BassMaster 85
Page 1 of 3 [61 Posts]
Goto page: 1, 2, 3 Next
Hammer
PostPosted: Sun Mar 18, 2018 3:31 am    Post subject: BassMaster 85 Reply with quote  Mark this post and the followings unread
Hello!
My project based on Digispark - ATTiny 85 16MHz arduino programmable.
The main idea is that it's possible to use two PWM outputs for DDS. One of them will be the main wave generator, other will be the envelope shaper.
But I could't find any simple, but good VCA, utill i saw elektrouwe 7052A circuit in this topic: http://electro-music.com/forum/post-405863.html#405863
In MIDI interface you can use channels to tell ATTiny 85 what kind of waves to generate i.e. 1st channel - sine, 4th channel - square, 5th channel - white noise and so on.
Here is short sample (triangle & pulse - lead, square - bass): https://www.youtube.com/watch?v=YfB4YF5tCFE
It was recorded with soviet 561LN2 chip, 4069 sounds not so bright.
BassMaster 85 have just 8kHz bitrate, but LPF and analog VCA helps to eliminate dizzy digital noise.
Here is the circuit diagram. I still not sure, thal levels between ATTiny 85 and TDA 7052 are OK, because triangle is not always triangle, and square wave is not always sharp.
I want to make envelope follower on 1/2 of 4069, and mix this envelope signal to the LPFcontrol via vactrol. Is it a good idea?
Links:
https://github.com/heartscrytech/DigisparkMIDI - DigiMIDI library
https://janostman.wordpress.com/cheap-diy-usb-midi-to-cv-interface/ - how to use DigiMIDI library
http://aeeprojects.blogspot.ru/2011/09/filters-with-cd4069.html - 4069 filter circuits
BassMaster 85 circuit diagram
 Filesize:  121.22 KB
 Viewed:  1115 Time(s)
Hammer
PostPosted: Sat Mar 24, 2018 12:35 pm    Post subject: Reply with quote  Mark this post and the followings unread
BassMaster 85C (chimera) because it is 3/4 digital, 1/4 analog.
Cutoff is driving by ATTiny85, resonance is still manual. JFETs for LPF are soviet again 2П303A, because I haven't others around.
I will post full code a bit later, it's still very dirty.
Check the sound!
BMS85_Test_saw.mp3
 Filesize:  379.96 KB
 Duration: 0:16
 Viewed:  1888 Time(s)
BMS85_Test_square_saw.mp3
 Filesize:  352.46 KB
 Duration: 0:16
 Viewed:  1870 Time(s)
 Filesize:  108.49 KB
 Viewed:  864 Time(s)
Hammer
PostPosted: Sun Apr 08, 2018 1:49 am    Post subject: Reply with quote  Mark this post and the followings unread
Trying to make sound "brighter". I've made another one SVF, but with additional feedback from BP output.
Then I've made "Most simple VCF on earth" to simplify circuit. Now i'ts possible to make my synth in size of credit card.
All three filters sounds and circuit:
BMS85_Test_stereo_LPF_CT.mp3
 Filesize:  606.41 KB
 Duration: 0:16
 Viewed:  1860 Time(s)
BMS85_Test_stereo_LPF_SVF.mp3
 Filesize:  450.78 KB
 Duration: 0:16
 Viewed:  1885 Time(s)
BMS85_Test_stereo_LPF_SVF_2.mp3
 Filesize:  526.79 KB
 Duration: 0:16
 Viewed:  1867 Time(s)
 Filesize:  100.73 KB
 Viewed:  923 Time(s)
petegaggs
PostPosted: Tue Apr 10, 2018 9:50 am    Post subject: Reply with quote  Mark this post and the followings unread
this is very cool, you have managed to make something that sounds really good with very few parts
Hammer
PostPosted: Wed Apr 11, 2018 7:15 am    Post subject: Reply with quote  Mark this post and the followings unread
I hope so! Thank you a lot!
I'll be back soon with full circuit and code.
Hammer
PostPosted: Mon May 07, 2018 1:26 am    Post subject: Reply with quote  Mark this post and the followings unread
Prototype soldered:
 Filesize:  224.64 KB
 Viewed:  807 Time(s)
Mynasru
PostPosted: Fri May 11, 2018 3:32 am    Post subject: Reply with quote  Mark this post and the followings unread
Super nice project!! Any updates on the code and circuit diagram? Can't wait to build this Very Happy
Hammer
PostPosted: Fri May 11, 2018 10:22 am    Post subject: Reply with quote  Mark this post and the followings unread
You know, I was stucked with VCF. This "Most simple VCF on earth" is very noisy. And I can't understand corellation between the lead envelope and LPF envelope to make it more "moogy".
Anyway, here you will find the code, but it's still very raw.
In ZIP you will find corrected library for USB MIDI, original I've got here, thanks to heartscrytech for great work: https://github.com/heartscrytech/DigisparkMIDI
When you upload sketch into Digispark, your PC will find new device. In FL Studio set a port for MidiStomp, I use port #5. Open attached example for FL Studio.
Channel #1 - sine
Channel #2 - triangle
Channel #3 - saw
Channel #4 - square
Channel #5... - effects
Decay is not working now. Dig the code, you will find envelope tables for lead and for filter.
Combining white noise and other waveshapes, it's possible to make new instruments! Let me know, if you will make something new!
 Filesize:  62.42 KB
 Viewed:  724 Time(s)
BASSMASTER.zip
 Filename:  BASSMASTER.zip
 Filesize:  184.77 KB
 Downloaded:  791 Time(s)
Mynasru
PostPosted: Fri May 11, 2018 1:13 pm    Post subject: Reply with quote  Mark this post and the followings unread
Sweet, thank you! I'll try it out.
StormB
PostPosted: Mon May 14, 2018 1:44 am    Post subject: Reply with quote  Mark this post and the followings unread
Hi
i have built the Bassmaster 85CT from your last Post
after upload the code into the Attiny85 i check the functions and
I can switch between the Waveforms Nice Cool and
I can play various Notes but the
Attack and Release pots don't work
if I turn the pot which one goes to pin 1 of the Attiny85 (A0)
over the half the Attiny lost her connection to USB if I turn
the pot back the bassmaster go on!
thanks for this work
Hammer
PostPosted: Mon May 14, 2018 2:06 am    Post subject: Reply with quote  Mark this post and the followings unread
Hello, StormB!
It's mean, that your AtTiny 85 is working properly!
A0 - reset pin. You are resetting your chip by the pot. There are two versions of Digispark, with unlocked reset pit (you may flash it with USBasp), and with locked by fuses. Locked version could be flashed only by high voltage programmer, but it lets you to use reset pin as input / output.
In your version, you can use only one pot.
In code change:
#define ENVELOPE_ATTACK A0 // Pot
#define ENVELOPE_DECAY A1 // Pot
To:
#define ENVELOPE_ATTACK A1 // Pot
#define ENVELOPE_DECAY A0 // Pot
And it will be possible to attenuate attack. I'm using single pot too.
Also, you can make a switch between Digispark and VCF - very useful!
StormB
PostPosted: Mon May 14, 2018 2:59 am    Post subject: Reply with quote  Mark this post and the followings unread
Hi
i have change the inputs now the Attack pot is working Very Happy
i upload the Sketch with my Arduino (Arduino as ISP)
it is possible to make the release shorter
Hammer
PostPosted: Mon May 14, 2018 3:19 am    Post subject: Reply with quote  Mark this post and the followings unread
Yes, find in code:
ADC_LFO = 32;
Increase this number. Than higher number, than shorter decay.
StormB
PostPosted: Wed Jun 06, 2018 12:19 am    Post subject: Reply with quote  Mark this post and the followings unread
Hi Hammer,
it is possible to Change the Attack Pot to Decay Pot ?
think is a better Feature as Attack
Thanks
StormB
Hammer
PostPosted: Wed Jun 06, 2018 12:30 am    Post subject: Reply with quote  Mark this post and the followings unread
Yes, it's possible/
Find:
if (PLAY == HIGH) // ATTACK
And before it add:
ADC_LFO = 800;
It will give you fixed attack, bigger number - faster attack.
Find:
if (PLAY == LOW) // RELEASE
And before it add:
ADC_LFO = analogRead(ENVELOPE_ATTACK);
if (ADC_LFO < 4) ADC_LFO = 4;
Now I have "soviet Moog", analog synthesizer "Ritm-2". And now I can model filter envelope. So, I think that the code will be updated )
StormB
PostPosted: Wed Jun 06, 2018 9:24 am    Post subject: Reply with quote  Mark this post and the followings unread
Hi
it this right
i have disable
//ADC_LFO = analogRead(ENVELOPE_ATTACK);
//if (ADC_LFO < 4) ADC_LFO = 4;
and
//ADC_LFO = 32;
Code:
ADC_LFO = 800;
if (envelopeINDEX <256>> 2;
envelopeINDEX = envelopeACC >> 7;
envelopePWM = pgm_read_byte(&adsr[envelopeINDEX]);
if (envelopePWM < _envelopePWM){envelopePWM = _envelopePWM;}
else {envelopePWM = 255;}
_envelopePWM = envelopePWM;
//ADC_LFO = 255 - analogRead(ENVELOPE_DECAY);
//if (ADC_LFO < 16) ADC_LFO = 16;
//ADC_LFO = 32;
Thanks
Hammer
PostPosted: Wed Jun 06, 2018 9:28 am    Post subject: Reply with quote  Mark this post and the followings unread
Yes, this is right. If you want to make decay not so "fast", use:
ADC_LFO = analogRead(ENVELOPE_ATTACK) >> 3;
StormB
PostPosted: Wed Jun 06, 2018 9:39 am    Post subject: Reply with quote  Mark this post and the followings unread
hi
i have upload the sketch and now after I plug the bass master into USB I have always a tone that never stopp....
Hammer
PostPosted: Wed Jun 06, 2018 9:53 am    Post subject: Reply with quote  Mark this post and the followings unread
Try this code.
BASSMASTER_85CT_DECAY_ONLY.zip
 Filename:  BASSMASTER_85CT_DECAY_ONLY.zip
 Filesize:  5.44 KB
 Downloaded:  695 Time(s)
StormB
PostPosted: Wed Jun 06, 2018 10:00 am    Post subject: Reply with quote  Mark this post and the followings unread
hidiho
I would have a mistake between 2 cable Embarassed
the code is running
Hammer
PostPosted: Sat Jun 09, 2018 1:52 am    Post subject: Reply with quote  Mark this post and the followings unread
My experience with Ritm-2 shows me that BassMaster should have standalone filter EG. It needs a new filter. Can you recommend some good 5V filter circuit? Or better to go to the bipolar power supply?
Hammer
PostPosted: Mon Jun 25, 2018 6:06 am    Post subject: Reply with quote  Mark this post and the followings unread
I think that laser cutted vinyl is good for case and deck building!
 Filesize:  764.95 KB
 Viewed:  627 Time(s)
Hammer
PostPosted: Thu Aug 09, 2018 3:10 pm    Post subject: Reply with quote  Mark this post and the followings unread
I want to convert BassMaster into something more useful. 5V USB power is very noisy, LPF is noisy, 8kHz DDS synthesis is very noisy...
So, what I want to do:
1. Extrnal dual power supply.
2. Make VCO more analog.
3. Make good LPF.
4. Play MIDI file from SD card.
5. Make it compatible with RhythmMaster 85.
6. Keep it all as simple as it possible.
I've started with dual power supply. I've just soldered together cheap MT3608 DC-DC Step Up converter and virtual ground circuit (it's very similar to RITM-2 power supply) of Sijosae: https://tangentsoft.net/elec/vgrounds.html
Tested with op amp saw VCO - no any noise!!!
 Filesize:  954.52 KB
 Viewed:  607 Time(s)
ixtern
PostPosted: Mon Aug 13, 2018 1:18 am    Post subject: Reply with quote  Mark this post and the followings unread
3. Make good LPF.
Nice piece of work. As you have dual power supply range of possible circuits is much wider than with +5V only.
Attaching simple VCO and VCF diagrams, may will be some help. Also simple +5V VCF from gasboss, don't know if any use of it.
I haven't made any of them, just collecting schematics Smile
 Filesize:  17.74 KB
 Viewed:  598 Time(s)
 Filesize:  1.16 MB
 Viewed:  688 Time(s)
 Filesize:  31.41 KB
 Viewed:  616 Time(s)
ixtern
PostPosted: Mon Aug 13, 2018 1:23 am    Post subject: Reply with quote  Mark this post and the followings unread
One more simple VCF I've found - with CMOS ICs.
 Filesize:  4.72 KB
 Viewed:  30679 Time(s)
