Whats up with this 8038 Chip?
Page 1 of 3 [53 Posts]
Goto page: 1, 2, 3 Next
Wild Zebra
PostPosted: Wed Oct 11, 2006 11:46 am    Post subject: Whats up with this 8038 Chip? Reply with quote  Mark this post and the followings unread
I'm kinda new to all these fancy specialized chips, and was thinking of ordering some for a few of these projects, like the XR2206, LM566, and I ran across this 8038. Are there any layouts for this chip? Has it been optimised Thomas Henry style? Is it worth getting? What about S&H chips like LF398/389? I have a Delton Horn book that has schems for some specialized chips, like S&H and ASDR blah blah
thanks
"your stripes are killer bro"
Coriolis
PostPosted: Wed Oct 11, 2006 11:56 am    Post subject: Reply with quote  Mark this post and the followings unread
Well, I read somewhere that the 8038 is supposed to be hopeless for 1V/oct control, but then they said that about the XR2206 Rolling Eyes (or did they? maybe I'm just exaggerating). But I've never seen it used for anything synth...
C
fluxmonkey
PostPosted: Wed Oct 11, 2006 4:51 pm    Post subject: Reply with quote  Mark this post and the followings unread
elby designs sells a circuit board for a thomas henry designed linear VCO based on the 8038. tom's usual elegance & simplicity of design, it uses one quad op-amp and a handful of other components, and is very servicable.
a few limitations of the design to be aware of:
    * response is linear, like korg and paia but unlike almost everything else which is exponential
    * it does not go low (bottoms out around 20hz), so it's not suitable as an LFO. goes up to 20k tho, using a vc sweep of 0 to +15v
    * positive cv only
i have 4 behind a dual frac panel, 2CVs with attenuators into each, makes some tasty noise with enough cross-patching.
bbob
Audio files: 25
PostPosted: Fri Oct 13, 2006 8:44 am    Post subject: Reply with quote  Mark this post and the followings unread
Its a good chip for a voltage controlled LFO (almost) that has all the common waveforms found in a subtractive synthesizer without having to wire in all the usual waveshaping circuits with discreet OP-AMPS. That is it's main benefit, a compact one chip solution. I have not seen it in precision VCO applications though.
I know the Blacet "Klank Werk" uses it for an internal voltage controlled carrier generator and it works fine in that application.
Another BETTER chip for function generation and LOW frequencies for LFO generation is the MAX038:
http://www.maxim-ic.com/quick_view2.cfm/qv_pk/1257
http://www.futurlec.com/Maxim/MAX038CPP.shtml
I have one or two in my parts bin and you may be able to find them.
Bill
piedwagtail
PostPosted: Fri Oct 13, 2006 12:16 pm    Post subject: Reply with quote  Mark this post and the followings unread
I'm getting well below 20Hz....
its my TH 3 wave lfo unit.
It doesn't go much below 0.2Hz though and ranges up to 200Hz or so.
Robert
Audio files: 25
PostPosted: Fri Oct 13, 2006 12:23 pm    Post subject: Reply with quote  Mark this post and the followings unread
Linear like PAIA Question My PAIA VCO design has an exponential response. Which PAIA are you referring to Question
Thanks,
Bill
Audio files: 25
PostPosted: Fri Oct 13, 2006 12:28 pm    Post subject: Reply with quote  Mark this post and the followings unread
A 5 second period is good for most applications though Very Happy It did not occur to me that the 8038 went that low. I know you can make it go well above 200 HZ Very Happy
Bill
fluxmonkey
PostPosted: Sun Oct 15, 2006 8:52 am    Post subject: Reply with quote  Mark this post and the followings unread
Robert
are you gettng that out of the t. henry circuit? what value do you have for the timing cap? i'm using his suggested 500pf. didn't mean to suggest the chip was incapable of lfo, i was referring specifically to tom's circuit.
Thanks,
Bill
fatman, and 2700/4700 series... i know, i'm dating myself...
bbob
Audio files: 25
PostPosted: Sun Oct 15, 2006 7:58 pm    Post subject: Reply with quote  Mark this post and the followings unread
Ahh, OK Very Happy Thats fine, with age, there is wisdom Wink
Bill
piedwagtail
PostPosted: Mon Oct 16, 2006 9:53 am    Post subject: Reply with quote  Mark this post and the followings unread
0.22uF Mr. Green
no problem,just another great adaptable TH circuit!
Robert
mediatechnology
PostPosted: Thu Jan 25, 2007 3:14 pm    Post subject: Reply with quote  Mark this post and the followings unread
I happened to stumble upon this today while going through an old file. It's a 1975 Electronic Design cite with op amp linearization of an 8038. It would obviously need, in some apps, expo scaling but might make a simple LFO. I'm pretty sure I used this technique once in a sweep generator.
www.ka-electronics.com/images/Electro-Music/VCO_8038_ED30175.pdf
IIRC 8038s are still pretty easy to get. I think I see them at Jameco.
Audio files: 25
PostPosted: Thu Jan 25, 2007 4:01 pm    Post subject: Reply with quote  Mark this post and the followings unread
Yes Wayne, and probably some temperature compensation as I am not sure how much this IC will drift Very Happy
mediatechnology
PostPosted: Thu Jan 25, 2007 5:18 pm    Post subject: Reply with quote  Mark this post and the followings unread
Yes 250 ppm/C (max) in the lowest grade for the 8038.
EDIT: The XR2206 in commercial specifies a typical number of +/-20ppm/C but no maximum figure. The MIL version is +/-50ppm max so I would think the commercial 2206 would have a significantly worse-case figure. It might approach the 8038's 250ppm/C.
A linearized 8038 might still be a good candidate for an LFO.
Eric G
PostPosted: Thu Mar 08, 2007 1:12 am    Post subject: Reply with quote  Mark this post and the followings unread
Hi, I'm Eric G and new to this forum (but not new in DIY)
The 8038 and 2206 are OK as modulation generators (LF or audio) or oscillators for crazy sounds, but don't spend time to make them track musically. Neither linear nor exponential (via expo converter). I tried that for months, it really doesn't work.
Coriolis
PostPosted: Thu Mar 08, 2007 2:14 am    Post subject: Reply with quote  Mark this post and the followings unread
Hi Eric and welcome!
You need to check this out...
http://mypeoplepc.com/members/scottnoanh/birthofasynth/id20.html
Cool
C
bugbrand
PostPosted: Thu Mar 08, 2007 2:39 am    Post subject: Reply with quote  Mark this post and the followings unread
Coriolis speaks the truth!
If you see the Youtube Vid of my new stylus keyboard that's it controlling two of these XR2206 VCOs - tracking is pretty good (considering I've only roughly tuned these oscs and I didn't implement the temp-compensation).
I'm a BIG(BUG) fan of the Thomas Henry XRVCO!
http://www.bugbrand.co.uk
synth_ollie
PostPosted: Thu Mar 08, 2007 3:20 am    Post subject: Reply with quote  Mark this post and the followings unread
Im building one (bugbrands pcb layput) right now ! Smile
Eric G
PostPosted: Thu Mar 08, 2007 5:09 am    Post subject: Reply with quote  Mark this post and the followings unread
C
Yep, I've seen this one. I don't know anything about it, so maybe I'm wrong. The design is pretty much like what I did.
Scott Stites
Audio files: 97
PostPosted: Thu Mar 08, 2007 7:24 am    Post subject: Reply with quote  Mark this post and the followings unread
Eric,
welcome
Are you the Eric G of the EH-30 modular? If so, you must realize, you are partially to blame for my getting back into Synth DIY after a ten year or so hiatus - I think it was your page and Ray's that inspired me to get back into it. Very Happy
Nice to see you here!
Scott
Scott Stites
Audio files: 97
PostPosted: Thu Mar 08, 2007 10:17 am    Post subject: Reply with quote  Mark this post and the followings unread
Regarding my EHS-30 site
I guess that answers that question Very Happy
Scott
Eric G
PostPosted: Fri Mar 09, 2007 12:23 am    Post subject: Reply with quote  Mark this post and the followings unread
Scott Stites wrote:
Eric,
Scott
Great! Nice to hear that it did some good. The EHS-30 site will be up'n'running in a couple of months.
iorobyy
PostPosted: Fri Mar 09, 2007 1:48 am    Post subject: Reply with quote  Mark this post and the followings unread
8038 is a good misunderstood circuit.
It have linear response but the problem is that is a inverted linerar
response Shocked ...not gooood!
The elby circuit is a good point for to start some experiment with a cv driver circuit....uhmmmm....antilog cv driver i think? right?
However the guru thomas henry some time ago made a good vco using 8038.
But response was always linear....is a perfect vclfo! but.... is not the 1V/oct VCO that we like.
Elby use very similar schematic (so linear response again).
However i know that Thomas was studying for 1V/octvize this chip.
Like the xr2206VCO....great!!
So guys.......Thomas go! go! go! Wink
Thomas Henry
PostPosted: Sat Apr 07, 2007 12:08 pm    Post subject: Reply with quote  Mark this post and the followings unread
Try this on for size. This is something I came up with in a book I wrote three years ago but haven't published yet. I used the AD821 because I had one, but feel free to try another matched pair.
This is for Forum users to play with only. Obviously, don't do anything commercial with it without permission, and please don't Web-publish this anywhere, but provide links back to this message.
Note the unusual power supply connections.
Thomas Henry
 Filesize:  39.56 KB
 Viewed:  31721 Time(s)
 Filesize:  41.64 KB
 Viewed:  31658 Time(s)
goodrevdoc
PostPosted: Sat Apr 07, 2007 12:29 pm    Post subject: Reply with quote  Mark this post and the followings unread
Wow! Shocked Mr. Henry strikes again! Very cool, unfortunately I recently got rid of my two 8038's as i didn't see myself using them. I'll have to get some more and try them out.
-justin
iorobyy
PostPosted: Sat Apr 07, 2007 2:49 pm    Post subject: Reply with quote  Mark this post and the followings unread
Great!!!!! Thomas you're my only Guru!!! Wink
I'm going to search a 8038 in my chips cemetary.
Uhmmmm...2sa798 transistor pair could be ok?
