 Forum index » electro-music.org » Streaming Radio Station
electro-music New Year's Eve Party
Post new topic   This topic is locked: you cannot edit posts or make replies. Moderators: shanemorris
Page 4 of 6 [150 Posts]
Audio files: 282
PostPosted: Thu Dec 29, 2005 3:48 pm    Post subject: Reply with quote  Mark this post and the followings unread
How do I test that my stream is working?
Former site admin
Audio files: 353
PostPosted: Thu Dec 29, 2005 3:58 pm    Post subject: Reply with quote  Mark this post and the followings unread
You could start a player and for the URL use http://radio.electro-music.com:<portnr> where <portnr> is one of the port numbers Howard gave to you - you can try both, both should work. And when that is working all should be OK, those ports will be manually plugged through to the main ports when it's "your time".
A few messages back I gave some examples for various players.
The main ports seem to be conected to the Noodle Radio now, but that will be a bit messy for the time being, as I'm working on making a program rather than doing serious streaming :-)
Ehm, and it should do some bug finding ...
Audio files: 282
PostPosted: Thu Dec 29, 2005 4:11 pm    Post subject: Reply with quote  Mark this post and the followings unread
I have set up Winamp with the shoutcast plugin as Mosc explained and clicked Connect. As far as I can tell something is being sent, I just don't know whether it is getting through. Is there any way to check?
deknow
PostPosted: Thu Dec 29, 2005 4:14 pm    Post subject: Reply with quote  Mark this post and the followings unread
...i was able to run foobar2000 listening to the stream at the same time winamp was sending it (make sure to point specifically to the stream you are sending).
deknow
Former site admin
Audio files: 353
PostPosted: Thu Dec 29, 2005 4:24 pm    Post subject: Reply with quote  Mark this post and the followings unread
modulator_esp wrote:
I have set up Winamp with the shoutcast plugin as Mosc explained and Connect. As far as I can tell something is being sent, I just don't know whether it is getting through. Is there any way to check?
Yes, that's what I tried to explain. You can listen to the same ports you send on, and it will be running through the server then.
Just don't use WinAmp to monitor as you are using that to send, but almost any player will be able to play shoutcast streams. The audio you get back back will b delayed by some tens of seconds.
Audio files: 282
PostPosted: Thu Dec 29, 2005 4:31 pm    Post subject: Reply with quote  Mark this post and the followings unread
Thank you both, I had not realised I had to change the port on the monitor to match that on the transmitter. Everything is OK now Very Happy
mtvic
PostPosted: Thu Dec 29, 2005 7:13 pm    Post subject: HELP Reply with quote  Mark this post and the followings unread
SH_T.
I can' t get these plug ins to work .
Shoutcast gives me invalid password message when I try to connect
oddcast gives me LAME .dll error when Itry to connect
Waz up wid dis ch_t mon
Please help
I really want to do this.
sonically all of yalls
mtvic
Former site admin
Audio files: 353
PostPosted: Thu Dec 29, 2005 7:29 pm    Post subject: Reply with quote  Mark this post and the followings unread
Ok, lets try to sort it out.
For the Shoutcast plugin : are you using the port numbers/passwords Howard sent you ?
I had some confusing characters in the passwords I got from Howard, cutting those out of Howard's message and pasting them into the password box solved a connection problem for me.
For OddCast, are you using the WinAmp plugin, the Foobar plugin or the stand-alone version ?
You'll need the file lame_enc.dll for the OddCast standalone it must be in the folder where the OddCast exe is, for the plugin I guess it should be in the WinAmp folder or in the WinAmp\plugin folder. WinAmp itself uses lamedll.dll which seems to be a different lame encoder.
mtvic
PostPosted: Fri Dec 30, 2005 9:28 am    Post subject: Reply with quote  Mark this post and the followings unread
Q:For the Shoutcast plugin : are you using the port numbers/passwords Howard sent you?
A: yes
I will try cutting and pasting and get back toyou
mtvic
Mohoyoho
PostPosted: Fri Dec 30, 2005 11:10 am    Post subject: Reply with quote  Mark this post and the followings unread
I found this out the hard way, and hopefully this might help you, Michael. Make sure there is no file loaded in Winamp when you have the plugin Shoutcast Source's Input on Soundcard. On my Windows 2000 it will freeze the whole computer if it's on Soundcard and there's a MP3 loaded and trying to play. If you want to play a file put the input on Winamp. If you want to play live through the soundboard, clear it out (there's a menu for that) and then change the input from Winamp to Soundcard.
If you still are having problems, Winamp has a pretty extensive support system. There are lots of posts on their forum that will walk you through problems. There are all sorts of problems that can occur. Old sound cards will need buffers, you'll have to have a recent Direct X loaded, etc.
Hope some of this will help.
mtvic
PostPosted: Fri Dec 30, 2005 7:17 pm    Post subject: Reply with quote  Mark this post and the followings unread
Thank you
Iwill certainly try your suggestion.
Iam preparing to set it up now.
Fingers crossed.
Sonically
mtv
mtvic
PostPosted: Fri Dec 30, 2005 7:41 pm    Post subject: Reply with quote  Mark this post and the followings unread
Danke
everyone
It's alive
please listen in at
GMT
Jan 1 02:00 - 03:00
EST
21:00 - 22:00 (Dec 31) Mike Victor Philadelphia
Iwill be jamming eclectic improv with DJRock.
my good friend for many years .
Sonically
mtvic
Audio files: 266
PostPosted: Fri Dec 30, 2005 7:42 pm    Post subject: Reply with quote  Mark this post and the followings unread
Great, Mike. Glad to hear you got it working.
deknow
PostPosted: Fri Dec 30, 2005 8:55 pm    Post subject: Reply with quote  Mark this post and the followings unread
...glad you got it worked out, we will be tuning in from here (i think about a dozen people are coming over).
deknow
Audio files: 266
PostPosted: Fri Dec 30, 2005 9:00 pm    Post subject: Reply with quote  Mark this post and the followings unread
We've started already. Noodles have been running since last night. See http://radio.electro-music.com
seraph
Editor
Editor
Audio files: 33
PostPosted: Sat Dec 31, 2005 1:23 am    Post subject: Reply with quote  Mark this post and the followings unread
I tuned in Exclamation listening to noodles galore Very Happy
frater v.i.o.
PostPosted: Sat Dec 31, 2005 4:00 am    Post subject: Reply with quote  Mark this post and the followings unread
just tuned in Very Happy
it takes very long before the schedule url will show up(at least with firefox).
guten rutsch. Wink
...it lives again.
jono
PostPosted: Sat Dec 31, 2005 4:32 am    Post subject: Noodles
Subject description: NYE
Streaming his fine with the Noodles. Very good
I hope everything goes smoothly and we all get a Happy New Year's Eve Party
Happy New Year
Mohoyoho
PostPosted: Sat Dec 31, 2005 8:05 am    Post subject: Reply with quote  Mark this post and the followings unread
Noodles are great!
Yes, I had some trouble loading the schedule page too.
Michael and I are up for this. Being first up, I hope things will go well. I have 50 foot mike cables running from our setup in my living room down the hall to my small office (where my computer is). My wife is going to monitor the computer to let me know if we make connection.
Good luck to all today, and a big thanks to Howard and everyone who had a hand in putting this together.
Happy New Year to all. May this year find peace.
Mark Mahoney
Kingsport, Tennessee
www.cdbaby.com/cd/markmahoney
Audio files: 282
PostPosted: Sat Dec 31, 2005 10:55 am    Post subject: Reply with quote  Mark this post and the followings unread
I'm having problems with the schedule page too, and also with the main site, takes for ever to load and quite often doesn't make it. Hopefully it'll all be sorted for later Smile
Audio files: 282
PostPosted: Sat Dec 31, 2005 6:42 pm    Post subject: Reply with quote  Mark this post and the followings unread
Well I had fun. Didn't go exactly to 'plan', but went better than the practice run
Happy New year to all
jono
PostPosted: Sat Dec 31, 2005 7:22 pm    Post subject:  Many Thanks Reply with quote  Mark this post and the followings unread
Thank you Mosc for this special evening this was a great job.
And thank you to All for the great Gigs and Noodles Streaming.
Thanks.
Happy New Year
Jono
Audio files: 282
PostPosted: Sat Dec 31, 2005 10:12 pm    Post subject: Reply with quote  Mark this post and the followings unread
Well, I stayed up much later than I should to catch the sets by Antimon, Mike Victor, Deknow and Mosc and enjoyed them all.
When's the next one?
paul e.
PostPosted: Sat Dec 31, 2005 10:15 pm    Post subject: Reply with quote  Mark this post and the followings unread
hey this is fun ....
just heard howard's [i presume] New years greeting and shout-outs
thing is, on my end the level is really really low
anyone else?
Spiral Recordings
paul e.
PostPosted: Sat Dec 31, 2005 10:31 pm    Post subject: Reply with quote  Mark this post and the followings unread
to clarify
the level on the audio portions is good
however, when howard got on the mic, the level was very low
anyhow..great stuff ! good work
Spiral Recordings
