 Forum index » Clavia Nord Modular » G2 Performances - Completed
Aria
Page 1 of 1 [3 Posts]
ian-s
Audio files: 43
G2 patch files: 626
PostPosted: Fri Sep 11, 2015 2:52 pm    Post subject: Aria
Subject description: mustache, big mustache
Roland has a product line called Aria. This prf2 has nothing to do with that.
aria.prf2
Yanni?
 Filename:  aria.prf2
 Filesize:  32.85 KB
 Downloaded:  4615 Time(s)
varice
Audio files: 29
G2 patch files: 54
PostPosted: Fri Sep 11, 2015 11:21 pm    Post subject: Reply with quote  Mark this post and the followings unread
wow!
Thanks for sharing this Ian...
varice
ian-s
Audio files: 43
G2 patch files: 626
PostPosted: Fri Jan 27, 2017 11:11 pm    Post subject: Reply with quote  Mark this post and the followings unread
The original used inter-slot midi CC to route the drum info, from slotA to slotC fx area, which resulted in a kind of drunk drummer feel. I have re-patched using the D2A => audio bus => A2D technique so it is tighter. Also the vocal counter melody was getting lost in steep dip in the vowel filter so I added a compressor to even it out. The bongos velocity was patched wrong as well. Embarassed
aria.prf2
new version.
 Filename:  aria.prf2
 Filesize:  32.89 KB
 Downloaded:  4117 Time(s)
