Audio files: 730
Posted: Tue Jan 28, 2014 11:11 am Post subject:
Alien Spoonbending Subject description: improv with zero input alienator and other DIY devices
something I recorded last nite. I used the Alienator as a zero input mixing device, but I also had the simple sampler recording it's output and feeding
it back to the input (not sure if this still counts as zero input, although it's basically just a long delay ) I hooked up the Lun-A-Key to the Soundbender,
which is a modulator based on a XR2206 chip, and used the modulation source of that (triangle wave) to create a droning sound. This was then fed
into a weird UAA180 based waveshaper I breadboarded (a bit similar to the 5 pulser) and there was some extra (chorus + reverb) effects added to
the output of that. The waveshaper was modulated by a random voltage generator with an extra capacitor added to the CV input to create a gliding
effect. I also hooked up my RGB shroom synth for some pingy sounds. The Lun-A-Key was controlled by midi data I received from Blue Hell, which is
(partially) generated by the chat, and I used that to control the simple sampler and delay time on the alienator aswell.
I will post some longer bits later but here's a short section that also included some samples/loops.
PHOBoS - Alien Spoonbending (Zontar radio mix).mp3
"although his name is untranslatable to any Earth language, it would sound something like Zontar"
Filesize:
12.81 MB
Duration:
14:00
Viewed:
4209 Time(s)
Alien Spoonbending patch
Filesize:
55.93 KB
Viewed:
1009 Time(s)
Posted: Fri Jan 31, 2014 10:50 pm Post subject:
That is really awesome. The Zontar mix vaguely reminds me of some droney bits from My Life in the Bush of Ghosts, though maybe that's just the distorted vocal samples
