 Forum index » Clavia Nord Modular » G2 Performances - Experimental
Laptopia
Page 1 of 1 [7 Posts]
ian-s
Audio files: 43
G2 patch files: 626
PostPosted: Wed May 04, 2005 6:53 pm    Post subject: Laptopia Reply with quote  Mark this post and the followings unread
Here is more experimentation with decades old ideas, rhythm processed by Serge style wave multiplier (mid section) then completely gushed by grain-o-matic. The solo voice uses the 2nd order PLL from the source of uncertainty (Buchla) and yet another grain-o-matic. The cheap sampler piano chord effect came accidentally from an experiment with audio rate PWM.
laptopic-Edit.mp3
audio sample
 Filesize:  1.08 MB
 Viewed:  2159 Time(s)
Lap.prf2
experimental G2 perf
 Filename:  Lap.prf2
 Filesize:  13.89 KB
 Downloaded:  2339 Time(s)
Audio files: 266
PostPosted: Thu May 05, 2005 7:38 am    Post subject: Re: Laptopia Reply with quote  Mark this post and the followings unread
This is very cool. Would you please point out:
1) what part is the Serge style wave multiplier?
2) what part it the garin-o-matic?
3) where is the 2nd order PLL? How does it work?
Thanks...
ian-s
Audio files: 43
G2 patch files: 626
PostPosted: Thu May 05, 2005 1:13 pm    Post subject: Reply with quote  Mark this post and the followings unread
Thanks Howard
The Serge wave multiplier is in slot A VA, column 2. It simply consists of a SeqCtr and a rectifier. The SeqCtr is set up for half the transfer function and the rect mirrors the other half. The effect is blurred somewhat by the grain-o-matic in the VA. Change the output to 1-2 to bypass the grain effect. Its like distortion with a little PM, because the transfer function is static it works best with dynamic inputs.
http://www.musicsynthesizer.com/Circuitry/nlt.htm
The grain-o-matic in the FX section is like a pitch shifter module but uses much longer delay than the Clavia module giving time stretching or even backward type effects. It works by creating sine envelopes on 4 delay taps modulated by synchronised, variable slope ramps. I posted it a while ago in the FX section.
The source of uncertainty sub section is in slot C, it is based on the premise that summing noise directly into the integrator of a simple triangle oscillator behaves like a PLL, I cant seem to find the SynthDIY thread where I read this but the circuit consists of a home made triangle oscillator with noise injected at the integrator. A Schmitt trigger is formed by a comparator with feedback, the square wave output inverts the polarity of the ‘charge current’ producing the triangle. The end result is a source that varies from simple triangle to very random depending on the amount and colour of the noise.
Its only a very small part of the source of uncertainty and is not used in this way specifically in the original AFAIK.
Audio files: 266
PostPosted: Thu May 05, 2005 1:17 pm    Post subject: Reply with quote  Mark this post and the followings unread
Thanks, Ian. Very helpfull. thumb up
cebec
G2 patch files: 31
PostPosted: Fri Jun 10, 2005 11:34 am    Post subject: Reply with quote  Mark this post and the followings unread
hi Ian. I'm trying to isolate the schmitt trigger from the source of uncertainty but i'm not sure i'm taking all of the right modules. could you patch a generic schmitt trigger i could drop into other patches? i really don't know how to go about patching one, myself.
ian-s
Audio files: 43
G2 patch files: 626
PostPosted: Fri Jun 10, 2005 1:11 pm    Post subject: Reply with quote  Mark this post and the followings unread
http://electro-music.com/forum/topic-6302.html
This is the building block the I extracted from the prf2.
If you are just after the schmitt trigger, it is just a comparator with feedback provided by a mixer.
A regular comparator (or compare module) will change state when the input voltage exceeds the threshold. The feedback provides hysteresis so that once the output goes high, the input voltage needs to go lower than the original trip point to change state.
A small amount of hysteresis is useful to reduce multiple triggers on noisy signals.
cebec
G2 patch files: 31
PostPosted: Fri Jun 10, 2005 1:19 pm    Post subject: Reply with quote  Mark this post and the followings unread
thanks! Very Happy
