Coming up on Radio 1 at
Trying to figure out Dividers
Page 1 of 1 [8 Posts]
acidblue
PostPosted: Tue Feb 04, 2014 3:06 pm    Post subject: Trying to figure out Dividers Reply with quote  Mark this post and the followings unread
Could some one please explain to me Dividers, specifically the cd4040 divider.
Should I put the reset to ground, (thru a resistor perhaps).
What goes into the clock pin? Is a VCO ok? or does it have to be pulse, like an LFO??
My understanding is it will divide the signal, (VCO?) by 2,4,6,8 and so on
thru Q1-Q12.
How do I connect the outs, (Q1-Q12)?
Can I put them into a mixer?
Will it give me a sequence??
Please forgive my ignorance, I've been looking at data sheets, but
the ones I've looked at dont give an example circuit.
Which is what I need, a few schems would be great.
commathe
PostPosted: Tue Feb 04, 2014 6:16 pm    Post subject: Reply with quote  Mark this post and the followings unread
The 4040 and 4060 are just chained flip flops. From the fairchild semiconductor datasheet:
The counters are advanced one count on the
negative transition of each clock pulse. The counters are
reset to the zero state by a logical “1” at the reset input
independent of clock.
This means that every time the input (clock pulse) goes from high to low the output from at least one pin will change. Think of it like this:
Code:
IN -_-_-_-_-_-_-_-_
/2 --__--__--__--__
/4 ----____----____
/8 --------________
Except in reality I think it's a little more like this (due to the changes happening on the negative transition so notice that the output changes every time the output above it goes from high to low):
Code:
IN -_-_-_-_-_-_-_-_
/2 -__--__--__--__-
/4 -____----____---
/8 -________-------
As for your question about the reset: if you are not planning to use it then tie it to ground. It resets everything when it goes high. If you are going to use it, then tie it to ground with a 10k "pull-down" resistor.
Technically, the input doesn't have to be an oscillator. You can use it with pulse chains and pretty much any digital logic input.
A lot of people who make modular systems will just wire up each output to its own output jack, that way you can do whatever you want with them! You can use them to create heavy sub-octaves and create clocks at half the speed of other clocks for synchronization
acidblue
PostPosted: Wed Feb 05, 2014 12:35 pm    Post subject: Reply with quote  Mark this post and the followings unread
Was thinking of outputting the 4040 into a simple R2R ladder.
Then into a VCO so I get a sort of step sequence. i think
I have some 47k and 100k r's for the ladder, should work.
Was looking at Phobo's triple ladder here:
http://electro-music.com/forum/phpbb-files/modlunetta_tripler2r_v2_528.gif
But i dont think I need one that complex, for now.
Time to do some breadboarding, I'll be back Wink
commathe
PostPosted: Wed Feb 05, 2014 5:14 pm    Post subject: Reply with quote  Mark this post and the followings unread
I would say build the r2r ladder as a separate module as they are very useful. If you do what you are saying then you will get some sort of sequence, but if you don't solder them together, and leave it patchable, then you have a huge variety of sequences you can make.
Also, if you use a fast enough square wave you can use a divider and an r2r ladder to make stepped waveforms
acidblue
PostPosted: Wed Feb 05, 2014 6:05 pm    Post subject: Reply with quote  Mark this post and the followings unread
Ha Ha, you read my mind, plus I didn't have enough room on my bread board
so I put the R2R on a Pluto Board.
I'm gonna try this:
LFO into the 4040 >>> R2R >>> VCO.
The VCO Im using has a trig out so could I try:
Trig out >>> 4040 >>> R2R >>> back to VCO ???
 Filesize:  116.85 KB
 Viewed:  435 Time(s)
commathe
PostPosted: Wed Feb 05, 2014 6:13 pm    Post subject: Reply with quote  Mark this post and the followings unread
Of course you can try it! Can't tell you how it's going to sound though Razz
JingleJoe
PostPosted: Thu Feb 06, 2014 5:43 am    Post subject: Reply with quote  Mark this post and the followings unread
I've done this quite a lot and I feel I need to clarify that logic/digital circuits can usually only accept pulse/square waves as thier input, what you're talking about in the first post kinda confuses the concept: you just need a pulse wave, the frequency doesn't matter Smile only the voltage.
the 4040 itself will really give you octaves below the input. (e.g. input frequency divided by 8, if output "3" is selected) so if you put in a frequency of 100 Hz you get frequencies of 50, 25, 12.5, 6.25, 3.15 and so on, halving with each successive division. commanthe gives a great example with textual waveforms Smile
some inputs of cmos ICs require a pull up or pull down resistor depending on other parts of the circuit, but rarely ever a resistor in series. However, make sure you allways connect your inputs ot something, even if they are not used, or your circuit will malfunction because the high impedence inputs pick up random electromagnetic fields in the air!
Your suggested circuit yeilds some great and very fun results. Very Happy
commathe
PostPosted: Thu Feb 06, 2014 7:35 am    Post subject: Reply with quote  Mark this post and the followings unread
Thanks Jingle Joe! I guess I maybe wasn't clear about the fact that it had to be a pulse input (digital logic). I also had no idea problems coming from not tying unused pins to ground caused problems because of that!
