gabbagabi
Posted: Mon Oct 16, 2017 10:50 am Post subject:
rip-of of the uneven part of Ken Stones wavemultiplier Subject description: sound sample added |
hi,
i recently stumbled over the ken stones wavemultiplier.
The uneven harmonic part looked exactly like the circuits i like.
After simulation i did it directly on pcb and it worked well.
47.78 KB |
| Viewed: |
805 Time(s) |
611.35 KB |
| Viewed: |
875 Time(s) |
gabbagabi
Posted: Tue Jul 17, 2018 1:15 am Post subject:
today i have this finally plugged in.
i really like what it does, with a vca in front that gently modulates the inputsignal
the pcb i did back then was an experiment to find out if the pcb could be the frontplate at the same time, the answer is - it could
i normalized the pcb today and will attach both
i included the mirror version - be shure wich one u use before etching
since it uses tl074 it dosent matter so much on the normalized pcb, but on the other the pot would work backwards
 Download (listen) |
| Filename: |
ueh_part.pdf |
1.04 MB |
| Downloaded: |
649 Time(s) |
 Download (listen) |
| Filename: |
ueh.pdf |
1.02 MB |
| Downloaded: |
655 Time(s) |
 Download (listen) |
| Filename: |
ueh parts small.pdf |
1.11 MB |
| Downloaded: |
696 Time(s) |
 Download (listen) |
| Filename: |
ueh small.pdf |
1.09 MB |
| Downloaded: |
683 Time(s) |
MapacheRaper
Posted: Tue Jul 17, 2018 4:46 am Post subject:
Another one for the TODOs folder. Cool!
The one of CGS is a ripoff of Haible so don´t be shy
I don´t understand why you need a VCA in the forefront thought. It´s to get some exponential conversion?. What happens if you feed it directly without the VCA? |
gabbagabi
gabbagabi
cygmu
Posted: Mon Jul 30, 2018 12:30 am Post subject:
Great!
This circuit has a special place in my heart -- it was the first thing I ever breadboarded, along with a simple trii-square oscillator, when I first got into this stuff.
This folder design originated with Serge I believe. Ken Stone explains on his web site that he was trying to reproduce the function of the Serge wave multipliers (middle section) when he came up with this circuit... and then to his surprise discovered that his solution was almost identical to the Serge schematic.
The Haible folder is a bit of a different beast. The Buchla one produces a similar effect in a very different way. |
