issue with PT2399 scot bernardi
Page 1 of 1 [2 Posts]
waronheaven
PostPosted: Mon Dec 27, 2021 7:06 am    Post subject: issue with PT2399 scot bernardi
Subject description: issue with pin14 and time cv
Hello Everyone, so if you followed my previous post i was having troubles making a relatevly simple design (attached)
basically i was having no signal on pin 14 of both of the PT2399 of the design. so i have managed to have signal at least on DELAY 1, i had to by pass all the cv time stage, adding a resistor from pin 6 to ground, and re soldering R10.
now i have signal (photo attached) but is not delayed (premise that i have the exact same pcb but single delay working) so should everyting work fine, but again seems either there is a problem on the LM13700 or i dont know.
Also the Diodes on the controlled voltage time stage are they switching general purpose? i got the design from here: http://www.sdiy.org/destrukto/vc-echo.html
also R14 im not sure if it goes to + or - voltage, hope someone can help me with all those questions, thanks a lot everyone
schematic
https://www.dropbox.com/s/2igs99flcn3eu6z/doubledelay.png?dl=0
Oscilloscope reading
https://www.dropbox.com/s/wthtjr132zhpdv5/IMG_4976.jpg?dl=0
gabbagabi
PostPosted: Sun Jan 02, 2022 2:51 am    Post subject: Reply with quote  Mark this post and the followings unread
Hi! and welcome to the Forum.
Do yourself a favor and attach grafix directly in the post.
If you do so, it is much more likely to get some help from your friends.
good luck!
 Filesize:  52.46 KB
 Viewed:  259 Time(s)
