 Forum index » Instruments and Equipment » Soft synths
Need help with Dynamo in OS9!!!!!
Page 1 of 1 [6 Posts]
Gothboy
PostPosted: Fri Aug 11, 2006 3:53 pm    Post subject: Need help with Dynamo in OS9!!!!! Reply with quote  Mark this post and the followings unread
I can't get any help from the digi or NI forums so I though you guys from electro might be able to help.
I'm using a 001 and PT LE in OS9.2.2 with NI Dynamo 001 edition softsynth using Directconnect. Everything is set up correctly and installed right as far as I can tell. Frustratingly, I can't hear any sound from the synth. Here's a description of how I set it up:
- In OMS, create an IAC bus for Dynamo (i.e. "Dynamo IAC bus"): In Pro Tools: Setups > OMS Studio Setup. (If it says “Please Find OMS: Desktop > Mac HardDrive > Opcode Folder > OMS Applications > OMS Setups.) Double-click in the IAC Driver. In the field there type in" Dynamo IAC bus".
- In Pro Tools > MIDI Menu > Input Devices > Enable the "Dynamo IAC bus".
- In your Pro Tools session create a MIDI track (File Menu > New Track). Assign the "Dynamo IAC bus" as its output.
- Create a Stereo Aux Input Track (File Menu > New Track). In the Mix Window on the Aux Input channel strip, instantiate the Dynamo plug-in and select the stereo link "Dynamo 1L/2R". In addition, choose any unused input (or pair of inputs) for the Aux IntputTrack.
- Launch Dynamo.In Dynamo: Menu System > Audio Port > DAE/TDM Direct Connect window. Menu System and MIDI settings…: Select MIDI system in the pop up menu: OMS.
I've got the Dynamo Geek FX looping a midi file and the midi in/out lights on it are flashing. The Aux. stereo track meters are going so it's playing.......I just can't HEAR it!
I thought that I haven't got it setup right in OMS.....so while I go back and read about directconnect 1.1, any help would be great! Rolling Eyes
Apple Mac Pro 2019 3.2 GHz 16-Core Intel Xeon W
96 GB Ram
15.6 Sequoia
Novation SL49, Behringer 2600, Crave, Edge
Mophox4, Nord Lead 2,Modal electronics Argon 8m, Roland System 1, Novation Nova, Nord Micro modular, Korg Radias, Roland d-05, Yamaha A3000 sampler, Novation SL MK2 and Remote Zero controllers, Arturia Beatstep and SparkLE, Korg ER-1, Unosynth
"We are the music makers and we are the dreamers of dreams"
Dymaxion Vehicle Music at www.dymaxionvehicle.com/
Gothboy
PostPosted: Mon Aug 14, 2006 2:33 pm    Post subject: Reply with quote  Mark this post and the followings unread
I followed the Digidesign Directconnect 1.1 instructions on how to use DC with Tokyos' Koblo synth which I just happened to have a Demo of.....and it works just fine. I can trigger a note from the piano roll on the MIDI track.
Then I substituted Dynamo for Koblo and was able to have Dynamo play MIDI files through DC in Pro Tools......so I could finally hear it! I just can't trigger MIDI notes to Dynamo from the PT MIDI track and it seems to me because in the Dynamo MIDI OMS setup I can't select Dynamo as an in port as well as an out port......each time I do it crashes the computer. Is it because I need to have a MIDI controller as the in port and Dynamo as the out port? Tokyo has a MIDI setup in Options that enables you to setup Tokyo as a DOC bus and it works. Dynamo is different but it's confusing as to why I can't midi trigger a note. Can anyone help here?
96 GB Ram
15.6 Sequoia
Gothboy
PostPosted: Mon Sep 04, 2006 5:05 pm    Post subject: Reply with quote  Mark this post and the followings unread
C'mon.....somebody besides me, eh? Rolling Eyes
96 GB Ram
15.6 Sequoia
Gothboy
PostPosted: Tue Jan 23, 2007 4:22 pm    Post subject: Reply with quote  Mark this post and the followings unread
I figured this one out too......a long time ago......so I'm just answering all my old posts that wen't soooo unanswered. Confused Is this place populated by anyone?
96 GB Ram
15.6 Sequoia
Former site admin
Audio files: 353
PostPosted: Tue Jan 23, 2007 4:24 pm    Post subject: Reply with quote  Mark this post and the followings unread
You figured out quite a lot during your absence, seems well spent time Very Happy
Gothboy
PostPosted: Wed Jan 24, 2007 6:43 am    Post subject: Reply with quote  Mark this post and the followings unread
been through softsynth hell and back. Wink .........well, it wasn't that bad actually. Cool I think I understand them now, yeah.
96 GB Ram
15.6 Sequoia
