jjpleeza
Posted: Wed Feb 28, 2007 7:11 am Post subject:
| torsig1967 wrote: | | jjpleeza wrote: |
Classic Vocoder
Saw Vocoder
Phase Vocoder
And where can these NM1-patches be found? |
In the NM1 patch archive. Under, Audio In > Vocoder.
Just really need the Saw & Classic |
Former site admin
Audio files: 353
torsig1967
Former site admin
Audio files: 353
Posted: Wed Feb 28, 2007 2:20 pm Post subject:
The originals are 2.10 patches, by saving them from the 3.03 editor they were converted to 3.03 (no need to use the slot trick, just load and save from 3.03 will do the trick).
Funny thing though is that the 2.10 original patches do not open in my 3.03 editor - and I see no good reason for that.
Ah well, you got it converted. |
qfingers
Posted: Wed Feb 28, 2007 2:38 pm Post subject:
| Blue Hell wrote: | The originals are 2.10 patches, by saving them from the 3.03 editor they were converted to 3.03 (no need to use the slot trick, just load and save from 3.03 will do the trick).
For 2.10 patches, I ended finding (somewhere here or on the net) a version 3.0 editor and using that for the convertion because 3.03 doesn't not seem to load 2.10 patches. I suppose adding support for 2.10 in g2ools may be a good idea but there is just not enough patches that would make it worth the time.
q |
jjpleeza
cappy2112
Joined: Dec 24, 2004 Posts: 2523 Location: San Jose, California
Posted: Wed Feb 28, 2007 6:21 pm Post subject:
| jjpleeza wrote: | You guys are absolute champions!! This has helped me out in a huge way..
There are 3 other patches I forget to add.
Pulse Vocoder
Simple Vocoder
Vocoder Lead
I've added the files, does someone mind converting these for me? I'm on OSX, and just can't get my head around using the convertor..
Jonny |
There are ~3 other OSX users here who have used the converter.
Axiom, 3phase, and hmm, who is the other one?
If you look back through the threads, you will find out how they overcame the mac problems.
Search for mac or OSX in the threads- I'm sure you'll find their posts. |
jjpleeza
Posted: Wed Feb 28, 2007 6:25 pm Post subject:
| Trust me I have several times.. I guess I'm just a retard with that kind of stuff cause I've attempted atleast 10 times. |
cappy2112
Posted: Wed Feb 28, 2007 6:27 pm Post subject:
| jjpleeza wrote: | | Trust me I have several times.. I guess I'm just a retard with that kind of stuff cause I've attempted atleast 10 times. |
Do you mean searching for a post??? |
jjpleeza
Posted: Wed Feb 28, 2007 6:30 pm Post subject:
Uh... no.
I mean using Mac Python/Convertor. I've read ALL the posts on using it with OSX. There is a separate thread related to it, but still no luck. |
cappy2112
Posted: Wed Feb 28, 2007 6:32 pm Post subject:
| jjpleeza wrote: | Uh... no.
http://electro-music.com/forum/posting.php?mode=quote&p=103188
Which version of MacPython are you using? |
jjpleeza
Posted: Wed Feb 28, 2007 6:37 pm Post subject:
2.5
I can't open the "terminal" to start off with. On my old G5 (now on intel) I got to the end of the process and then it wigged out at the last step.. Now I can't even begin the process. Not sure where the "terminal" is. |
cappy2112
Posted: Wed Feb 28, 2007 6:40 pm Post subject:
| jjpleeza wrote: | 2.5
Can you ask a co-worker or friend who has a mac?
There's got to be millions of online Mac forums- somewhere.
I'm a Windows user-with a little Linux experience. |
jjpleeza
Posted: Wed Feb 28, 2007 6:57 pm Post subject:
The only other NM1 patches I'm ever going to need are the 3 I posted before.
If someone can convert them for me I'd be mucho appreciative.
Jonny |
cappy2112
Posted: Wed Feb 28, 2007 7:03 pm Post subject:
| jjpleeza wrote: | The only other NM1 patches I'm ever going to need are the 3 I posted before.
Jonny |
It's good to know that this problem really isn't specific to g2ools, and that there is a whole universe of (non-programmer) functionality waiting for you if you could just get a cmd prompt (referred to as the Terminal) in the other posts. You might be impressed what you could do with the OSX shell- with music/midi/audio programs, for example. |
cappy2112
Posted: Wed Feb 28, 2007 7:06 pm Post subject:
Pulse Vocoder
Simple Vocoder
Vocoder Lead
Jonny |
These 3 patches failed conversion for me.
"Vocoder lead.pch"
Failed patches:
PulseVoc.pch
SimpleVocoder.pch
Vocoder lead.pch
Can't look into it now, I'm at work.
Let qfingers know- it might be a problem with g2ools. |
jjpleeza
cappy2112
cappy2112
Posted: Wed Feb 28, 2007 8:04 pm Post subject:
Pulse Vocoder
Simple Vocoder
Vocoder Lead
Jonny |
BTW- you should get into the habit of not having spaces in the filenames.
It confuses programs that accept arguments on the command line, like g2ools. Putting quotes around each of the patch names is tedious, and not necessary, if you avoid spaces. Underscores work just as easy, and are easy on the eyes too. |
jjpleeza
Posted: Wed Feb 28, 2007 8:11 pm Post subject:
Yeah sorry bout that..
None of them converted properly. They barely work... Not sure what's going wrong. |
jjpleeza
Posted: Wed Feb 28, 2007 8:18 pm Post subject:
Thanks heaps for that anyway.
I've just compared the original NM1 patch against the converted patch, and HEAPS of new modules hace been added. The only one I couldn't work out was the formant OSC, but now there's all the original modules plus Invert, Rnd Clk, Mix4, Constsw, Note Quant, Ratio, Env Follow.
Something tells me that's not quite right...
Def doesn't sound right. |
cappy2112
Posted: Wed Feb 28, 2007 8:28 pm Post subject:
| jjpleeza wrote: | Thanks heaps for that anyway.
I think that was my goof.
The first time I ran your old patches, I used *.pch.
The second time I manually put quotes around each patchname.
I *may* have copied the wrong patches.
Will try again when I get home- about 2 hours from now |
jjpleeza
Posted: Wed Feb 28, 2007 8:33 pm Post subject:
Yeah, all the original modules were there plus about 10 others..
Thanks so much for all your help today! |
BobTheDog
Posted: Wed Mar 14, 2007 12:25 am Post subject:
Hi Guys,
Does the first post have links to the most recent version?
Andy |
ian-s
Audio files: 43
G2 patch files: 626
Posted: Wed Mar 14, 2007 12:49 am Post subject:
| BobTheDog wrote: | Hi Guys,
Andy |
Yes, I believe 1.5 is the latest. |
