ESP/Rod Elliot Spring Reverb Stripboard Problems
Page 1 of 1 [2 Posts]
artilect99
PostPosted: Sun Aug 09, 2020 8:23 am    Post subject: ESP/Rod Elliot Spring Reverb Stripboard Problems Reply with quote  Mark this post and the followings unread
Hi all, I recently put together this spring reverb driver/recovery amp circuit from Rod Elliot. It seems to be working but I am getting a lot of high frequency noise (hiss/squealing) on the output, and the NE5532 is getting hot to the touch. This makes me think either the op amp is oscillating or there is a short somewhere(?) I can't see any solder bridges. Is it possible the decoupling caps are too far away from the IC? I need a second pair of eyes on this, pls let me know if anything jumps out at you from this layout.
stripboard layout
 Filesize:  125.84 KB
 Viewed:  485 Time(s)
schematic
 Filesize:  37.96 KB
 Viewed:  473 Time(s)
artilect99
PostPosted: Tue Aug 11, 2020 12:42 am    Post subject: Reply with quote  Mark this post and the followings unread
anybody? beuller... beuller...
