 Forum index » Clavia Nord Modular » Editor programs » Nomad - NM1 Open Source Editor
The Nmedit/Nomad project needs your help.
Page 1 of 1 [13 Posts]
chresan
PostPosted: Fri Jul 13, 2007 10:28 am    Post subject: The Nmedit/Nomad project needs your help. Reply with quote  Mark this post and the followings unread
Hello everyone,
we have difficulties understanding the meaning of the midi message which identifies the nord modular synthesizer because we have not enough sample messages.
A small java application is attached to this posting which will retrieve this message from your Nord Modular Keyboard, Nord Modular Rack or Micro Modular. It would be a great help if you take a few minutes to fill out the form and post the results here.
You can start the application by either single/double click on the file IAMtest.jar or by using the terminal:
Code:
java -jar IAMtest.jar
After you retrieved the message and filled out the form post the results here. Example:
Code:
------ begin ------
device: Nord Modular Keyboard
expanded: no
serial: MA 99041015
iam: F0 33 00 06 01 03 03 00 07 77 00 F7
------ end ------
Thank you very much,
Christian
 Filesize:  11.99 KB
 Viewed:  12350 Time(s)
IAMtest.zip
 Filename:  IAMtest.zip
 Filesize:  142.81 KB
 Downloaded:  591 Time(s)
http://nmedit.sf.net
Former site admin
Audio files: 353
PostPosted: Fri Jul 13, 2007 4:37 pm    Post subject: Reply with quote  Mark this post and the followings unread
------ begin ------
expanded: yes
serial: none Shocked
iam: F0 33 00 06 01 03 03 00 02 3D 00 F7
------ end ------
really don't know what happened to the serial number plate, it's just not there ... guess it's $023d ... but it has a label on the inside saying :
OK Jonas
98-04-05
the main board is version 1.0, the expansion has version 0.2
chresan
PostPosted: Sat Jul 14, 2007 8:45 am    Post subject: Reply with quote  Mark this post and the followings unread
------ begin ------
expanded: yes
------ end ------
Just for completeness I know of two other IAm messages, here are their unknown bytes 8-11
Code:
unk1 unk2 unk3 unk4
0x00 0x0D 0x2D 0x01 (Nord Modular rack, expanded=yes)
0x00 0x27 0x6A 0x02 (Micro Modular)
I am pretty sure now that the fourth unknown byte has following meaning:
Code:
0x00 Nord Modular Keyboard
0x01 Rack
0x02 Micro
The first byte is always zero in the four sample message we have here. It could be a reserved byte.
The questions is what the meaning of the unknown bytes 2-3 is. I believe that there we can find a bit which says whether the modular is expanded or not.
Former site admin
Audio files: 353
PostPosted: Sat Jul 14, 2007 8:59 am    Post subject: Reply with quote  Mark this post and the followings unread
Ok, I removed the expansion :
------ begin ------
expanded: no
serial: <not>
------ end ------
So there is no bit for it I guess.
chresan
PostPosted: Sat Jul 14, 2007 9:23 am    Post subject: Reply with quote  Mark this post and the followings unread
Hm yes, I agree.
The serial number could have following structure
DD YYMMNNNN
DD = device identifier : MA=Modular (if not a coincidence)
YY = Year
MM = Month
NNNN = mysterious number
If you look at my serial MA 99041015 : then NNNN = 1015(dec) = 3F7(hex) ~ = 0777 (hex,0-bit inserted at bit8 according to MIDI spec)
This is the same value as the unknown bytes 2-3 in my IAM message.
Former site admin
Audio files: 353
PostPosted: Sat Jul 14, 2007 9:35 am    Post subject: Reply with quote  Mark this post and the followings unread
Too good for a coincidence Very Happy and too bad I don't have a serial number Sad
chresan
PostPosted: Sat Jul 14, 2007 9:39 am    Post subject: Reply with quote  Mark this post and the followings unread
Crying or Very sad
Former site admin
Audio files: 353
PostPosted: Sat Jul 14, 2007 10:33 am    Post subject: Reply with quote  Mark this post and the followings unread
chresan wrote:
Crying or Very sad
We could just keep bumping this until someone with a serial number feels guilty Rolling Eyes
Audio files: 373
PostPosted: Sat Jul 14, 2007 1:20 pm    Post subject: Reply with quote  Mark this post and the followings unread
Here's from mine:
------ begin ------
expanded: yes
serial: MA 99010818
iam: F0 33 00 06 01 03 03 00 06 32 00 F7
------ end ------
Smile
/Stefan
chresan
PostPosted: Sat Jul 14, 2007 1:25 pm    Post subject: Reply with quote  Mark this post and the followings unread
Thank you, perfect. So the unknown bytes 2-3 are the last four digits of the serial number:
06 32 (hex) = (332 removed 8th bit) = 0818 (dec)
chresan
PostPosted: Mon Jul 16, 2007 2:43 pm    Post subject: Reply with quote  Mark this post and the followings unread
It seems there are no more examples coming. Well, I think I know enough now. Again thanks to Antimon and especially to Jan (you are always so supportive Smile )
Christian
license
PostPosted: Sun Aug 12, 2007 9:39 am    Post subject: Reply with quote  Mark this post and the followings unread
Chresan, just in case you needed more:
------ begin ------
device: Micro Modular
expanded: no
serial: MC 99072012
iam: F0 33 00 06 01 03 03 00 0F 5C 02 F7
------ end ------
chresan
PostPosted: Sun Aug 12, 2007 10:16 am    Post subject: Reply with quote  Mark this post and the followings unread
Thanks for your help Smile
