BlacKcaT
Posted: Wed Jan 24, 2018 5:13 am Post subject:
| hey Nardu, you are a master! I will swap the TL084 with a TL074 without any change. Is this ok? |
Nardu
Joined: Feb 28, 2011 Posts: 62 Location: Braila, Romania
Nardu
Posted: Thu Jan 25, 2018 1:17 am Post subject:
RYO 2X VCA_v.3 stripboard Lochmaster |
Sorry, I found 2 errors: LM324, TL084 must be rotated 180 degrees (in all variants), a wrong connection to VR7 and VR8.
Here,
- RYO 2x VCA top v.3 revised. The attachment RYO 2X VCA_v.3 stripboard.zip, contains the LM4 file.
- RYO 2x VCA v.3 helper, like silkscreen. Print from ryo 2x vca_v.3 silkscreen helper.pdf file 1:1, crop to edges and stick the corners on top side.
Note!, are some connections on bottom side (in all variants).
Use Viewer for LochMaster for printing
| RYO 2x VCA v.3 helper, like silkscreen, stripboard, Lochmaster |
179.9 KB |
| Viewed: |
838 Time(s) |
| RYO 2x VCA top v.3 revised, stripboard, Lochmaster |
373.42 KB |
| Viewed: |
855 Time(s) |
 Download (listen) |
| Filename: |
ryo 2x vca_v.3 silkscreen helper.pdf |
220.18 KB |
| Downloaded: |
797 Time(s) |
| RYO 2X VCA v.3 revised, LM4 file, stripboard, Lochmaster |
 Download (listen) |
| Filename: |
RYO 2X VCA_v.3 stripboard.zip |
382.77 KB |
| Downloaded: |
810 Time(s) |
_________________ http://nardusynth.blogspot.ro/ |
Ayab
Posted: Fri Jan 26, 2018 3:49 pm Post subject:
Hi Nardu - Greetings and thank you for your generosity sharing these!  |
Nardu
Posted: Sun Jan 28, 2018 3:31 am Post subject:
RYO 2X VCA_v.3 stripboard Lochmaster, helpers |
So you do not miss any spilt points, use this helper. Print from ryo 2x vca_v.3 split points helper.pdf file to 1:1 scale, crop to edges and stick the corners on bottom side.
Note! For any prints for the bottom side you must press the mirror button (vertical)
Use in Lochmaster the Print function (ryo 2x vca_v.3 printing tips.png)
| Lochmaster 4.0 printing tips & helpers |
106.85 KB |
| Viewed: |
851 Time(s) |
| Lochmaster 4.0 printing tips |
168.96 KB |
| Viewed: |
863 Time(s) |
 Download (listen) |
| Filename: |
ryo 2x vca_v.3 split points helper.pdf |
72.02 KB |
| Downloaded: |
786 Time(s) |
Ayab
Posted: Mon Jan 29, 2018 9:24 am Post subject:
Very helpful thank you
Unfortunately have to change heating element in soldering iron before can do any more circuits! Have replacement hope repair goes well! |
Nardu
BlacKcaT
Posted: Sun Feb 04, 2018 4:43 am Post subject:
This design is going to be more and more interesting!
I have a question Nardu, why you choose to use two different op-amp in there? I mean, TL082 and LM324? It is possible, in this design, to use 2 identical one (the TL or the LM), without any change?
thank you for your effort! |
Nardu
Nardu
Posted: Mon Feb 05, 2018 12:49 pm Post subject:
Replace LM324 & TL084 |
Analyzing the circuit RYO VCA, LM324 (cheaper) is used for CV, work with DC; is not critical. TL084 works with audio and the noise figure (NF) is important; affects the signal-to-noise ratio (SNR). TL074 has lower noise than TL084.
Now, by looking at the calibration instructions - pages 13 & 14, I deduce that you can use other compatible CIs. _________________ http://nardusynth.blogspot.ro/ |
Nardu
Posted: Tue Feb 13, 2018 2:41 pm Post subject:
Another approach to this project for - an interesting idea on 8HP EuroRack Otto's DIY EuroRack Modules - Facebook Otto's DIY Eurorack User Group
Possible 4xRYO VCA
266.61 KB |
| Viewed: |
591 Time(s) |
516.23 KB |
| Viewed: |
693 Time(s) |
gabbagabi
Posted: Wed Feb 14, 2018 1:51 am Post subject:
| nice one! |
BlacKcaT
Posted: Thu Feb 15, 2018 11:00 am Post subject:
Din't expect to see so much effort! You'r a king Nardu!  |
Nardu
kamielsd
Posted: Mon Jul 16, 2018 3:33 am Post subject:
| Hi, I just more or less finished recreating RYO 2x VCA top_v.3_corect1.jpg, but when testdriving without the ic's placed it keeps igniting r1. i checked for any short circuit but couldn't find anything, eventually tried minus c1 and c3, but same results, any suggestions? |
kamielsd
Posted: Tue Jul 17, 2018 8:04 am Post subject:
| allready found the problem, accidently manage to short 2 rows somewhere else on the board |
