Lunettatic ChucK program
Page 1 of 1 [4 Posts]
Inventor
Audio files: 270
PostPosted: Thu Jul 21, 2011 10:04 am    Post subject: Lunettatic ChucK program
Subject description: A work in progress
I was inspired by the Lunetta Challenge to create more with Lunettas, however I was tired of wiring stuff up. I also wanted to create something that I could share with others. So I decided to write a ChucK program that makes Lunettas.
I called the program Lunettatic for fun and started coding it up while broadcasting on my port at electro-music radio. I'm doing that now as i write this, and I used Nicecast to record just a short little segment of the first working version.
I've attached the code and the audio sample. The circuit is as follows: It's a Boolean Sequencer clocked at 6 Hz with a 12 bit counter (CD4040 model) and XOR gates going to a summing network at the output. Simple, yet sounds kind of pleasant. More later as I progress.
Les
Lunettatic2 20110721 1248.mp3
Audio sample of version 2 of Lunettatic ChucK program
 Filesize:  794.29 KB
 Viewed:  1505 Time(s)
Lunettatic2.ck
 Filename:  Lunettatic2.ck
 Filesize:  2.31 KB
 Downloaded:  635 Time(s)
Inventor
Audio files: 270
PostPosted: Thu Jul 21, 2011 12:40 pm    Post subject: Reply with quote  Mark this post and the followings unread
I added spatialization using a CD4052 mux model in ChucK software form. It works by a two-bit selection of the four spatial positions which use simulated resistor dividers to weight the inputs, more on left for left spatial position and more on right for right spatial position. Hear the bits bounce around in your head, wow what a beepy triip! enjoy!
Les
Lunettatic4 20110721 1528.1.mp3
version 4 audio sample
 Filesize:  2.07 MB
 Viewed:  1412 Time(s)
Lunettatic4.ck
version 4 program with spatialization
 Filename:  Lunettatic4.ck
 Filesize:  4.19 KB
 Downloaded:  566 Time(s)
Inventor
Audio files: 270
PostPosted: Thu Jul 21, 2011 3:20 pm    Post subject: Reply with quote  Mark this post and the followings unread
Here is the final version with spatialized sound and three voices.
Les
Lunettatic8 20110721 1813.mp3
the audio
 Filesize:  781.22 KB
 Viewed:  1509 Time(s)
Lunettatic8.ck
the code
 Filename:  Lunettatic8.ck
 Filesize:  5.55 KB
 Downloaded:  641 Time(s)
Winstontaneous
PostPosted: Fri Aug 12, 2011 1:01 pm    Post subject: Reply with quote  Mark this post and the followings unread
Wacky and fun!
I've just barely started to scratch the surface of sound programming languages (pure data, Processing, Super Collider, Chuck).
Your examples and creativity are inspiring!
