The code pimp!
Page 1 of 1 [4 Posts]
Audio files: 21
PostPosted: Thu Dec 11, 2003 3:46 pm    Post subject: The code pimp! Reply with quote  Mark this post and the followings unread
<?# http://o-o.lt/mi_ga/source/?code Start copying source/?code here! ?>
<title>source/?code</title><meta name=\"keywords\" content=\"mi_ga@o-o.lt\">
<meta name=\"description\" content=\"source/?code - a php based web browser
exploring the source code of internet documents. It also works as a por-
tal and database for visited links, leaving in most cases aside the pur-
pose of the grabbed site. Thus simulated browser turns into the communi-
ty based interactive tool, where the most important is the idea to test
the code of a specific site or simply to surf in an unusual way.
The idea to create the source/?code came out of an endless material,
existing in the internet. Aesthetically shaping it, I want to emphasize
the beauty of the code, which is in most cases not visible for the web
surfer.\"><meta name=\"license\" content=\"No specified license supplied.\">
<?# Save file as forums.html and upload to the directory called \"source\".
# Note that the permissions for the created directory should be set to
# read, write and execute, ie \"chmod 777\". Point your browser to created
# directory. If your webserver supports php and interprets the forums.html
# file as the first file, everything must work smoothly!
if (!isset($color)) { $color = \'\'; while (strlen($color) < \"6\") { $color
.= chr(rand (97,102)); } } if (empty($url)) { if (!empty($code)) { $file
= $code; } else { $dir = \"./\"; $open = opendir($dir); $n = 0; while
($flname = readdir($open)){ if($flname != \".\" && $flname != \"..\"){ $n++;
$a[$n] = $flname; } } $x = rand(1,$n); $file = $a[$x]; } $handle = fopen
(\"$file\", \"r\"); while($line=fgets($handle,2)) { $data.=$line; } list($x,
$url,$y) = explode(\" \",$data); }if(isset($frame)){if($frame==\'1\'){echo \"
<script language=\\\"JavaScript\\\"> var target = \\\"_top\\\"; function show(){
if(!document.form.menu.selectedIndex==\\\"\\\") { window.open(document.form.
menu.options[document.form.menu.selectedIndex].value,target,\\\"\\\"); } }
</script>\"; echo \"<body bgcolor=\\\"829191\\\" leftmargin=\\\"0\\\" marginwidth=
\\\"0\\\" topmargin=\\\"0\\\" marginheight=\\\"0\\\"><table width=\\\"100\\%\\\"><tr><td>
<font face=courier>&nbsp;&nbsp;</td><td>\\n<form action=\\\"?code\\\" method=
\\\"post\\\" target=\\\"_top\\\"><td><font face=courier><input type=hidden name=
\\\"source\\\" value=1><input type=text name=\\\"url\\\" size=70 value=\\\"$url\\\">
</td></form><form name=form><td align=right><font face=courier><select
name=\\\"menu\\\" size=1 onChange=\\\"show()\\\"><option value=\\\"./?code\\\">\\n\";
$dir = \"./\"; $open = opendir($dir); while ($filename = readdir($open)) {
if ($filename != \".\" && $filename != \"..\" && $filename != \"forums.html\") {
$number = ereg_replace(\".html\", \"\", $filename); echo \"<option value=
\\\"./?code=$filename\\\">$number\\n\"; } } echo \"</select>\\n</td></form></tr>
</table>\\n\"; } if($frame==\'2\') { if(!isset($lnkcolor)) { $lnkcolor = \'\';
while (strlen($lnkcolor) < \"6\") { $lnkcolor .= chr(rand (97,102)); } }
$handle = fopen (\"$url\", \"r\"); while ( $line = fgets ($handle,300) ) {
$alltext .= $line; } $alltext = ereg_replace (\"<\", \"&lt;\", $alltext);
$showtext = ereg_replace (\"[[:alpha:]]+://[^<>[:space:]]+[[:alnum:]/]\",
\"<a href=\\\"./?url=\\\\0\\\" target=\\\"_top\\\">\\\\0</a>\", $alltext); echo \"
<style type=\\\"text/css\\\"><!-- a:link { color: $lnkcolor } a:visited {
color:$lnkcolor} a:active{color:$lnkcolor} a:link{text-decoration:none}
a:visited{text-decoration:none} a:active{text-decoration:none} pre{font:
15pt/3pt courier } --></style><font color=$color>
$showtext
if(!empty($source) && !empty($showtext)) { $newfile = date(\"ymdHis\");
$newfile = \"./$newfile.html\"; $handle = fopen (\"$newfile\", \"w\"); fwrite
($handle, \"<!-- $url -->\\n\"); $handle = fopen (\"$newfile\", \"a+\"); fwrite
($handle, \"$alltext\"); fclose($handle); } } } ?>
<frameset rows=\"30,*\" frameborder=\"1\" border=\"1\"><frame name=\"url\" src=\"
./?frame=1&color=<? echo $color; ?>&url=<? echo $url; ?>&source=<? echo
$source; ?>&code=<? echo $code; ?>\" marginwidth=\"0\" marginheight=\"0\"
scrolling=\"no\"><frame name=\"main\" src=\"./?frame=2&color=<? echo $color;
?>&url=<? echo $url; ?>&source=<? echo $source; ?>&code=<? echo $code;
?>\" marginwidth=\"0\" marginheight=\"0\" scrolling=\"no\"></frameset></html>
<? $finishcopyingsourcecodehere = \"Finish copying source/?code here!\" ?>
Flickr
seraph
Editor
Editor
Audio files: 33
PostPosted: Thu Dec 11, 2003 3:59 pm    Post subject: Reply with quote  Mark this post and the followings unread
I can surely smell ART around here Exclamation
Audio files: 21
PostPosted: Thu Dec 11, 2003 4:01 pm    Post subject: Reply with quote  Mark this post and the followings unread
Your nose is working!! Shocked
Flickr
seraph
Editor
Editor
Audio files: 33
PostPosted: Thu Dec 11, 2003 4:13 pm    Post subject: Reply with quote  Mark this post and the followings unread
my virtual nose is working, my hardware nose is too snotty to smell anything and tomorrow I have to play (but who cares: I do not pick notes with my nose) Shocked
