Jupiter Storm & Galilean Moons
Page 1 of 1 [7 Posts]
Audio files: 163
PostPosted: Sat Dec 12, 2015 4:40 am    Post subject: Jupiter Storm & Galilean Moons
Subject description: ....... In Blue
Hi there.
I have been working on the panel layout for these 2 diy pcbs, that I ordered from Hex a while ago. Rather than have two separate single modules I have decided on a double size panel (200m wide by 250mm high).
When I finished the controls layout on corel draw, there was a space free under the Jupiter Storm sockets, I have wanted to use the midi to 8 triggers Elby pcb that came out the old version 1 yellow drum synth (new drum synth has a midi to 24 triggers pcb) and it fitted the space perfect Smile .
Some build pics of the project so far ......
 Filesize:  599.05 KB
 Viewed:  452 Time(s)
 Filesize:  439.08 KB
 Viewed:  458 Time(s)
 Filesize:  531.79 KB
 Viewed:  457 Time(s)
Audio files: 163
PostPosted: Sat Dec 12, 2015 4:52 am    Post subject: Reply with quote  Mark this post and the followings unread
Panel layout for Hexinverter Jupiter Storm & Galilean Moons & Elby midi to 8 triggers.
 Filesize:  1.11 MB
 Viewed:  482 Time(s)
Audio files: 163
PostPosted: Sat Dec 12, 2015 5:14 am    Post subject: Reply with quote  Mark this post and the followings unread
Moons Vca's ....
I wanted an extra cv input for each vca amplitude control, there is 1 input on the pcb for each Vca, so I got the multimeter out , set to continuity beep and I traced vca numbers 1 and 2 cv inputs through inter connects & via holes back to a respective 100K resistor for each input , then simply hook n solder another 100K on the opposite leg from the traced continuity path leg.
Soon be ready to test / calibrate the Jp Storm & moons section , the elby midi to 8 triggers is still to transplant onto the panel after I have the main two going.
Dave Smile
 Filesize:  422.66 KB
 Viewed:  467 Time(s)
Audio files: 163
PostPosted: Sun Dec 13, 2015 10:30 am    Post subject: Reply with quote  Mark this post and the followings unread
Hi again Smile .
Been soldering yesterday & today , got the Elby midi to SdS 8 trigger pcb mounted & wired in , tested & set up .
Last back end pic before finish & calibration.
 Filesize:  592.9 KB
 Viewed:  475 Time(s)
Audio files: 163
PostPosted: Sun Dec 13, 2015 11:29 am    Post subject: Reply with quote  Mark this post and the followings unread
Finished & calibrated, Yay Smile
zero problems building this one all work a treat , the Jupiter storm is making different styles of crazy noise / the AR/VCA's are set up now and working great & the midi to sds 8 trigger is firing on all the white keys C1 to C2 on my korg X5 by midi cable.
I have the expansion ports on both Jp Storm & Moons connected, this normalises via switching jack , main noise to VCA 2 & Xor noise to VCA 1 when nothing is plugged in to the audio inputs.
A pic of the front after calibrating.....
I will get some demo sounds up in a few days Smile
 Filesize:  404.08 KB
 Viewed:  451 Time(s)
Audio files: 163
PostPosted: Sun Dec 13, 2015 12:47 pm    Post subject: Reply with quote  Mark this post and the followings unread
Here is a quick jam using the Jupiter storm & moons with sequencer trigger firing AR1 & VCA 1, plus a little bit of slow lfo to cv in 2 , osc 3 on the JP storm is barely modulated by an ADSR, & cv all gets a vc-lfo , the output of the vca goes through a delay module with the time & feedback set short.
I knocked together a simple beat to twist the Osc tuning dials & cv amounts to Smile Smile , im loving the sounds.
JP Storm & moons test jam with drums.mp3
 Filesize:  5.57 MB
 Viewed:  1313 Time(s)
Former site admin
Audio files: 353
PostPosted: Thu Dec 24, 2015 5:52 pm    Post subject: Reply with quote  Mark this post and the followings unread
Skrog Productions wrote:
Here is a quick jam using the Jupiter storm & moons.
Some nice sounds in that :-)
