syrious
Posted: Sun Jul 06, 2014 3:08 pm Post subject:
How to trigger Dumping of Program parameters via CC/Sysex |
Hello there,
I'm looking for a possibility to tell the Nord Lead 4 to send me all parameter values via Midi CC.
Manually, thats possible in the MIDI menu / 6 - Send CC (page 43 in the manual).
Exactly that I need to trigger with a midi cc or if necessary with a sysex message.
How (which midi cc / sysex message) to achieve that?
Is there documentation I missed? |
Joined: Apr 24, 2009 Posts: 2543 Location: Bristol UK
Audio files: 522
Posted: Tue Jul 08, 2014 6:00 pm Post subject:
Hmmm, I am sure the NL4 should be able to do this, but after a quick scan of the manual it seems there is no sysex info there…
You can do a Dump One command from the front panel of course… (also page 43) _________________ Muied Lumens Sub Forum
Bandcamp |
syrious
Posted: Thu Jul 10, 2014 3:00 pm Post subject:
Hello,
however I exactly need to trigger the param transfer in the opposite direction, that is: VST->NordLead
Any ideas / suggestions how to achieve that? |
Audio files: 522
Posted: Thu Jul 10, 2014 5:48 pm Post subject:
Well, as I said, there is nothing in the manual about system exclusive messaging, which seems like an oversight to me... The NL4 certainly accepts sysex.
What you are looking for is an All Controllers Request message, which previous Nord Leads would accept. Either that or a Patch Dump Request.
Maybe time to ask on the Nord Forum perhaps, or Clavia support even.
Sorry I can't help you more, any searches I did turned up blank. _________________ Muied Lumens Sub Forum
Bandcamp |
syrious
Posted: Fri Jul 11, 2014 2:49 am Post subject:
Thanks for the answer.
I still posted in the nord forum where I got no reply and asked Nord Support who couldn't or didn't really want to help me. I also googled for some hours.
At least now you gave me two key words for which I will try to find a sysex message that I can send to the nord lead. |
Audio files: 522
Posted: Fri Jul 11, 2014 4:06 am Post subject:
OK, this is a shot in the dark, but have you tried this?
Byte (Hex)
$F0 $33 $00 $04 $14 $00 $F7
Byte (Decimal)
240 51 0 4 20 0 247
This is the All Ctrl Request message for both the Nord Lead 1 and 2X, so they may have kept it the same. For this specific message the global channel must be 1 and it sends the controllers for Slot A. The global channel (device ID) is the third byte, if you want to change that. _________________ Muied Lumens Sub Forum
Bandcamp |
syrious
Posted: Sun Jul 13, 2014 7:50 am Post subject:
Thanks for your reply..sounds promising..In the first try my sysex I sent didn't affect the nord lead.
I asked for help / example code in another forum as there is no documentation for the framework I'm using to build the VST.
EDIT: Today I got reply from Nord that the "Request All Controllers" command is not available in the Nord Lead 4. So that's it with my project
Btw. thanks Muied Lumens for helping |
syrious
Posted: Fri Jul 25, 2014 2:31 am Post subject:
It turned out that sysex can not be send from my targeted daw (ableton live).
So sysex is no more an option for my problem.
Thread may be closed. |
Audio files: 522
Posted: Fri Jul 25, 2014 6:42 am Post subject:
| syrious wrote: | I asked for help / example code in another forum as there is no documentation for the framework I'm using to build the VST.
EDIT: Today I got reply from Nord that the "Request All Controllers" command is not available in the Nord Lead 4. So that's it with my project. |
What a pity! Perhaps Clavia will include sysex capability in a future update... seems strange not to.
Also, maybe with Max for Live it is possible to do sysex? I don't know Live at all though. _________________ Muied Lumens Sub Forum
Bandcamp |
syrious
Posted: Mon Jul 18, 2016 10:07 am Post subject:
| Eventually I gave up...enough hours burned for nothing...sold the synth |
Audio files: 522
Posted: Sat Jul 23, 2016 9:39 pm Post subject:
| syrious wrote: | | Eventually I gave up...enough hours burned for nothing...sold the synth |
Heh... and I bought one. I had forgotten about this thread, still think it is strange that there is no sysex, have to double check that.
Nothing is for nothing though. Working on problems is never a waste of time, even if you never found a solution. IMO of course. _________________ Muied Lumens Sub Forum
Bandcamp |
