Simple resonant low pass filter
Page 1 of 1 [8 Posts]
synaesthesia
Audio files: 87
PostPosted: Sat Mar 11, 2017 10:12 am    Post subject: Simple resonant low pass filter
Subject description: using only 16-bit integer arithmetic
Does anybody know a good resonant low-pass filter using only 16-bit integer arithmetic? The code below is what I currently use.
It sounds quite good already, but it needs a bit of taming (the division by 3) because it otherwise easily overflows during 16-bit calculations.
Code:
// in the main loop
// get unsigned values for fcut and qfilter in range 25..250
feedback = qfilter + ((qfilter*128)/(256-fcut));
// in the interrupt, use input value in range 0..255
int sample = (input-128)/3; // shift to -128..127 and scale by /3
// buf0 and buf1 are static integers
buf0 = buf0 + (fcut*((sample-buf0) + (feedback*(buf0-buf1)/256))/256);
buf1 = buf1 + (fcut*(buf0-buf1)/256);
int output = (buf1+128)&255; // shift signed result back into range 0..255
Instead of the division by 256, a shift right by 8 bits can be used of course, but it must be an arithmetic shift to preserve the sign bit.
JovianPyx
Audio files: 237
PostPosted: Sat Mar 11, 2017 3:00 pm    Post subject: Reply with quote  Mark this post and the followings unread
What CPU?
Take a look at dspic33FJ128GP802. It's a 16 bit CPU that runs as fast as 40 MIPS. That particular part number is for the 28 pin DIP package, so it's quite DIY friendly. I've written a state variable filter for it in assembly language and it works wonderfully well. The filter I wrote also uses the full 16 bits of range for data which is -32768 to +32767. Using Q values higher than 1.0 requires some attenuation of the input signal. There is information about this filter here: http://www.earlevel.com/main/2003/03/02/the-digital-state-variable-filter/
Time flies like a banana.
corruptio optimi pessima
synaesthesia
Audio files: 87
PostPosted: Tue Mar 21, 2017 11:28 am    Post subject: Reply with quote  Mark this post and the followings unread
I am using a PIC24FJ64GA002 right now, but I am looking for generic code that can run on any controller without foating point support.
By the way, I had to change the scaling to /4 because even with an input scaled by /3 the filter sometimes overflows the internal values, for example when an envelope with a very steep attack phase is used.
VA1
PostPosted: Wed Aug 29, 2018 3:02 am    Post subject: Reply with quote  Mark this post and the followings unread
You mean with resonance the overflow occurs.
I heard a FIR filter will stay in limit, IIR is problems.
FIR has more delay and more CPU.
i dont know how FIR behaves with resonance ?
this is always a big problem, some filters has it covered somehow, still finding out how.
i am no filter expert.
You should adjust levels per project, lower the max reso and so on to get some results.
My filter adjust levels per waveform, i have the same problem.
Maybe you can try http://www.microchip.com/forums/m1003759.aspx
JovianPyx
Audio files: 237
PostPosted: Wed Aug 29, 2018 8:39 am    Post subject: Reply with quote  Mark this post and the followings unread
IIR filters like the SVF have a property called "Q enhancement". This means that as the Q is raised, the amplitude of the signal at Fc also increases. The gain of the system at Fc becomes greater than 1.0 as Q is increased. This can easily cause overflow. Attenuation is the only way to handle this. You may be able to handle this automatically with a table that relates Q values back to an attentuation value. This can be tricky to handle with fixed point (integer based) arithmetic and still maintain a signal that is close to saturation.
VA1
PostPosted: Mon Oct 22, 2018 8:15 am    Post subject: Reply with quote  Mark this post and the followings unread
My filters make weird beeping noises sometimes, you can hear it when no audio is playing, like it hangs,
when you press note it can be gone.
These sounds are also hearable very soft in the audio.
What is this with my IIR filter ?
Normally for float on PC you have to normalize ( remove small values ),
i dont have this in my filter, mabe its needed somehow ?, i dont wanto waste a if.
Audio files: 353
PostPosted: Mon Oct 22, 2018 9:20 am    Post subject: Reply with quote  Mark this post and the followings unread
Normalization is for floats only .. and only on some floating point units (like the 8087 stuff on a PC which gets very slow for denormal numbers), it is not needed for fixed point arithmetic, as there are no denormal numbers in fixed point.
VA1
PostPosted: Tue Oct 23, 2018 5:30 am    Post subject: Reply with quote  Mark this post and the followings unread
Thanks, i,m still figuring out why my filter is so noisey.
