Audio files: 353
Posted: Wed Jul 29, 2026 1:52 pm Post subject:
my page changed |
My page changed ... https://www.electro-music.com/radio_admin/radio_info_test.php
The speaker symbols on the left now popup some player window instead of opening in my VLC ..
Why was it changed? I do not want this, please revert it.
Also I'm still getting admin mails about new signups, I do not want those. |
Audio files: 353
Posted: Wed Jul 29, 2026 1:54 pm Post subject:
| On the radio page the link to "Links for use with external players" does not work where should it point at .. but i still can not use that to listen in to the connector ports on VLC |
Audio files: 353
Posted: Wed Jul 29, 2026 2:12 pm Post subject:
Anyway .. behind the speaker symbols should just be
an m3u or a pls containing :
http://electro-music.com:8050
etc. for all the ports.
I used to run a php file to generate that stuff .. pff ..
Also the link for external players on the radio page is nort working .. has been defunct for a long time now.
Howard - some people ---really--- want there own players, and not that popup web nonsense.
Also the the port information for user ports got fukt .. currently jez is on and he used to have an image uploaded for his port .. it is not showing anymore.
And I had to restore it manually for my own port. |
Audio files: 353
Posted: Wed Jul 29, 2026 2:17 pm Post subject:
| And I still can not remove people from user groups - and there really is nonsense in the groups. |
Joined: Jan 31, 2003 Posts: 18507 Location: Durham, NC
Audio files: 266
Posted: Thu Jul 30, 2026 10:10 pm Post subject:
Jan, thanks for the heads up on these problems.
All 5 items are fixed. The m3u links are a little different but they should work. It turns out that some browsers don't serve http requests in links from https pages I tested these links in chrome and firefox. There is a forum post with the link information and a link to that post on the radio page that works now.
https://electro-music.com/forum/topic-74977.html
Users are back on self approval as has always been the case. You won't get admin email for new accounts anymore. This has actually been the case for 2 or 3 days.
You can remove users from usergoups. There was a bug on the original forum code that's been there for 20 years.
I'm confident these things are fixed, but I expect I'm over confident.
Please check and let me know... _________________ --Howard
my music and other stuff |
Audio files: 353
Audio files: 353
Posted: Fri Jul 31, 2026 1:21 pm Post subject:
| Removing people from groups works, at least it did so for the radio-ops group - thanks! |
Audio files: 353
Posted: Fri Jul 31, 2026 1:22 pm Post subject:
| Also thanks for the admin email change - I'll re-anable those here. |
Audio files: 353
Posted: Fri Jul 31, 2026 1:23 pm Post subject:
The external player link is useful again - thanks :)
.. except that it only works for the stations .. and not for the connectors. |
Audio files: 266
Posted: Sat Aug 01, 2026 10:06 am Post subject:
Jan, the connector ports should work in VLC now, including the All link.
One difference you'll notice: the m3u for a connector port now contains
https://electro-music.com/stream/8078
instead of http://electro-music.com:8078. On the new engine the connector port itself is only the door your encoder logs into (that part is unchanged - same port, same password). The listener side comes out of Icecast, and /stream/8078 is where it lives. Raw port listening can't come back without moving everyone's source login ports, which I don't want to do. VLC plays the https link the same way.
The 7 station ports still use the direct http://electro-music.com:8050 style links.
One note: a connector port with nobody connected will give VLC an error - same as the sc_serv days, nothing on the port until someone is on it.
Please give it a try and let me know. _________________ --Howard
Audio files: 353
Posted: Sat Aug 01, 2026 4:54 pm Post subject:
It works - thank you.
And .. hmm .. yeah .. re-assigning port numbers would seem a good idea .. to bring some order in the historic mess .. yet confusing .. indeed. |
Audio files: 353
Audio files: 353
Posted: Tue Aug 04, 2026 11:36 am Post subject:
| k .. claudeo mumbled some magic token thingies and now it is fixed again - good. |
