Audio files: 9
Posted: Thu Jan 14, 2016 6:32 am Post subject:
This seems like the perfect project for collaboration. I entered the schemo into Eagle and I'll try to make a one-sided layout for easy DIY. I uploaded the files to a git repo and it would be great for others to add their ideas.
Audio files: 9
Posted: Thu Jan 14, 2016 6:50 am Post subject:
I think this switch would be ideal -- it's a big, solid toggle that could be edge mounted and only take 8mm width. I'm looking for an Eagle library with this part...
Audio files: 730
Posted: Thu Jan 14, 2016 9:16 am Post subject:
That's great! I am thinking of making some PCBs for it, so now I don't have to redraw the schematic in eagle myself
Those would probably be double sided though (costs are the same if I have them made) and for DIY single sided is much
easier so it would be nice to have that option too.
Not sure about the switches, round is an advantage since it sucks to make square holes and I like the short levers,
but switches with some thread on it would make it possible to mount them to a panel without having to add some extra
mounting holes. Having them at and angle is also good to save panel space in case the PCB gets a bit large which can
easily happen with CMOS and a single sided PCB.
ow and I must have missed the nice PCBs piedwagtail made, those look great!
I've had great difficulties sourcing the slide switches in any quantity.
It rather put me off offering them and as you say the panel hole is a much easier option to plan for.
Yes, those switches are the ones, from a quick glance.
Audio files: 9
Posted: Thu Jan 14, 2016 9:40 am Post subject:
I would also prefer threaded switches for panel mounting, but I haven't seen threaded vertical right angle under $6. I'm thinking I can get 10 of these with a threaded 3.5 jack on each end in the height of a euro panel. (The two jacks would hold the PCB)
clkIn-1-2-3-4-5-6-7-8-9-10-Out
Then a daughterboard with the other jack and switches...
onoffSw-loopSw-resetIn-shortlogSw Last edited by jbeuckm on Thu Jan 14, 2016 11:10 am; edited 1 time in total
It may encourage you to add leds.
I used a double pole switch so the gate on steps in red can be seen at a glance.
White is running.
Purple is sequencer output.
Use a dpdt on-off-on, stick rail to centre and led plus resistance on gate position.
High brightness leds require 22k or so, the camera up close makes them look bright but it's soft enough.
You could do last step on the loop side but I felt the run leds return was sufficient for that.
Use bussed SIL networked resistors for your droppers. I used 9 way ten pin with an extra resistor for those reds. Saves pcb space.
Toggles are so expensive but the play against availability, price and panel problems with slides it's an annoying call. In the end, I didn't want to pay a >$ a switch; I felt multiple PHOBian Little Gate sequencers was the way to go.
Posted: Thu Jan 14, 2016 9:46 pm Post subject:
Working on a gate sequencer layout myself at the moment, based on Fonik's Baby Ten -- mine has two parallel tracks, one with on-none-on switches (for gate on/off), and one with on-off-on, for gate on, gate off, and reset (saves bothering with a rotary, or patching a reset in, or similar.) The 4017 outputs have transistor buffers hanging off them for reinforcement.
Haven't submitted it for fab, yet. It's a two pcb set, due to the amount of stuff on the switch board.
Posted: Sun Jan 17, 2016 9:20 pm Post subject:
I don't etch, so I can get away with doublesided layouts
The jacks are Clock In, Reset, Gate 1 Out, Short Gate 1 Out, Gate 2 Out, Short Gate 2 Out. Short in this case is the normal gate signal AND'ed with the clock. Oh, and the two odd looking pairs of pads are for normally open momentary pushbuttons for step and reset
Still have to submit this for fab... I'm not entirely happy with the thin Reset bus, but can't see a good way around it at the moment.
Filesize:
37.94 KB
Viewed:
482 Time(s)
I see the jacks as holding the pcb, the switches are threadless and would therefore poke out less. Nice idea.
but I'm confused by the output led being perpendicular which suggests a slim desktop enclosure with the unfitted step leds...except the eurorack power port is....
Internal wires I like to use screw terminals 3.81 or 5.08 to allow the pcb to be removed from a panel without having to desolder or de-attach everything. I blame Ken Stone for making me hate soldered up panels.
Audio files: 9
Posted: Thu Jan 28, 2016 8:36 am Post subject:
When I took the picture, only the most necessary parts were installed to make sure the layout worked. Those long wires will be cut to connect the switches and I will desolder the output LED when I wire to the panel. I don't think the jacks and switches are colinear, no.
You can probably tell - I hate wiring I wish there was a convenient way to layout LEDs so I didn't have 22+ wires on this thing One thing I have done in the past is to keep legs long on a 3mm LED near the edge, then bend the legs and push the LED into a 1/8" hole in the panel.
Here is an idea to minimize LED wiring and keep the board one-sided: Move the LED holes under the switch bodies. Trim the LED legs to be long but the same length. Mount the switches first, then set the long-leg LEDs into the holes from the bottom so that the switch body holds them flush with the top of the PCB. Solder the LEDs onto the bottom and bend into holes in the panel. I might try that. But this thing is pretty expensive to build with all those switches!
Filesize:
57.95 KB
Viewed:
484 Time(s)
If there's a problem with space under the switches, you can do away with holes and etch small pads as if the leds were SMT.
This is what I did for the first time with this design; there was too little space under the switches to have through holes and solder, so I placed a hole for one end of the 1n4148s and a pad at the other; worked fine.
Since the panel hole will hold the led body this is an option you have.
