Joined: Jan 07, 2009 Posts: 1231 Location: Scottish Borders
Audio files: 163
Posted: Mon Aug 25, 2014 11:09 am Post subject:
Building a new drum synth Subject description: neinohnein / 808 stripboards / MPS / CYnare / bass++ / DS8 |
Hi there.
Over the past few months, I have been keen to re-design my drum synth I built in 2009. I have had success with building the 808 hi hats / cymbal / cowbell from the great layouts by Minus , I also have soldered together the 808 kick & snare by Eric Archer and recently ordered some of the hex-inverter nein oh nein pcb's.
Once I have finished experimenting with all the mods, I can get the panel stickers finalised for the pot & switch layouts.
Also, in the new box , I will be re-panelling the voices from drum synth V1 (MPS / cynare / Bass++ / DS8).
Here are some pics of the 808 strip boards being hooked up for testing & populating the nein oh nein pcb's.......
991.05 KB |
| Viewed: |
937 Time(s) |
| old bit of panel used for testing controls |
614.67 KB |
| Viewed: |
699 Time(s) |
| Kick / Clap / Rimshot / & battery acid CV (still to construct) |
924.9 KB |
| Viewed: |
715 Time(s) |
Audio files: 163
Audio files: 163
Paradigm X
Joined: Feb 15, 2011 Posts: 363 Location: Null and void
Posted: Sun Aug 31, 2014 1:00 pm Post subject:
nice
i do enjoy these build threads. i want to build a similar box.
nice one, Ben |
Audio files: 163
Posted: Mon Sep 01, 2014 12:56 pm Post subject:
Hi Ben , Thanks .
My first few home made boxes turned out a slight parallelogram shape (a bit of box twisting needed to get the panel sitting straight) but i'am getting a bit better at woodwork now and have learned to use a strip of wood as an angle brace to keep the box internal corners all at 90deg square.
Dave. |
Audio files: 163
Audio files: 163
Audio files: 163
Posted: Tue Sep 09, 2014 11:49 am Post subject:
Hullo .
Horror ... I removed the back panel from drumsynth vers 1 (2009) to remove the power supply thinking an easy job , and I discovered I had installed a 30VA toroidal transformer (almost just enough for that drum synth).
Of course I am now nearly doubling the load with 2 rows of modules, but , after a rake about in one of many electronics boxes in my cupboard, I found a new 100VA toroidal (dual secondary), magic .
I sat down at the desk with a pen & paper and totalled up my expected current use for + line and - line on this new diy drum synth.
Allowing a bit of head room for expansion ( I've designed this drum synth to have a few blank panels for future)
+ line 700mA.
- line 620mA.
Total 1.32 Amps .
The new transformer is a dual 15V / 0V , 100VA toroidal which gives 3.333A max ( that has worked out nice because I always like to have a transformer working at half load or less, also called de-rating).
I will be using a similar design to the big power supply I built for the blue modular system, Raw DC supply distributed with thick wire to several regulator / buss bars.
Below is a pic of the new transformer with a bag of mounting rubber pads & cap plates & bolts ,
the 2nd pic is the Raw DC board which takes the transformer output and rectifies it and smooths it , 4 sets of 3way terminals,will distribute the expected +18V / 0V / -18V Raw DC through thick cable to the regulator busbars , one unfinished one is pictured (the regulators get wired to this board with the green module power connectors)
851.76 KB |
| Viewed: |
666 Time(s) |
880.65 KB |
| Viewed: |
710 Time(s) |
Audio files: 163
Posted: Sun Sep 14, 2014 10:55 am Post subject:
Hi Again.
Had a chance this weekend to work on the power supply.
Finished the little regulator / distro boards and bolted the regulators onto the alum L bar, using a thin scrape of heat paste & mica insulator plates & bushes. The wiring between the Raw DC board & the regulators is 1.5mmSq(csa) 3 core 16Amp flex , same size wire used for connecting the regulators off the board.
The L bar is distanced fixed using 12mm hex nuts as spacers.
From left to right there is 2 sets of dual 15V distros (6 sockets each) / the Raw DC board & the dual 12V distro (5 sockets) , which also has a 78L09 circuit (+9V) for the wee midi to trigger module.
Still to put a safe enclosure round the 240V connections to the transformer primary leads , probably a little choc box type mains connector & a rubber shroud over the IEC rear.
Busy populating the nein oh nein snare pcb now , more pics through the week.
344 KB |
| Viewed: |
684 Time(s) |
417.96 KB |
| Viewed: |
695 Time(s) |
Audio files: 163
phobos
Audio files: 728
Audio files: 163
Posted: Mon Sep 15, 2014 12:04 pm Post subject:
Thanks Phobos |
isak
Posted: Tue Sep 16, 2014 7:50 am Post subject:
Indeed, that really looks great
Will be interesting to see if you'll make the panel blue  _________________ http://www.myspace.com/mgmtrance |
Audio files: 163
Audio files: 163
Posted: Sun Sep 28, 2014 6:39 am Post subject:
Hi
I've been working on the quad bass++ , populating & deciding on mods to add.
Apologies to Bill (state-machine) from Long island, when you sent me the quad board in 2010 you didn't want to see the board in a drawer for 4 years , well the time & project is right for it now .
Left off R24 / C2 / C7 on each of the 4 voices for the wave mod , bump & pip mods & pitch cap increase mod , which I will solder all the mods on a strip of veroboard to bolt on.
I have done a test layout of the panel , instead of putting the quad bass++ across 2 100mm panels, I have robbed the 200mm long bit I was keeping for the mixer area, as usual it's a tight fit , but I think I've got all the controls I need for bass/tomtom sounds I need .
595.39 KB |
| Viewed: |
647 Time(s) |
668.93 KB |
| Viewed: |
625 Time(s) |
Audio files: 163
Audio files: 163
Audio files: 163
Posted: Sun Nov 16, 2014 2:13 pm Post subject:
Hi all , been busy
Stickers done , fixed on and all panels drilled , started the first build ... the pan controls & the mixer & FX panels , all working good apart from 2 pots wired wrong direction fixed now , mounted the midi to trigger pcb in the case and fitted the midi in , din socket round the back of the case , the pcb is powered from it's own 9v supply off the 12V board inside the case .
First drum module finished this weekend, Hexinverter rim shot & clap on one module plate , works great first power up ( all the drum circuits are powered 15V -- FX & mixer are 12V).
I made a mistake on the rim shot panel front , overdrive control pot , I forgot to delete that one when lining up the pots on the design programme , so... I had a stab about with a 20k pot and found R22 (22K) had a resonance sounding change , popped out R22 and replaced with a 20K pot and a 100 ohm limit resistor in series , cool , no blank control now
More updates as I work through the drums....
352.33 KB |
| Viewed: |
597 Time(s) |
502.78 KB |
| Viewed: |
625 Time(s) |
400.77 KB |
| Viewed: |
803 Time(s) |
Audio files: 163
Audio files: 163
Audio files: 163
Audio files: 163
isak
Audio files: 163
Posted: Sun Dec 14, 2014 2:25 pm Post subject:
Thanks Isak , taking time to build , though it sounds great so far.
Dave. |
Audio files: 163
