808 Cowbell Eagle Layout
Page 1 of 1 [2 Posts]
jbeuckm
Audio files: 9
PostPosted: Mon Aug 17, 2015 8:49 pm    Post subject: 808 Cowbell Eagle Layout Reply with quote  Mark this post and the followings unread
I have a euro layout for the 808 cowbell that must be fairly close to working. If I press fingers to short the two oscillators to the output, I can hear and tune each. But I can not trigger any sound with the trigger and accent inputs. On the Yocto project schematics, I noticed that the trig (accent?) input has a different circuit than the rest of the drums. Can someone tell me what this part of the trig input does?
For the other 808 voices, I have been able to use a DC voltage for accent or the same scaled gate signal that I use for trigger. (I get a scaled gate signal from the "drums" configuration of a PAiA 9700.)
Here are my Eagle files: https://github.com/jbeuckm/808-Cowbell/tree/master/eagle (DELETED)
UPDATE: This part of the 808 "TRIG" circuit scales the accent voltage up to 5-15 for the cowbell and cymbals.
 Filesize:  12.43 KB
 Viewed:  5823 Time(s)
jbeuckm
Audio files: 9
PostPosted: Wed Apr 20, 2016 7:47 pm    Post subject: Reply with quote  Mark this post and the followings unread
I restarted this from scratch and now it works. One-sided Eurorack format PCB with tunable components VERIFIED.
Eagle files:
https://github.com/jbeuckm/808_CB/releases/tag/v0.1
 Filesize:  104.25 KB
 Viewed:  441 Time(s)
