SuperCounter
jamos
G2 patch files: 44
PostPosted: Fri Jul 31, 2026 2:33 pm    Post subject: SuperCounter
Subject description: An up/down counter with several twists
This is a byproduct of my quest for the ultimate arpeggiator - a souped-up up/down counter.
This will count from a minimum to a maximum value, using a selectable step size, in any of four different directions - up, down, up/down, and a special "drunkard's walk" mode, which changes direction at random on every step. (I only added the fourth mode because I had a fourth slot on the switch.)
There's also a Reverse input, which reverses the direction of counting as long as it is high. In conjunction with the first three modes and an event sequencer, this allows for the creation of some interesting patterns.
SuperCounter.pch2
 Filename:  SuperCounter.pch2
 Filesize:  2.66 KB
 Downloaded:  67 Time(s)
