Coming up on Radio 1 at
Steiner VCF - strange self oscillation problem
Page 1 of 1 [5 Posts]
Bodo1967
PostPosted: Mon Sep 14, 2020 5:21 am    Post subject: Steiner VCF - strange self oscillation problem Reply with quote  Mark this post and the followings unread
I built the YuSynth Steiner filter (current version according to the web site).
Everything (all 4 modes, cutoff, resonance, cv...) works absolutely perfectly - except for one thing:
The filter does actually self oscillate when the resonance is cranked up sufficiently, but does so in a rather high frequency range (kHz), which hardly - if at all - responds to the cutoff pot and/or applied CV. Also, it rather looks trapezoidal than like a sine wave.
Any ideas?
Additional info:
- There is a difference concerning R22 between the schematic and the layout It's 220k in the schematic and 330k in the layout. I used 220k there.
- Increasing R18 (I used 4k7) in several steps to about 32k led to no improvement.
- The 2k trimmer (T2) also has no noticeable effect, but that may be a follow-up to the oscillation being somewhere out of a useful range.
romaindegode
PostPosted: Mon Sep 14, 2020 11:58 am    Post subject: Reply with quote  Mark this post and the followings unread
Hi
Did you used BC547? Matching pair was OK?
I'm asking that because you have no effect on T2 trim and Yves suggests that problems might happen with a bad matching
Did you try different values for R18? This resistor has to do with resonance range.
It would be nice if you could put some pictures of both side pcb
Also if you double checked wiring, you should triple check 😉
Bodo1967
PostPosted: Mon Sep 14, 2020 11:28 pm    Post subject: Reply with quote  Mark this post and the followings unread
thanks for your reply Very Happy!
Yes and yes - and it was no problem at all to trim the CV bleedthrough to almost invisible and inaudible.
Argh, my bad. I correctly wrote "2k trimmer" (the other one is 1k), but that's T1 (near the edge of the board), not T2 Embarassed . T2 is 1k and used for eliminating CV bleedthrough (in the center of the board). And that went flawlessly, as I wrote above.
Yes, that's what I meant by "Increasing R18 (I used 4k7) in several steps to about 32k...". Those steps were 4k7; 2 * 4k7; 3 * 4k7; and 4k7 + 27k, meaning resistance values of 4k7, 9k4, 14k1 and 31k7 respectively.
Sure (I made a KiCad layout of the PCB, which I of course triple checked before getting it manufactured). I'll check once more (including checking for accidental solder blobs and/or bad solder joints) and if I don't find any obvious mistake I'll post pictures.
Did that as well, but I doubt I made any mistakes here since everything else works as it should.
Bodo1967
PostPosted: Sat Sep 19, 2020 12:32 pm    Post subject: Reply with quote  Mark this post and the followings unread
OK, here we go -
it seems I can't add more than 5 pics to one post, so I'll have to do it in two posts.
Oscilloscope pics are all taken with self oscillating filter. The first and last ones are from the output jack. Frequency at this point ranges from approximately 2.2 - 3.5 kHz, depending on the cutoff pot setting. The first TL074 I had put in returned a kind of trapezoid wave, whereas the second one is more or less a square wave.
The three in the middle taken on pin 5 of the IC. At lower cutoff settings the wave is a bit triangle-ish. It goes down in amplitude and turns into a sine wave at higher settings of the cutoff pot.
Edit: The preview showed the pics in different order - best look at them in inverted order Rolling Eyes .
filter output after having swapped the TL047
 Filesize:  370.38 KB
 Viewed:  538 Time(s)
same signal as before, but with Y scaling on the oscilloscope increased a bit
 Filesize:  387.69 KB
 Viewed:  518 Time(s)
pin 5 of the TL074 at higher cutoff setting
 Filesize:  388.23 KB
 Viewed:  482 Time(s)
pin 5 of the TL074 at low cutoff setting
 Filesize:  388.99 KB
 Viewed:  508 Time(s)
filter output
 Filesize:  386.38 KB
 Viewed:  505 Time(s)
Bodo1967
PostPosted: Sat Sep 19, 2020 12:39 pm    Post subject: Reply with quote  Mark this post and the followings unread
OK, and here's the PCB pics
front side - pleace note I repalce the jumper near the upper egde (close to the manufacturer's code) with a cooper track
 Filesize:  397.96 KB
 Viewed:  540 Time(s)
back side
 Filesize:  376.27 KB
 Viewed:  525 Time(s)
front side, populated
 Filesize:  395.95 KB
 Viewed:  495 Time(s)
back side, populated. I resoldered everything again today, and made sure there are no solder blobs. Didn't change anything though.
 Filesize:  379.93 KB
 Viewed:  505 Time(s)
