ridethefader
PostPosted: Tue Aug 21, 2007 11:18 pm    Post subject: Reply with quote  Mark this post and the followings unread
Wout
okay well heres another issue. the parameter i want to control is #127. the nord mod only goes to #120. is there a way to work around this?
Wout Blommers
Audio files: 123
G2 patch files: 12
PostPosted: Wed Aug 22, 2007 3:16 am    Post subject: Reply with quote  Mark this post and the followings unread
ridethefader wrote:
... is there a way to work around this?
No!
The G2 can do this (See attachment)
Wout
 Filesize:  29.95 KB
 Viewed:  5653 Time(s)
Wout Blommers
Audio files: 123
G2 patch files: 12
PostPosted: Wed Aug 22, 2007 3:20 am    Post subject: Reply with quote  Mark this post and the followings unread
WHAT!
Still no G2 bought yet? Wink
Then Jan Punter's (Blue Hell) MidiMod, if you're on a Windows machine, that is, can do the same trick using your computer.
Go to http://bluehell.electro-music.com/
and search for 'More Blue Hell...' > software > MidiMod.
Wout
 Filesize:  20.19 KB
 Viewed:  5655 Time(s)
ridethefader
PostPosted: Wed Aug 22, 2007 3:45 am    Post subject: Reply with quote  Mark this post and the followings unread
yea no g2. im on a mac. so theres always little problems like this. thanks for the replies
