Fritz chaos circuit
Page 3 of 12 [278 Posts]
Goto page: Previous 1, 2, 3, 4, 5, ..., 10, 11, 12 Next
frijitz
Audio files: 54
PostPosted: Sun Jul 01, 2007 1:15 pm    Post subject: Reply with quote  Mark this post and the followings unread
para wrote:
i think i must have had something else wrong if the 4.7 should have worked. i'll need to go over it some more. doing stripboards in a rush is a bad idea but i was excited to get it running and short on time. i used a 074 though, there isn't anything wrong with that is there?
Steven -- The 074 should be fine. The easiest mistakes to make are in wiring the pots, so maybe start double checking there.
Ian
para
PostPosted: Sun Jul 01, 2007 1:58 pm    Post subject: Reply with quote  Mark this post and the followings unread
thanks Ian.
steven
Narbotic
PostPosted: Sun Sep 23, 2007 3:14 am    Post subject:   Reply with quote  Mark this post and the followings unread
Question from a rookie in search of chaos:
Should I assume Op-amps are to be hooked up to +/-voltage even if it's not shown on the schematic?
Thanks, I know this question will seem silly to me in a month. Rolling Eyes
And a big thanks to Ian, this type of circuit is the reason I became interested in DIY synth in the first place.
- Collin Mel
frijitz
Audio files: 54
PostPosted: Sun Sep 23, 2007 4:54 am    Post subject: Reply with quote  Mark this post and the followings unread
Yes you should. Many of us use somewhat abbreviated schematics, so don't hesitate to ask whenever something like that is unclear to you.
Ian
caress
PostPosted: Mon Oct 08, 2007 8:33 pm    Post subject: Reply with quote  Mark this post and the followings unread
i've been checking out the jerkster and i'm wondering if anyone has any help on the subcircuit connections...? are the unused points simply not connected? (the first subcircuit +in and the 2nd/4th -in)
also, the diodes can be 1n4148's or 1n914's?
anyone have any boards for some of ian fritz's circuits? most desired would be the jerkster or dwell...
frijitz
Audio files: 54
PostPosted: Mon Oct 08, 2007 9:21 pm    Post subject: Reply with quote  Mark this post and the followings unread
Correct, no connection.
Yes, any general purpose Si switching diode.
Sorry, but the boards are sold out.
I will send you the docs for both circuits -- hopefully the connections will be clear there.
Thanks for your interest!
Ian
caress
PostPosted: Mon Oct 08, 2007 9:23 pm    Post subject: Reply with quote  Mark this post and the followings unread
thanks! i can't wait to build these!
prophei
PostPosted: Mon Oct 08, 2007 9:47 pm    Post subject: Reply with quote  Mark this post and the followings unread
any other new boards coming soon fritz? that threshold gate trigger sample hold thing i bought from you is really nice!
lots of fun and very different than my usual s&h's
frijitz
Audio files: 54
PostPosted: Tue Oct 09, 2007 3:59 am    Post subject: Reply with quote  Mark this post and the followings unread
Thanks for letting me know Exclamation I developed that specifically for use with my chaos circuits, but it is useful in other kinds of patches also.
I don't have any specific plans for doing more boards right now. It takes a lot of time to manage all the orders and to ship the boards out, and so far it doesn't seem like very many folks have done anything with the ones they bought. I'll revisit this sometime next spring.
I have a circuit that can be switched to be either a chaos generator (the hacked EZChaos circuit) or a quadrature oscillator. That could possibly be of interest. It also has a pair of bargraph displays, so you can see what's happening without a scope.
Another waveshaper might also be fun to make a board for. Maybe the SNICster or the Wavolver. I'll be thinking about this. Right now I'm pretty busy puttting a backlog of completed circuits behind panels.
Thanks for your interest Exclamation
Ian
mono-poly
PostPosted: Tue Oct 09, 2007 5:31 am    Post subject: Reply with quote  Mark this post and the followings unread
Ian we just wanna be sure that our backlog stays big enough Smile
Thaks for sharing allt his stuff!
frijitz
Audio files: 54
PostPosted: Tue Oct 09, 2007 7:18 am    Post subject: Reply with quote  Mark this post and the followings unread
Understood. I just hope the boards are still solderable by the time you get around to building on them. ROHS, you know. Laughing
Narbotic
PostPosted: Thu Oct 11, 2007 2:54 pm    Post subject: Reply with quote  Mark this post and the followings unread
Shocked
This sounds ideal for the art/synth unit I'm developing. Your work never fail s to intrigue.
I've etched and soldered a version of the EZ-Chaos, just have to rig the pots and enclosure tonight. I'll post pics upon completion.
I'm sure the boards you sent out will be brought to life soon. So many are worried that they'll miss the oppurtunity to purchase them that they buy long before they can build.
- Collin/Narbotic
- Collin Mel
iep
PostPosted: Thu Oct 18, 2007 9:22 am    Post subject: Reply with quote  Mark this post and the followings unread
I also misssed the boat when the chaos PCB's were for sale, oh well. I'm doing them on perfboard now and I'm making progress slowly but surely. Excellent circuits!
Narbotic
PostPosted: Thu Oct 18, 2007 3:53 pm    Post subject: Reply with quote  Mark this post and the followings unread
"Slow" progress here as well. My EZ-Chaos seems dead in the water but I have to admit the board I etched turned out a little to chaotic in appearance. I think I'll move straight to the Jerkster as it seems to be more of what I want anyhow.
- Collin Mel
loss1234
PostPosted: Fri Nov 30, 2007 1:29 pm    Post subject: Reply with quote  Mark this post and the followings unread
fritz-in response to someone else, you mentioned docs that went with the boards? are these online or printed? i'd love to get the docs for the chaos circuits as i am starting them on pefboard.
thanks
bearblock
PostPosted: Sat Dec 08, 2007 10:41 am    Post subject: jerkster trouble Reply with quote  Mark this post and the followings unread
finally got round to building my jerkster. unfortunately it just seems to generate DC - the level varies depending on the pot positions but it doesn't move on its own.
while assembling it there was a space on the board for one component that doesn't seem to be on the schematic... might this be related? have i missed something here?
thanks!
resistor values in my jerkster... did I do it wrong?
 Filesize:  332.38 KB
 Viewed:  573 Time(s)
frijitz
Audio files: 54
PostPosted: Sat Dec 08, 2007 12:25 pm    Post subject: Re: jerkster trouble Reply with quote  Mark this post and the followings unread
Hi bear --
I'm glad you got the time to build this. It looks like you did a nice neat job. We should be able to get this running without too much trouble.
I checked your photo directly against a working board and it all looks OK. Just to check one thing -- please make sure C1 isn't shorting against the trace that goes under it.
The extra resistor -- R29 -- is not needed to get the circuit working. It's for making a small offset adjustment that sometimes is necessary (see #3 on the docs). It's shown on the schematic directly above U3A, and on the stuffing diagram it is notated as optional. I suppose there is a chance that you have a previous version of the docs that doesn't mention R29. If so, just let me know. But don't worry about it for now.
All I can suggest right now without further details is to go over the pot wiring very carefully. Note that I have used (1) for the CW terminals (2) for the sliders and (3) for the CCW terminal. Your PS voltages are probably OK if you are getting a trace. But be sure to remember to double check them.
Meanwhile, I'll fire this board back up and give you some pot settings to get started. You will not get oscillations for all combinations of settings.
I'll be back with you later.
Ian
frijitz
Audio files: 54
PostPosted: Sat Dec 08, 2007 6:27 pm    Post subject: Reply with quote  Mark this post and the followings unread
OK, the unit should have good stable oscillations with all pots centered. Here's a photo showing the board set up like that, along with the Lissajou pattern you should get from "x" and "y"
Ian
 Filesize:  33.64 KB
 Viewed:  39615 Time(s)
chaotician
PostPosted: Sun Dec 09, 2007 2:25 am    Post subject: Reply with quote  Mark this post and the followings unread
Hi Loss, here is the page for the EZ chaos that Fritz posted on his website http://home.comcast.net/~ijfritz/ch_cir1.htm.
And here is the Jerkster http://home.comcast.net/~ijfritz/ch_cir2.htm.
I hope this is helpful,
Matte
bearblock
PostPosted: Sun Dec 09, 2007 10:23 am    Post subject: Re: jerkster trouble Reply with quote  Mark this post and the followings unread
lol well spotted Ian; of course that's exactly what it was.
Cheers! Very Happy
t
frijitz
Audio files: 54
PostPosted: Sun Dec 09, 2007 11:01 am    Post subject: Re: jerkster trouble Reply with quote  Mark this post and the followings unread
Cheers! Very Happy
t
Wow, glad it was that easy. Thanks for posting such a clear photo. So it's wiggling away?
Ian
bearblock
PostPosted: Tue Dec 11, 2007 2:52 pm    Post subject: Reply with quote  Mark this post and the followings unread
yes, yes it is.
one thing i wasn't expecting is the range of the frequency control. my lorenz attractor doesn't even have one so it's just an LFO. but it is fun to crank the jerkster up to audio rate and listen to the transitions between chaos and periodicity as you change the other constants.
in fact the rate pot seems to be generating a CV... this isn't that far from being a full-on chaotic VCO amirite? though musically i think it will see most use (by me) as a modulator. it definitely does something to a drone/texture you can't do with regular LFOs or random generators.
now i'm gonna put a triple red/green/blue LED in there to track the outputs Twisted Evil
frijitz
Audio files: 54
PostPosted: Tue Dec 11, 2007 4:23 pm    Post subject: Reply with quote  Mark this post and the followings unread
Absolutely! It was designed so you could use a standard expo converter to replace the "Rate" pot. I even put extra holes on the board for mounting a piggyback expo circuit.
Thanks for the report. This kind of info is very important to me as far as knowing how to proceed with further development.
Great idea. One chaos box I built has a pair of LED bargraph displays, which prove to be quite useful, at least to me.
Ian
EDIT: To clarify, the bargraph display mentioned above is external to the chaos circuit, and is taken directly from the National Semiconductor Data Sheet. Its purpose is to give a visible indication of the circuit output, to make it easier to use without an oscilloscope. I'm sorry if this caused any confusion.
iep
PostPosted: Wed Dec 12, 2007 1:25 pm    Post subject: Reply with quote  Mark this post and the followings unread
I got a Driven Double-Well Potential circuit up and running here, fascinating patterns! I'm enthousiastic about these implementations of chaotic models, they are simple & elegant and with lots of musical potential.
I am in the progress of building a voltage-to-OSC converter to use some of these circuits and some motion-sensors within Supercollider, using this device http://koncon.nl/ipsonlab/
frijitz
Audio files: 54
PostPosted: Wed Dec 12, 2007 2:20 pm    Post subject: Reply with quote  Mark this post and the followings unread
Wow! That's all I can say because I don't understand a bit of it.
So the signal is treated just like a sensor signal?
I'd really appreciate being kept up to date on this, especially on any audio that eventually comes out the other end.
Ian
