ChucK Guitar Effects
Page 1 of 1 [14 Posts]
Inventor
Audio files: 270
PostPosted: Wed Jun 17, 2009 3:14 am    Post subject: ChucK Guitar Effects
Subject description: Four examples and request for more
A while back we had a thread about guitar effects programs for ChucK. Kijjaz and I wrote some code, attached, that does freaky things with guitar input and makes really kewl sounds.
I'm posting because I'd like to start doing some guitar jams on The ChucK Show using such guitar effects programs, and I was wondering if anyone would like to take a shot at creating some more. Or if you're busy or don't have a guitar, I wonder if you could suggest some possibilities for me to convert into code.
Please let me know what your thoughts are on this topic, I'm eager to develop a collection of really kewl effects for the show. Thanks.
Les
Primal2.ck
 Filename:  Primal2.ck
 Filesize:  5.07 KB
 Downloaded:  967 Time(s)
Kijjaz_Trancey1.ck
 Filename:  Kijjaz_Trancey1.ck
 Filesize:  1.65 KB
 Downloaded:  900 Time(s)
Kijjaz_Psychedellic1.ck
 Filename:  Kijjaz_Psychedellic1.ck
 Filesize:  1.05 KB
 Downloaded:  882 Time(s)
Kijjaz_Evolver.ck
 Filename:  Kijjaz_Evolver.ck
 Filesize:  946 Bytes
 Downloaded:  910 Time(s)
wmonk
Audio files: 15
PostPosted: Wed Jun 17, 2009 8:22 am    Post subject: Reply with quote  Mark this post and the followings unread
Cool idea Inventor! Perhaps you can send me some guitar files to use the effects on. That way I can do some effects, without destroying my soundcard by plugging my guitar into the mic input Wink
The effect of the effects would be clearer when using the same guitar for programming.
Inventor
Audio files: 270
PostPosted: Wed Jun 17, 2009 8:26 am    Post subject: Reply with quote  Mark this post and the followings unread
Wow Thomas, thanks for giving it a shot! I will record some guitar for you in a wav file using ChucK so you can read it in with WvIn or whatever it's called, I forget. I have found that ChucK will not read in just any wav file but it will read in it's own files as far as I know. I'll post soon.
Les
Inventor
Audio files: 270
PostPosted: Wed Jun 17, 2009 9:27 am    Post subject: Reply with quote  Mark this post and the followings unread
wmonk,
Here is a file for your testing purposes. Thanks for giving this a try.
Les
wmonkGuitar.wav
File for wmonk, just me talking and playing bad guitar
 Filesize:  14.81 MB
 Viewed:  1996 Time(s)
wmonk
Audio files: 15
PostPosted: Wed Jun 17, 2009 2:19 pm    Post subject: Reply with quote  Mark this post and the followings unread
Well, got some things done. The UAna's are great for some effects. Now time to find my microphone to test it with my own voice. Will update this post soon! Smile
Inventor
Audio files: 270
PostPosted: Wed Jun 17, 2009 2:27 pm    Post subject: Reply with quote  Mark this post and the followings unread
Gee Thomas, I didn't know you could speak guitar! Haha, just kidding. I just got the idea to try summing the output of delayed versions of the input signal for an interesting effect. Maybe I'll get time to try it tonight.
Les
wmonk
Audio files: 15
PostPosted: Wed Jun 17, 2009 4:04 pm    Post subject: Reply with quote  Mark this post and the followings unread
The idea was to post a MP3 file here with the files demoing, but couldn't find the mic.
Number 001 is more or less a chorus like effect, it brightens the signal.
Number 002 sounds like a bitcrusher, I like it. I did some modifications to create the others:
Number 003 is dark, Number 4 is more like waterdrops.
20090617-guitareffect001.ck
 Filename:  20090617-guitareffect001.ck
 Filesize:  425 Bytes
 Downloaded:  867 Time(s)
20090617-guitareffect002.ck
 Filename:  20090617-guitareffect002.ck
 Filesize:  461 Bytes
 Downloaded:  837 Time(s)
20090617-guitareffect003.ck
 Filename:  20090617-guitareffect003.ck
 Filesize:  578 Bytes
 Downloaded:  871 Time(s)
20090617-guitareffect004.ck
 Filename:  20090617-guitareffect004.ck
 Filesize:  506 Bytes
 Downloaded:  840 Time(s)
mrcold
Audio files: 31
PostPosted: Thu Jun 18, 2009 10:42 am    Post subject: Reply with quote  Mark this post and the followings unread
hey..
these are awesome Smile
I am working on a project and stuff like this is EXACTLY what I need.
Audio files: 373
PostPosted: Thu Jun 18, 2009 11:09 am    Post subject: Reply with quote  Mark this post and the followings unread
There's always the old oscillator sync trick. Actually it wasn't as simple as I first thought, since I misinterpreted the sync input on SinOsc. Change the channels on adc and dac to your liking (I need to do it like this to get it to work with my Motu):
Code:
adc.chan(0) => blackhole;
SinOsc sinOsc => dac.chan(2);
sinOsc => dac.chan(3);
1 => sinOsc.sync;
400 => sinOsc.freq;
1 => sinOsc.gain;
0.0 => float max;
0.0 => float lastValue;
0.0 => float lfoPhase;
while(true) {
   1::samp => now;
   0.00001 +=> lfoPhase;
   if (lfoPhase > pi*2.0) {
      0 => lfoPhase;
   Math.sin(lfoPhase)*1000.0 + 1200.0 => sinOsc.freq;
   adc.last() => float value;
   if (value > max) {
      value => max;
   0.0001 -=> max;
   max => sinOsc.gain;
   if (lastValue < 0.0 && value >= 0.0) {
      0.0 => sinOsc.phase;
   value => lastValue;
Inventor
Audio files: 270
PostPosted: Thu Jun 18, 2009 7:21 pm    Post subject: Reply with quote  Mark this post and the followings unread
I'm gonna check that out later, Stefan. I downloaded it and changed the ADC and DAC lines, now I just have to test it.
Here is a multiple delay line effect. It just has a chain of delays in series that are all summed into the dac, so it soundsoundsounds likeikeike thisisis sort of. Change the two parameters at the top of the file for different delay and number of delays.
Les
MultiDelayGuitarEffect1.ck
 Filename:  MultiDelayGuitarEffect1.ck
 Filesize:  530 Bytes
 Downloaded:  783 Time(s)
Kassen
PostPosted: Fri Jun 19, 2009 4:15 am    Post subject: Reply with quote  Mark this post and the followings unread
mrcold wrote:
hey..
Welcome on board!
Kassen
Inventor
Audio files: 270
PostPosted: Sat Jun 27, 2009 8:16 pm    Post subject: Reply with quote  Mark this post and the followings unread
i just entertained rob and jan and mrcold with the attached guitar synth. It's by kijjaz as posted earlier in this thread, but i added a delay line feedback loop which really makes it super psychedellic.. or should i say psychodellic, with an o! wow man.
Kijjaz_Psychedellic2.ck
Kijjaz Psychedellic Guitar Synth
 Filename:  Kijjaz_Psychedellic2.ck
 Filesize:  1.14 KB
 Downloaded:  625 Time(s)
Inventor
Audio files: 270
PostPosted: Sun Jun 28, 2009 3:09 am    Post subject: Reply with quote  Mark this post and the followings unread
I got to thinking about that last posted code, KijjazPsychedelic2, while in chat and it occurred to me that I could create a hardware feedback loop instead of a software one. So I just moved the delay line to the output and now I'm waiting for morning so I can hook things up and jam.
You see, I have a special cable that runs from the eMac's headphones output to the guitar amp's CD player input. I just attenuate the signal in software and then a feedback loop will be established.
Guitar input will get sounded by the amp, and then the eMac's microphone will pick up the guitar and my voice, go all psychedelic on it, and send that back to the guitar amp. This process repeats so that many images of the sound are present at any one time.
What's so cool about this is that it will fill my living room with the psychedelic sounds instead of just being on the headphones as in the past.
I should be able to control the amp gain and the eMac volume to establish any desired level of effect. Wish me luck. If it works, I may do it on the ChucK show.
Les
Inventor
Audio files: 270
PostPosted: Tue Jun 30, 2009 9:28 am    Post subject: Reply with quote  Mark this post and the followings unread
I tried the experiment in the previous post and there was too much room noise in the feedback loop. The noise took over the signal so it didn't work right. What I did discover, however, is that the feedback loop, even in software is unnecessary. I made several guitar synths and went back to KijjazPsychedelic1.ck because the original was the best.
Then I modified it to receive input from my homemade little guitar mixer thingie. It puts the mic on one channel and the guitar on the other, amplifies them accordingly and sends them in on the left and right channels of the line in jack. I set the code up to psychedelically process the voice and pass the guitar through with only some software gain.
With this configuration I still get the star-sparkling woo woo noises in response to the voice, but the guitar comes through clean. Should be useful in the ChucK show...
Les
Kijjaz_Psychedellic5.ck
Latest and best version of Kijjaz Psychedelic (for my use)
 Filename:  Kijjaz_Psychedellic5.ck
 Filesize:  1.21 KB
 Downloaded:  614 Time(s)
