Jarre, Equinox 5 how to make this sound
Page 1 of 1 [5 Posts]
PostPosted: Sun Mar 13, 2016 11:52 pm    Post subject: Jarre, Equinox 5 how to make this sound
Subject description: without buying a MOOG system
Can anybody tell me how to make the sound you hear in the beginning of Equinox 5 from Jean Michelle Jarre? It's such a great thunder Very Happy
Without buying a MOOG system?
What are the physics behind this sound?
I mean, start with a noise generator>>filter>>VCA.... or?
thunder.mp3
Jean Michelle Jarre - Equinox 5
 Filesize:  71.45 KB
 Viewed:  1533 Time(s)
PostPosted: Mon Mar 14, 2016 9:10 pm    Post subject: Reply with quote  Mark this post and the followings unread
My initial guess is something sampled, and then sloooowed down.
PostPosted: Mon Mar 14, 2016 11:00 pm    Post subject: Reply with quote  Mark this post and the followings unread
Could be, but that would be just part of it because you loose the higher frequencies and listening (and looking with audition) at this sample tells me there is something more going on....
ian-s
Audio files: 43
G2 patch files: 626
PostPosted: Tue Mar 15, 2016 12:04 am    Post subject: Reply with quote  Mark this post and the followings unread
Try white noise > clipper > filter > vca
I seem to remember getting similar crunchy thunder sounds using the MS20 external signal processor module set to full gain. Reverb also helps.
DES
PostPosted: Thu Mar 24, 2016 10:39 am    Post subject: Reply with quote  Mark this post and the followings unread
As the noise is being fed into the reverb, try slapping or bumping the reverb tank... Not sure how the original was done but probably possible with the Arp 2600. Or feed a patch into a guitar amp with reverb.
www.davesneed.com
