Posted: Tue Apr 18, 2017 11:25 pm Post subject:
Fireware?  |
Posted: Wed Apr 19, 2017 3:11 am Post subject:
Centre ground is the global default standard for pedal power supplies. Boss use this, and they have ungodly market saturation.
The reason is that most DC sockets have a switching contact for the ring, but not the tip. So this means that if you are tip-ground, then you can switch the switching ring contact for the positive rail from the 9V battery in or out of the circuit, depending on whether a external power supply is connected. (Using the Ring of the actual guitar in jack switches the battery on and off, not whether it is connected to the circuit or not.)
It's very, very rare to have ring-ground wiring in guitar pedals. You'll usually see it only in -9V pedals, like Dallas Rangemaster clones (and then, the power supply used has to be isolated from the power supply used for +9V pedals in the same signal chain.)
Sorry if I'm being obscure. |
Posted: Wed Apr 19, 2017 3:32 am Post subject:
Ok, thank you for your input, it makes completely sense!
Learned something today  |
Audio files: 730
Posted: Wed Apr 19, 2017 7:03 am Post subject:
I've wondered about this too since it seems to make more sense to use the outside connection for -/GND and the center
pin for +. But for a guitar pedal where the ring of the in jack is used as the power switch (which I always thought of as
a brilliant solution) it does indeed make sense to reverse the power connections, actually it is the only way it can work.
Thanks alan I learned something too  _________________ "My perf, it's full of holes!"
The Golden Shrimp Guild |
Joined: Aug 08, 2009 Posts: 1082 Location: Out scouting . . .
Posted: Thu Apr 20, 2017 5:18 am Post subject:
Excellent point of discussion about the output of power supplies. Interesting insights about the "normal" standard about "wall warts" for guitar pedals; you are a wealth of knowledge, alanp.
Ages ago my first few power supplies for gear were all DC, center negative. I noticed however that phone answering machines tended to be AC. In fact when I needed a replacement for my ART X-15 [midi foot pedal/button thing, aka UltraFoot], the original was 9v AC.
However, the power supply requirement design was rather amazing:
| Quote: | Power
If you find you must replace the power adapter, make sure
the specifications meet or exceed the specifications of the
original adapter. The ART X-15 was designed to work with
just about any battery eliminator.
The Pedal will work with eliminators that produce a minimum
100 milliamperes (ma) of Alternating Current (AC or VAC) at
6.3 to 15 volts or Direct Current (DC or VDC) at 9 volts to
24 Volts. |
I don't think I have seen any gear as flexible since! But it does go to show that if manufacturers wanted to, evidently they could design gear to accommodate such flexibility, I would assume.
Also, there are some "universal battery eliminators" that have plugs that can be used to swap the polarity (as well as switch the voltage output).
I am not a DYI builder, but I think if I were designing something for use with wall-warts, I'd want a flexible power supply design--if it's at all possible. I imagine it might be more expensive, but in the long run, it might be worth the money to protect stuff--again, if it's possible.
And that's my 2 cents work. Excellent topic of discussion.
Steve |
JovianPyx
Audio files: 237
Posted: Thu Apr 20, 2017 7:31 am Post subject:
I've seen this several times. It works because while AC is turned into proper polarity DC by going through a rectifier, DC can also pass through the rectifier as well and an additional benefit is that the DC polarity doesn't matter, it gets corrected by the rectifier. There are actually many devices out there that will work with either AC or DC inputs, but they just don't say so.
I've never assigned the attribute "normal" to any PSU connection scheme. It is what it's designer needed it to be either for technical reasons or because "Hey, let's use THAT one because we have two thousand in boxes in the back".
The real fun was in the "old days" when car battery systems were either 6 volt or 12 volt and some had negative ground while others had positive ground. Had to be really careful when jump starting back then. _________________ FPGA, dsPIC and Fatman Synth Stuff
Posted: Thu Apr 20, 2017 12:49 pm Post subject:
"Positive ground" and "negative ground" are a whole 'nother kettle of fish. I've never liked those terms, they confuse people (and me) too much. Ground is a zero volt reference. The power rails can be either positive or negative, though.
It's like diodes and LEDs. The cathode might be connected to ground, or the anode might be. So it's a bit much to talk about the "positive leg" of the diode. |
Posted: Thu Apr 20, 2017 1:40 pm Post subject:
To make it more confusing: People say that current flows from positive to negative, but since the charge comes from electrons (which are charged negative!) the real current flows from negative to positive  |
gdavis
Posted: Thu Apr 20, 2017 2:17 pm Post subject:
| Grumble wrote: | To make it more confusing: People say that current flows from positive to negative, but since the charge comes from electrons (which are charged negative!) the real current flows from negative to positive  |
Current flow and electron flow are two different things (even though they are related). Positive current flow is the direction of positive charge flow. The fact that the charge carriers happen to be negatively charged and move in the opposite direction is irrelevant from an electrical circuit standpoint.
If the charge carriers where positively charged, the current flow would still be positive to negative, just the direction of the carriers would change.
It's really all arbitrary anyway. The reason for it is that the polarity of protons and electrons where chosen (arbitrarily) before we learned that it was the electrons that were mobile.
There was a time when some considered the current flow as the same direction as electron flow, but this convention has mostly fallen out of favor. _________________ My synth build blog: http://gndsynth.blogspot.com/ |
JovianPyx
Audio files: 237
Posted: Thu Apr 20, 2017 3:10 pm Post subject:
| AlanP wrote: | "Positive ground" and "negative ground" are a whole 'nother kettle of fish. I've never liked those terms, they confuse people (and me) too much. Ground is a zero volt reference. The power rails can be either positive or negative, though.
In fact, whether "positive" or "negative" ground, the ground "rail" is always zero volts. It's a point of reference and that is all it is. In a positive ground system, the other rail is a negative voltage. So what? When I was a kid, I remember when transistors started to appear as commercial products. The first ones I had access to were PNP, so amplifiers normally had a single rail which was negative and a ground (which was in fact, positive).
Ground is nothing more than a point of reference. Think of positive ground as the same as a bipolar supply system without the V+ rail. In that case, ground is POSITIVE with respect to the other rail. There is no necessity, culturally, technically, linguistically or otherwise that forces ground to be negative - and again - what about a bipolar supply? In that case, ground is both positive and negative... That is a very confusing way to look at it. Look at it as a simple reference point and it will become clear. _________________ FPGA, dsPIC and Fatman Synth Stuff
