 Forum index » DIY Hardware and Software » The Repair Shop
Does this snare/hihat schematic look okay?
Page 1 of 1 [8 Posts]
Meehah
PostPosted: Fri Jan 04, 2019 8:19 pm    Post subject: Does this snare/hihat schematic look okay? Reply with quote  Mark this post and the followings unread
Hello.
I'm not sure if this is the correct board for this but it looked to be the best choice.
I have found a schematic for a snare and hihat but would like to make sure it is okay before I build. I don't know all that much about electronics and so was wondering if someone would be able to take a quick glance over it to make sure it looks like it will work? Here is the schematic:
Posted Image
Thank you very much.
gabbagabi
PostPosted: Sat Jan 05, 2019 3:52 am    Post subject: Reply with quote  Mark this post and the followings unread
hi and welcome to this forum,
the schematic "looks" ok,
the noise source is very similar to the nutsNvolts noise source here:
https://www.nutsvolts.com/magazine/article/bipolar_transistor_cookbook_part_5
in the VCA are small changes, the original vca u will find here:
http://www.sdiy.org/richardc64/new_drums/dr110/dr110a1.html
the envelope will work somehow, the 10µF Caps are a kind of big but not a real problem,
the other thing is: the Amplitude of the envelope is dependent of the amplitude of your Trigger-Signal, which could be a problem cos it couldt be easy to loud or to quiet, and it is nothing written there about the trigger amplitude - so u have to try urself - of course on the breadboard first
 Filesize:  270.8 KB
 Viewed:  750 Time(s)
Meehah
PostPosted: Sat Jan 05, 2019 4:39 am    Post subject: Reply with quote  Mark this post and the followings unread
Thank you very much. I might build it tomorrow and if I do I will post about how it goes.
phobos
Audio files: 728
PostPosted: Sat Jan 05, 2019 5:35 am    Post subject: Reply with quote  Mark this post and the followings unread
welcome party!
The circuit looked familiar so I looked around a bit and found an older thread about it here.
Also the designer is known as Top Top here on the forum.
The Golden Shrimp Guild
Meehah
PostPosted: Sun Jan 06, 2019 6:40 am    Post subject: Reply with quote  Mark this post and the followings unread
Thank you very much PHOBoS. I’ll have to read that thread.
I just finished it off and it works great. I built exactly as per the schematic but used 1n914s instead of 1n4001s and 4.7uF instead of 10uF as that’s what I had. I built it with the snare capacitor values but will do a hi hat tomorrow. I won’t upload any audio clips as theirs a good demo here: https://youtu.be/B8t38IFALTo. It sounds quite good, though very lo-fi and gritty, what I expected. I’m very pleased with how this turned out and would absolutely recommend it as a first foray into synth drums.
Thank you g-gabba for checking over the circuit, it gave me much more confidence in building it and the links you gave where very interesting and helpful as well.
gabbagabi
PostPosted: Sun Jan 06, 2019 7:32 am    Post subject: Reply with quote  Mark this post and the followings unread
cheers
glad to hear u have entered the sdiy world with a pleasend success
some more drum ciruits u could find here:
http://electro-music.com/forum/phpbb-files/buch_scan_rythm_129.pdf
from this thread:
http://electro-music.com/forum/topic-28541.html&postorder=asc&highlight=twint&start=25
regarding component values, most of the times the circuits will work with values different from the schematic, the outcome often differs only minimal.
e.g last schemo (Bass Drum) in the pdf, the 18nF caps in the bass drum schemo could be replaced by 22nF or two 10nF in paralel (=20nF), insted of 39k resistor u could try 33k or 50k, for the 68K resistor u coul try 50k or 100k, for 27k u could try 22k or two 50k in paralel and so on.
glhf
steved
PostPosted: Mon Jan 07, 2019 8:27 am    Post subject: Reply with quote  Mark this post and the followings unread
I just built a few of those based on that schematic..
It works great for me. I run it from 12v with no problems.
combine the snare with PAiA syndrum and it sounds great
https://www.paia.com/ProdArticles/syndrum.htm
good luck, lmk if you want my pcb layout for that circuit
Meehah
PostPosted: Wed Jan 09, 2019 12:45 am    Post subject: Reply with quote  Mark this post and the followings unread
I finished the hi hat today. I had some issues with constant white noise even when not triggered that I eventually fixed by replacing some capacitors that I believe were at fault. It sounds good as well, I would say better than the snare. Thanks again for the help.
