Andy randomly changing parameters - similar to sketchy pots
Page 1 of 1 [4 Posts]
statlerw
PostPosted: Tue Sep 22, 2020 5:11 pm    Post subject: Andy randomly changing parameters - similar to sketchy pots Reply with quote  Mark this post and the followings unread
I pulled my andy out of storage (unfortunately a very long one) and fired it up. Works fine - as awesome as I remember. Only problem is an intermittent random changing of (mainly oscillator) parameters.
The display shows the values changing like I had moved a pot (commonly LFO 1 / 3 or one of the VCO master tunes, put also S&H and other parameters). I have tried moving the pots around to make sure it isnt the 'actual' pots and I dont think it is because;
1. It isn't just one pot / value and it seems to be signal source related parameters
2. The value keeps moving even after several wide sweeps of the pots
Maybe a voltage issue somewhere? Perhaps a cap or op-amp failure?
The machine is usable, but this is annoying it makes it only suitable for studio use. Any pointers? Board components to check?
Any help appreciated
pulsewave
PostPosted: Tue Mar 02, 2021 8:41 am    Post subject: Reply with quote  Mark this post and the followings unread
Here's a great video on jumping values and the proper way to fix it (don't spray deoxit in the shaft...).
https://www.youtube.com/watch?v=1PczJWF5WqQ
bobule
PostPosted: Thu Sep 16, 2021 7:21 am    Post subject: Reply with quote  Mark this post and the followings unread
thanks for this ^
rh2y
PostPosted: Wed Oct 19, 2022 7:40 pm    Post subject: Reply with quote  Mark this post and the followings unread
About to attempt this myself. My A6 is from 2007 and for the most part, if I take the time to twiddle all the pots on it back and forth about 10-15 times before playing it, it behaves for that session, and maybe for a week or two after. If I let it sit more than a few months (it happens... Sad ) then I have to do the whole "twist all the pots" dance again.
Shameless plug: http://www.soundcloud.com/rh2y
Shameless-er plug: http://www.evatontechnologies.com/
Music: https://atomstomolecules.bandcamp.com/releases
