tranzistor as a switch
Page 1 of 1 [8 Posts]
a.b.o.z.
G2 patch files: 4
PostPosted: Mon Mar 26, 2007 3:11 am    Post subject: tranzistor as a switch Reply with quote  Mark this post and the followings unread
i'm looking for a trazistor that could act like a swithch in toys. tranzistor would be triggered by another point in same toy or different one. is this possible? what type of tranzistor am i looking? value?
Former site admin
Audio files: 353
PostPosted: Mon Mar 26, 2007 12:30 pm    Post subject: Reply with quote  Mark this post and the followings unread
This question is too hard to answer Very Happy
A transistor is not really a switch although it can be made to behave in a switch like manner under certain conditions. To come up with a circuit some things would have to be known like the characteristics of the thing setting it on and off and the characteristics of the load. It might very well be impossible to solve the problem with a single transistor.
ian-s
Audio files: 43
G2 patch files: 626
PostPosted: Mon Mar 26, 2007 1:11 pm    Post subject: Reply with quote  Mark this post and the followings unread
This might work on some things. You are a bender so why not try it and see Laughing
As best I recall, it works even without the diode.
Posted Image
Mikmo
PostPosted: Mon Mar 26, 2007 2:21 pm    Post subject: Reply with quote  Mark this post and the followings unread
You might want to try to experiment with a 4066 quad analog switc IC instead of the transistor.
You can take a look on my website here :
http://www.mikmo.dk/cbinterfacedetails.html
to see how i used it in a bend toy. I used it for triggeruing switches in a bent toy from a computer but the input to the IC could come from another source
Stay Cool
Mikael
http://www.mikmo.dk
a.b.o.z.
G2 patch files: 4
PostPosted: Mon Mar 26, 2007 2:36 pm    Post subject: Reply with quote  Mark this post and the followings unread
@ g2ian. thnx for that. ill give it a try :-/
@mikmo. i know of yours sequencer. i like it. i could also try with another pin from same toy? or even diferent toy? could i maybe connect it to 555 timer? hmh. possibilities Very Happy
a.b.o.z.
G2 patch files: 4
PostPosted: Mon Mar 26, 2007 2:40 pm    Post subject: Reply with quote  Mark this post and the followings unread
this is what i had in mind.
point 1 and 2 on toy1 are bend points. i connect them and toy bends.
can i deliver external power from another toy to this?
can this be done?
or should i go mikmo way?
 Filesize:  6.5 KB
 Viewed:  8611 Time(s)
Pehr
PostPosted: Mon Mar 26, 2007 11:38 pm    Post subject: Reply with quote  Mark this post and the followings unread
With the 4016/4066 you could also control the bend with an external gate sequencer Cool
but the transistor idea is good too, I'll try that one Smile
YouTube channel
flickr photostream
http://loxodrom.blogspot.com
a.b.o.z.
G2 patch files: 4
PostPosted: Fri Mar 30, 2007 1:56 am    Post subject: Reply with quote  Mark this post and the followings unread
here it goes: circuitmaster from getlofi beat me to it Smile
http://www.getlofi.com/?p=743
http://techhouse.brown.edu/~dmorris/projects/tutorials/transistor.switches.pdf
Smile
