Yet another sequencer ((edit: answered) question) thread
Page 2 of 2 [29 Posts]
Goto page: Previous 1, 2
Lysol
PostPosted: Sat Aug 01, 2020 12:02 pm    Post subject: Reply with quote  Mark this post and the followings unread
I gave this schem a go on the breadboard as well, which I believe is basically the same principle for cascading them as seen in the 4017 manual.
However though, i'm still left with a similar problem. It will cycle through all 16 steps just fine, but I can't seem to find a configuration using the reset pins to have control over how many steps it cycles through.
Ultimately, I'm trying to get a 16 step sequencer that has the same toggles as seen in the "Little Gate."
Posted Image
Lysol
PostPosted: Sat Aug 01, 2020 12:21 pm    Post subject: Reply with quote  Mark this post and the followings unread
Or, to get the functionality that I want would it be more wise to just attempt cascading them as outlined in fig. 19 in the manual? (via an AND gate?).
Although the version in the datasheet is different it works somewhat similar and I don't think it would be muich of an improvement.
Yes, this appears to be the situation I found myself in. Same issue using a transistor AND gate to cascade - reset doesn't work.
a much better solution for more steps would be to use a binary counter (4040, 4029, 4520) and a binary to decimal decoder (4514) or a mux (4067) instead of 2 4017s.
I did check and it does appear as though I have a 4040 and a 4051
phobos
Audio files: 728
PostPosted: Sat Aug 01, 2020 12:36 pm    Post subject: Reply with quote  Mark this post and the followings unread
a single 4051 will only get you 8 steps, but there are ways of cascading them.
For 2 muxes it is not very complicated and to do this you use 3 outputs of the binary counter
for the A,B,C inputs of both muxes and use another output of the counter to control the INH pin
which has to be inverted for 1 of the muxes.
The Golden Shrimp Guild
dadinfinitum
PostPosted: Wed Jul 05, 2023 11:17 am    Post subject: Reply with quote  Mark this post and the followings unread
I have a couple elementary questions, and at least is in reference to the cascading 4017s at the beginning:
- CV out is simply taking each output of the 4017, running it through a pot and diode, and connecting all of those, right?
- can you create a gate output by taking the CV output and ANDing it with the clock? Anything extra that needs to happen there?
- with the cascading 4017s, how do the CV outputs work? I understand that you can have two different outputs for each of the 8 steps, but how does the output work for the 16 step?
Thanks in advance!
