LED indicator for VC panning?
Page 1 of 1 [6 Posts]
PostPosted: Sat Apr 23, 2022 9:01 pm    Post subject: LED indicator for VC panning? Reply with quote  Mark this post and the followings unread
https://yusynth.net/Modular/Commun/MIXOUT/mixout-panner-sch.gif
Would a LED going to ground through a resistor, from the output of U101a, be a good location to get a indicator of the amount of panning?
gabbagabi
PostPosted: Sat Apr 30, 2022 10:01 am    Post subject: Reply with quote  Mark this post and the followings unread
hm, just a guess...
only counting in the offset
the minus 4 Volt going in to 101d coming out as plus 2V
then these
2V and -4V coming out of 101a as 2V, right?
so the LED would be always on with no CV applied,
i guess Smile
Audio files: 730
PostPosted: Thu May 05, 2022 12:04 pm    Post subject: Reply with quote  Mark this post and the followings unread
gabbagabi wrote:
hm, just a guess...
then these
i guess Smile
yes, I think that is indeed correct, with no CV and the pan pot (PAN #1) at the center position.
with a supply voltage of -/+15V and R3 = R4 = 27K the output of 101a can be varied from -1V to +5V
by adjusting the pan pot. This is with T101 set to -4V so once properly calibrated itwill be slightly different.
It would be a good location to get a voltage to drive an LED but it requires some extra components to get it
working properly. Driving an LED so that it corresponds nicely with a varying voltage is a bit tricky.
The best way might be by using PWM but that get's a bit complicated for a single LED. Another way to do it
is with an opamp configured as a current source, or with a transistor. But all methods would need some extra
components and proper testing since it also depends on the used LED and the response you want.
The Golden Shrimp Guild
PostPosted: Fri May 06, 2022 1:44 pm    Post subject: Reply with quote  Mark this post and the followings unread
I think I'm going to have to pull my build of this from my rack, and tack on some flying test wires.
I'm using the subcircuit in another module, and would like some kind of visual indicator Very Happy
gabbagabi
PostPosted: Sat May 07, 2022 11:33 pm    Post subject: Reply with quote  Mark this post and the followings unread
What comes quickly to my mind,
The difference between 101a and 101d is zero with no CV applied
With CV the difference will rise
Could be antiparallel LEDs + resistor between the two outputs a solution?
Audio files: 730
PostPosted: Mon May 09, 2022 11:21 am    Post subject: Reply with quote  Mark this post and the followings unread
good thinking and worth trying. The forward voltage of the LEDs might create a large dark section
and it may affect the outputs of the opamps, it actually creates somewhat of a feedback path for U101a.
But it would be a nice and simple solution.
